Question about Hardware & Accessories
Timers Manual timer telemecanique gt1-x02 , how to programme
    Top Expert:
  • 46,218 Answers
Google it , I never heard of that MAKE
Posted on Sep 13, 2017
  • 760 Answers
SOURCE: have model dt-17 7 day
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt17c%20-%20english.ashx
Here is a link to the manual from www.intermatic.com
Posted on Aug 19, 2010
SOURCE: how do i programm 735 t6 timer prince castle
A search of prince channel site for 735 timer sent me to the 740 timer >> their other models wer 755 and 840
Here's the prince castle page:
http://www.princecastle.com/products/timers_740series_single-display.asp
Here's the 2 instruction guides:
740 horizontal
740 vertical
The timer is a multi-channel countdown timer which means it can control multiple electrical devices separate from each other
Set the french fry cooker to tun on for 5 minutes
Set the dryer to come on for 10 minutes
Set the blower to come on for 1 hour
Set each item for different lengths of time
The item with least amount of time left shows on the screen
To program timer
Press and hold Prince Castle logo for six seconds
Time displays will change from " ----" to "PROG"
Press timer channel to be programmed
LED indicator light will turn yellow and beep will sound
Current programmed time will display (for example it might show 5 minutes 20 seconds)
Time value will indicate either H:M (hours-minutes) or M:S (minutes-second)
Press SCAN/UP arrow or SCAN/DOWN arrow to change program time
These arrows are located next to Prince Castle logo
If you want H:M instead of M:S, then press and hold SCAN/UP button
When display reaches 59:59 it will automatically change to 1:00 Hour
LED indicator light switches from M:S to H:M
Now you programmed first channel, click next channel and repeat steps above
To FINISH programming, press Prince Castle logo for a moment, and programs are saved
Posted on Oct 09, 2010
SOURCE: I have digital programmable timers
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Posted on Oct 12, 2010
SOURCE: I have two Delta 7 day programmable timers which I cannot programme ET7-AL
These are scans of the original packaging. Hope this helps. FYI mine packed up after a couple of years but is now working after I unsoldered and replaced the Troily 1.2v 40mAh (5.5mm x 12mm) button cell
Posted on Jun 10, 2012
  • 5245 Answers
SOURCE: manual for intermatic timer part no. 2T511GA
2T511GA is an Intermatic enclosure (or box)
2T511GA is a grey standard Indoor/Outdoor Nema3R metal enclosure.
http://waterheatertimer.org/pdf/Intermatic-Enclosures.pdf
Any intermatic box timer will fit into the enclosure.
Tork makes the IAP adapter so Tork/ GE timers will also fit into same enclosure.
This includes digital timer and analog timers made by both companies.
To find the exact manual, add a comment and describe the timer and number of terminals, and what voltage is being used, and what you are controlling with the timer. For example 6 screw terminals A 1 2 3 4 and controlling 2-speed 240 pool pump. etc.
Also copy following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Posted on Aug 16, 2012
How do you cancel the sunrise sunset program and just use your own times?
Most dawn-dusk wall timers have programmable option... except aube/honeywell.
Most plug-in timers have various options... but some are just astronomic and not programmable
Following link will help identify timer so you can download possible manual with instructions.
http://waterheatertimer.org/How-to-set-timers.html
Gene
Water Heater Timers Save Money
Mar 17, 2015 | Hardware & Accessories
How to wire a timer to delay a telemecanique LC1D4011M7
You need a delay contactor block that attaches to top of LC1D4011M7 contactor:
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#block
Connect power to contactor block.
Connect Load to other side of contactor block.
When contactor activates, it activates delay timer.
May 31, 2013 | Hardware & Accessories
How do I programme the tap timer?
Copy following link.
http://www.popeproducts.com.au/products/garden-watering-products/tap-timers-amp-auto-control-systems/tap-timers
Tap timers show on page.
Click timer image that looks like your timer
Another page opens, than just below the timer image is link to pdf instruction manual.
Oct 29, 2012 | Hardware & Accessories
How to programme UPM Model ETl30
More information is needed to find manual.
ET130 timer appears to have 6 buttons with 3 buttons on each row.
http://hkm888.com/upm-marketing-et130-indoor-programmable-timer-reviews.html
Review options below:
1) Add a comment and describe timer buttons in detail so I can match buttons with known timers.
2) Open following links and check if manuals for ET525, ET420C, ET420 might have same button and programming relationship.
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET420C
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET130
Add a comment please
Oct 02, 2011 | UPM Indoor Electronic Programmable Plug-In...
Where can we purchase Aube 7-Day Programmable 40-500w Light Timer Switch
You might be looking for T-1032 or T-1034 500watt timer
Identify model number on following link, and then google-search that specific model.
Link to instruction manual appears for each timer.
http://waterheatertimer.org/Aube-timers-and-manuals.html
Honeywell Aube in-wall timers can be used for single-pole or 3-way applications.
Look at instruction manual carefully for 3-way wiring.
Timer can be used for incandescent, halogen and CFL with minimum wattage requirement.
Since Aube timers have internal battery, they cannot be exposed to freezing temperatures or high temperatures.
Sep 28, 2011 | Aube Technologies Aube 7-Day Programmable...
Lost manual and i need to reset the timer
You posted under Woods 59028 almond-colored 7-day in-wall timer
Woods timer usually has Woods printed on it
Manual for 59208 timer:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
If this is not your timer, add a comment with more information
Also look at timers on following pages to help identify your timer
Most of these timers have similar programming, except with slightly different buttons, and some offer daylight savings time, and dawn-dusk feature
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/Programmable.html#Aube
Dec 12, 2010 | Woods 59028 Programmable Timer Switch...
Hardware & Accessories Logo
827 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
