Question about Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER 907058
Machine made a pop and started smoking - Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER 907058
Went to start car, made LOUD POP NOISE, then smoke poured out from under hood?? Is my car even fixable??
Depends on what went pop. What color was the smoke? If it was white and the engine was hot you may be lucky and just have blown a radiator hose. If the smoke was black or blue that would be more in line with an oil leak which may still not be the end of your car. You need to have someone look under the hook and determine where the pop sound came from.
Jul 27, 2015 | 1998 Buick Regal
Have a 22 hp kohler engine on a cub cadet comerical mower it smokes black smoke and pops through carb with no power
burnt a valve out need valve job with new valves might have also lost rings in one cylinder wont no till you open it up
Sep 11, 2014 | Garden
Check engine light goes on I hear a pop pop it chokes and than starts
Take it to your transmission people to find out why the pop. Step 2 will be if not fixed, the smoke issue.
Jul 17, 2013 | Cars & Trucks
It seems the electric control unit has popped so to speak, slight smoke was coming from the gaps near the top. asked around a few places and they asked if the door was sticky as this could of been the...
if the board has popped on your machine this is usually to do with the failing of another component such as the motor or heater, speaking from 17 years in the trade don't waste your money on this machine as it it will only be a matter of time before the board blows again!!
Regards
Ian
Apr 16, 2011 | Hotpoint Washing Machines
Hi. I have a brand new Benchmark Premiere 6 11068 popcorn machine. Ever since the first time using the machine the kettle smokes up. It smokes the entire 5 minutes while heating up and continues to...
could be that the bowel had a thin plastic protection on it when new that should have been peeled off before starting it up
could be a wire touching the hot bowel and melting
what ever , it is under warranty so take it to a service dealer or authorized repair shop and have it checked out
smoke and smell are food contaminants so the cause has to be found for safety reasons
Apr 17, 2017 | Benchmark 11065 Popcorn Maker
I have a singer curvy 8763. As soon as I started sewing, I heard a loud pop and smoke came out of the machine. Now it does not even turn on. How do I fix this?
I would call Singer at 1-800-4singer and have them direct you to an authorized warranty center. This sounds like an serious electrical problem and should be covered under warranty.
Dec 31, 2010 | Singer Sewing Machines
It smoked out my house when it was on the drying cycle any ideas?
did you have any plastic in it like a tupperware or anything for a baby?the water sprays so hard that it sometimes pushes plastic cookware or whatever out of the racks and it lands on the heater and melts the plastic,also if overloading the racks the plastic wheels pop off and burn on the heater,if not this then you'll have to kill the power and start looking for a broken wire on the door,amelted wire nut where the power wires are connected to the machine or the motor smoked up,could be anything,were you near the machine when it happened?could you see where the smoke was coming out of,under the machine or inside,also next time send the model number
Nov 21, 2010 | Frigidaire Dishwashers
Pop noise with thick white smoke from front end,
sounds like you might have a cracked cylinder and oil puddled up inside over night and when you started it..it blew out through the exhaust. White smoke means oil...black smoke means gas ,and blue smoke means both..if you cracked a water jacket your oil will look like a bubbly milk shake.....take a look at your oil.
Sep 08, 2009 | 2008 Yamaha YZF-R6
Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER 907058 Logo
56 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
