Question about GE Profile¿ Energy Star® 22.6 Cu. Ft. Side-By-Side Refrigerator with Dispenser, PSS23MGS
Whirlpool 27 cu ft side ed22pq - GE Profile¿ Energy Star® 22.6 Cu. Ft. Side-By-Side Refrigerator with Dispenser, PSS23MGS
taran_2005
  • 10515 Answers
SOURCE: I have two (2) GE
You can try to turn off your refrigerator from time to time but the biggest problem you are going to run into will have to do with remembering to turn it back on before it gets too warm and the food spoils.
Honestly it isn't something we would recommend. Instead you can turn the temp down a bit and make sure that it is always full with either food or gallon sized full water bottles to maintain the temperature inside even after opening the the door.
Just be really careful with lowering the temperature too much because the food can spoil. Instead try to keep it at the temperature that the instruction manual suggests.
However, as you would moving outside for 3 months, you could switch that OFF. Refrigerator plays a major part in chunk of your electricity bill ( on an average 16% ). So, on daily basis it is not advisable, but for 3 months it is recommended.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
heatman101
  • 43501 Answers
SOURCE: ge 26.6 cu. ft. side by side refrig- TFX27R- the
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 23, 2010
imufo2
  • 3773 Answers
SOURCE: Ge 26.6 cu. ft. side by side refrig- TFX27R no
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 06, 2011
  • 4 Answers
SOURCE: fridge side of side by side 25.6 cu. ft. iced up to where fan was hitting
un plug it and let is de ice..or put a hair dryer on the frozen park
Posted on Jan 31, 2012
cyrus_mansoo
SOURCE: My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Posted on Mar 08, 2012
How many cu yards to cover 196 sq ft to a depth of 2 1/2"
Hi Bob:
1 cubic yard is 3ft by 3 ft by 3 ft.
3 times 3 times 3 equals 27, so
1 cubic yard equals 27 cubic feet.
2 1/2 inches divided by 12 inches equals .2083333 feet
196 square feet times .208333 feet equals 40.83333 cubic feet
40.83333 cubic ft divided by 27 cubic ft equals 1.5123456 cu yards.
Ta Da!!!!
May 01, 2015 | Refrigerators
Need to know how many cubic feet my frig is so I can compare when shopping for another.
This is the information I could find.
Refrigerator Type Side-by-Side Total Capacity Cu. Ft. 21.7 Cu. Ft. Refrigerator Capacity Cu. Ft. 14.40 Cu. Ft. Freezer Capacity Cu. Ft. 7.30 Cu. Ft. Energy StarĀ® Qualified Yes
for more information try this link.
Whirlpool Appliances for the Home Kitchen and Laundry Room
Bob
Mar 16, 2015 | Whirlpool Refrigerators
How do you get the water filter out of refrigerator so you can replace it
Without knowing your particular model number, I checked and most 25 cu.ft. side by sides have the water filter in the grille. You just push a release button and it pops out. There is a cap on the filter, do not through it away as you will need it on a new filter. Also ensure the O-ring protective covers are removed on the new filter prior to installing. You can run the water dispenser without a filter as well. Here is a link to the PDF for one type of 25 cu. ft. Whirlpool side by side.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GS5VHAXWA_Use%20and%20Care_EN.pdf
Jul 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ice maker ,no harvest?
Hi, The optics almost never go in those unit's, the problem is in the icemaker module itself. If you can jump it thru a fill and then no advancing thru to harvest afterward ( provided your freezer is below freezing ) it's the module. You can either replace just the head/module or the entire icemaker. For the difference of only about $50 I always replace the complete assembly. The most common one being about $150 complete, # 2198597 and this should be the one for your fridge since you mentioned the optic component's. Hope that help's. Thanks for choosing "fixya" for your fridge inquiry. Please take a moment and rate this solution if indeed it solves your problem. Thanks again and good luck. Macmarkus :)
Mar 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
What is the capacity of washer model GHW9400PW0
Whirlpool GHW9400PW Washer / 27" Duet Front-Load Washer w/ 3.8 Cu. Ft. Capacity, 13 Cycles & 1200 RPM
Feb 05, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Water dispenser has stopped dispensing water. I have a whirlpool 25.4 cu ft. Side by Side Refrigerator
there are a few things to check real quick
does your ice still work
does your ice make still work
when was the last time you changed the filter
when you do call for water can you hear the water solonoid
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Profile¿ Energy Star® 22.6 Cu. Ft. Side-By-Side Refrigerator with Dispenser, PSS23MGS Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
