Tv patterning I am watching one tv program but another program from another station is showing up as static in the current program. You can only make out big shapes and some writing because it is clear in some places and static in others. Cheers, Dannal
  • dannal Oct 08, 2007
    I have isolated the TV and still have the problem but it happens through the VCR when I use it too.
    Cheers.
  • dannal Oct 13, 2007
    Thanks Chris but I haven't had time to scratch.  I will do as you suggested in the next day or two.  Cheers!
  • 372 Answers
Hi. What if any other devices eg dvd, vcr, do you have connected to the tv set. Is this just through roof antenna or is it through other device.
Posted on Oct 08, 2007
  • chris pursloe
    chris pursloe Oct 09, 2007
    Hi.
    Ok do these tests.
    Play a film on your vcr is the image showing through the picture ?
    Pull antenna lead out of the vcr now play tape again is the image showing now ?
    With antenna lead removed from vcr put antenna lead directly in to the tv set so that it now comes from the roof & directly in to the tv, what I want is the vcr completely disconected from the tv, Now put the tv on a channel what is picture like now ?
    How is the vcr connected to the tv set are you using Rf lead, Scart, Rca-Phono, Svhs,?
    Regards Chris
SOURCE:
After some homework, I am thinking perhaps the problem is the T-CON board? Do you think that is likely the problem?
Hello... No, it a Main board. If the T CON was the cause, all video would be affected, including the menus. This is not a guess... I work on TVs for a living, and have seen this symptom several times. It's always the Main board. I hope this helps!
Nov 26, 2017 | LG Televison & Video
I have amazon.prime - can I watch tv shows for free? I want to watch "the unusuals" do I have to purchase?
You can't watch current network programming, but you can watch series' that have been released, usually pre-current season episodes, often back to the original episodes.
Prime offerings are always changing, look specifically at prime tv to see what's available.
I f a series does not qualify for prime, you may be able to purchase a show or a season if it is offered on Amazon.
I believe you can subscribe to HULU through Amazon, in that case you can watch current network programming within 24 hours of it being on television, but there is a fee for HULU.
Aug 28, 2017 | Computers & Internet
When selecting the TV guide option it shows the current and future programmes for all stations however when trying to access the programmes from the past even just the last hour is not available
You will need to buy a newspaper or TV guide to see what was on in the past. If you can't watch it, they aren't going to show it. Fairly standard thought process.
Jul 30, 2017 | Televison & Video
Static on Powering on
You can start out by resoldering all poor solder connections and look for bad capacitors they will be puffed up on Top.
Oct 01, 2012 | Mitsubishi WS-65907 65" Rear Projection...
New dynex 24 in tv-working good but only shows 19 in picture. How to stretch to full screen?
Go into menu with remote control & change picture size. Depending on which station you are watching you may have to change it to suit your viewing preference. They transmit in different sizes
Apr 03, 2012 | Dynex DXR24TV 24" TV
No audio...only static
This is caused by a corrupted signal being sent out by one of the stations you are watching. There is definitely NO PERMANENT SOLUTION to this problem. Just keep unplugging the TV.
May 13, 2009 | RCA P60921 60" Rear Projection Television
Picture not clear when playing a recorded program from dvd
I had a similar problem with an Insignia converter box. This is confusing but . . . I was told by an Insignia person that you can only program the channel that you have on and cannot record a different channel. My output channel is 3. My roof antenna is attached to my converter box "From Antenna" jack. Attach the converter's "To TV (RF)" jack to your VCR's "Antenna Input" jack. Attach "Antenna Output" jack to TV "Antenna Input". You will see your programs on your output channel, but if your VCR is like mine, your VCR may not recognize anything but your output channel, no matter which station is actually showing on the TV. If I want to record a show on channel 7 while I'm gone, I have to make sure the converter station is on 7 and that I choose channel 3 as my channel to record. You cannot program shows to be taped on different stations unless you physically change it on the converter box. I put my VCR on "Record" and flipped the stations from one to the next from my converter remote control and I taped exactly what was on the screen from one station to the next. You cannot tape one thing and watch another. Clear as mud??? Hopefully, not.
Jan 02, 2009 | Insignia Digital-to-Analog Converter for...
Tv won't work
I downloaded this off of Wikipedia. You are not the only person having the problem with the switch to digital television. The complaints are nationwide. the old TV Guide Plus has gone away for many viewers and soon for all viewers as the transition to DTV gets nearer. If you are using an antenna be sure to get the digital converter. They are practically free with a government sponsored coupon.
Digital television
The new service, launched in the United States in 2006, is entirely digital, using the ATSC digital television standard. While this will significantly improve the service, older systems will no longer be able to download listings once analog shutdown is done in early 2009.
It should be noted that the Program and System Information Protocol (PSIP) within the ATSC standard already allows for each station to send out its own EPG information, and in the U.S. the FCC in fact requires stations to do so for OTA (but not cable, unless they are rebroadcasting an OTA station that provides the PSIP data). However, actual implementation is rather spotty, and usually very minimal -- stations often don't have full descriptions (or even correct information) on the current show, much less the next 3 hours required of them, or the 16 days worth of guide information that can be transmitted. Additionally, ATSC tuners are not required to even show the EPG, only the very limited information for the current show on the current channel.
While the TV Guide service also requires software in the TV or other device, and licensing fees or royalties to be paid to Gemstar TV Guide, it also offers a more complete solution for broadcast television, more like digital satellite or digital cable.
Nov 28, 2008 | RCA 20F420T 20" TV
Televison & Video Logo
Top Televison & Video Experts
Ekse
