Question about Brother IntelliFAX 5750e Laser Fax
Receiving comm. error 20 07 when sending a fax
  • 186 Answers
SOURCE: fax sending problem
It sounds like you have a few problems. First, the comm error usually means there was a problem communicating with the other fax. This maybe caused by a phone line issue, or a bad connection. You will have to replace you ink but that does not have anything to do with your sending issues. As far as the pages getting stuck, the separation pad under the top cover should be cleaned. If you lift up the cover where you load your pages to be sent, and look in there(on the backside of the keyboard)you will see a flat square rubber piece. Clean it thoroughly with a rag and some rubbing alcohol. Also clean the rubber rollers as well. Good luck John
Posted on Jul 03, 2007
SOURCE: comm.error displayed
Answer to your problem is move out of Verizon service area, they stink
Posted on Jan 30, 2008
leroyal
  • 2120 Answers
SOURCE: i cant get anything to
Call your cell phone from the fax machine.
Call some fax numbers on a regular phone and listen for fax tones.
Do you have a DSL phone line?
Posted on Oct 14, 2008
SOURCE: Brother FAX 8360P comm.error
Hi, my fax machine is saying off line error 077
Posted on Feb 01, 2009
SOURCE: Receiving error NG message when send multiple pages
Changed transmission mode to normal in order to get rid of EMC error. Caution! depends on your telephone line or modem, for DSL is good for normal mode at 14400 bps else set it to basic mode at 9600 bps.
Posted on Mar 07, 2009
Sending fax for hp all in one indicate Comm Error 388
Error could be caused by the fax machine that you are sending to.
So you can receive faxes, but can't send them. Is it just the one number that causes the error, or is it all faxes sent that cause the error?
What I like to do on fax troubleshooting calls, is to call the phone company that the site is using. Tell them that you are having fax problems, and ask them to test the line.
Jun 12, 2011 | HP LaserJet 3050 All-In-One Printer
Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
Eliteprintersolutions@gmail.com
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
Comm error 634
Receiving fax never picked.
Aug 14, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Rx comm error 200082 on receiving fax Ricoh aficio 222SF
I have Dell Monolaser MFP1125, can not send and receive fax
Aug 04, 2008 | Office Equipment & Supplies
Comm error
could be down to the line, had a similar issue which I believed to be hardware related, so got supplier to send a new fax out, spoke to someone at canon who said is def hardware related, any yet it turned out to be rabbits outside chewed through a cable (was in scotland..) so was a BT issue.
May 27, 2008 | Canon FAX-L1000 Plain Paper Laser
Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Jun 25, 2007 | Canon L120 Fax Laser Printer
Brother IntelliFAX 5750e Laser Fax Logo
79 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
