Question about Tunturi Exercise & Fitness
MOTOR OVERHEATING - Tunturi Exercise & Fitness
Why is cadillac deville very hard to start when hot?
if its a north star motor ,pistons are seizing LET IT COOL DOWN these motors are very bad when overheating ,find out why its overheating and fix it fast if you don't want more problems,these motors have the worst overheating problems up to 2010 they stoped making the motors because of overheating trouble. bolts in heads weaken from overheating and then soon after you have a blowen head gasket.
Sep 08, 2014 | Cars & Trucks
Will tappets on a pontiac 3.8 start rattling after motor overheats?
it can if the motor got very hot. you may have poor oil quality from overheating. damaged valve lifters, damaged camshaft/bearings, oil pump, water in oil which can cause engine damage from overheating. it will have to be checked out to find what caused the overheating then the lose of oil pressure to cause the rattle.
Aug 30, 2014 | Cars & Trucks
E56
Hi Susan, this is JK. I understand that you are receiving an error E56 on your washer. This error E56 is indicating a high motor current, the motor has overheated. The washer motor will stop when it is overheated, allow the motor to cool down and attempt to wash again. If the problem persists, you would need to contact a service provider to test the motor, motor pulley, tub pulley and the bearings. Hope this helps!
Mar 24, 2014 | Frigidaire Affinity ATF8000FE
Overheating dryer - motor replacement???
Good day,
You said "The dryer is still overheatng". If your not describing the motor but the whole machine then that problem will have to be resolved.
Maytag's build lint up badly in the blower housing area and the duct between it and the filter. Requires disassembling the front of the dryer and cleaning that area as well as determining if the blower wheel is loose on the motor shaft requiring replacing.
If the overheating is the motor itself, then replacing it would be a common item on that brand.
May 14, 2010 | Maytag Dryers
I have a numatic nss 450 floor poliser. floor
Probably the motor's thermal protector is shutting the motor off because of overheating, and then you have to wait for it to cool off and reset.
Especially in floor cleaning equipment, dirt and corrosion can be problems. Dirt can built up in the motor housing and block air flow, leading to overheating. Make sure the motor gets vacuumed or blown clean with compressed air to keep its air channels clear. Also, wear may be causing bearings to run hot. It may be necessary to have the motor disassembled and serviced by a rebuilder before it goes completely.
Mar 11, 2010 | Kitchen Appliances - Others
Motor shuts off after 30 seconds looks like it is overheating
More than likely the motor is overheating or at least the thermal overload thinks it is. The thermal overload could be bad but if the motor has burnt windings then it probably is pulling too many amps which will cause the overload. Sounds like you need a service call or take the motor to a motor shop.
Sep 13, 2009 | Emerson Threaded 1.5hp Fullrate 115/230v
The motor keeps turning on & off like it is overheating
it sounds as if it is overheating. there is a sensor inside all motors that shuts the motor down if it reaches a certain temperature.
If your motor shuts down after running for a while then 15 minutes or so just comes back on then that is what is happening.
Could be the result of not enough air around the motor to keep it cool, or something inside the motor making it work harder than it should like the bearings going out.
Feb 23, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Fan blowing but not overheating
That shouldnt be a problem. I have a 99 Sebring and it does the same thing. it has never overheated. if it is only blowing small amounts of heat you should be alright. and the fan is blowing to prevent the car from overheating.
having a heater running will help a car from overheating, it actually helps cool the engine.
Dec 01, 2008 | 2004 Chrysler Pacifica
Nocking motor
the motor starts nocking after about ten to fifteen minutes of running.and looks like it is overheating but i do not understand the overheating signals on the dashboard.
Jul 23, 2008 | 2001 Dodge Intrepid
Dryer shuts off
motor overheating ..doesit "groan" when start button pressed ? If so bad motor ..possible excess lint due to poor exhaust system caused lint build up around motor causing overheating and motor damage .new motor only fix
May 02, 2008 | Kenmore 62602 Electric Dryer
Exercise & Fitness Logo
15 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
