Question about Onkyo TX-DS797 Receiver
No sound I have noticed that i have had to turn the volume up a little higher than usual latley, but now i get no sound at all. Powers on but no sound, cranked vol up all the way on fm, music distorted, is the amp shot?
    Problem Solver:
  • 7 Answers
Possible problem will be on the speaker relay ckt. as discussed in onkyo's service bulletin.
"When the speaker relays are activated, the collector of Q231 and Q232 should drop to near 0Vdc. Voltage can be monitored at terminal P6830 and P6832. Q231 supports RL6600, RL6602 and RL6603, where as Q232 supports RL6605 for Zone 2 operation. If the DVC at P6830 collector or its follower terminal is HIGH, it should be an open transistor Q231."
Posted on Nov 13, 2008
SOURCE:
Why are my headphones making a vibrating sound on the left side, when there is a lot of bass.
Each speaker works independently from each other. One speaker may use more low frequency tones than the other one.. Low frequency tones create a lot more noticeable vibration than higher frequency tones. You can reduce it by turning the volume down a little on the left speaker. It is possible that nuts came loose on the speaker.
Jun 01, 2014 | Beyerdynamic DT 770 PRO Professional...
I have a pioneer elite VSX-21. when raising the volume beyond 20db there is a popping sound and the receiver turns off and recalibrates and turns on again. I also noticed when I raise it to 19db and higher...
it sounds like a power supply issue to me or maybe cold solder joints inside the unit. this is job better off if you take it to an audio repair shop might only cost 50 to 70 bucks to fix
Feb 20, 2018 | Audio Players & Recorders
No sound but all powers up. Signal light stays on.
Internal opamp fault, they look like a little spiders, 8 pin each, some of them got fried internally is a common srm450 issue, hope this helps.
Jan 28, 2013 | Mackie SRM-450 System
Navigon easy 40 no sound
The usual problem is the voice volume is turned down. This can happen when you are adjusting the volume down just as turn by turn instructions are starting; thus you don't notice it happened, or someone else did it or software glitch caused it or Murphy's law.
The way to fix it is turn vol up to max and set navigation and start driving. As you get to navigation points where you would expect the turn by turn instructions hit the up volume button. Keep trying it will only go up whilst instructions are being broadcast. Try using repeat last directions function to get a better shot at it.
This happened to me and this was the fix, odd but true.
Also see if there is a turn by turn vol level in settings.
Hope it works for you.
Aug 12, 2012 | Navigon 40 Easy 4.3" Sat Nav With Western...
I have a Sylvania SMPK4083 and the volume isnt the greatest. Is there a way to turn the volume up?
it goes up to 31... while u are in the music section, tap 'vol'... this should cause your the red 'vol' on the screen to start blinking... while its blinking tap '<< to volume down, and tap >>' to volume up.... when its where u want it, tap vol again to stop it from blinking...
Feb 08, 2012 | Sylvania SMPK4083 Digital Media Player
I have a 2001 chrysler voyager installed a kenwood stereo and when i raise the volume to where its lound the radio will turn off and on untill i lower the vol
My electronics savvy source says you may be overdriving the amplifier in your Kenwood stereo to an impedance-mismatched set of speakers, meaning that the speakers are impedance mis-matched to the Kenwood stereo, and therefore operate ok (but inefficiently) at low volume, but cut off completely at higher volume.
Fix: match the impedance of your speaker network to the specs on your Kenwood car stereo. Once this is done, you should be able to crank up the volume to the point of permanent hearing loss.
SAFETY CAUTION - sound levels above 85 decibels produce NIHL (noise-induced hearing loss).
http://www.dangerousdecibels.org/education/information-center/faq/
Oct 18, 2011 | Kenwood Car Audio & Video
I have a philips Matchline tv (29pt6361/79r) the tv works fine except it automatically turns the volume down without any buttons on the remote or tv being pushed
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
Mar 08, 2008 | Televison & Video
AUDIO
Hey Tex
You are on the right track, sounds like a noisy volume control. Can often be repaired with a squirt of cleaner spray into the potentiometer assembly.But I suggest you use crc2-26 contact lubricant spray, not silicone spray which is a great materials lubricant, but not electrical. Worst case, the Vol Potentiometer, may have to be replaced. Go for the CRC first and see how it goes. Good Luck, happy FixYa
regards
Graeme
Mar 05, 2008 | Audio Players & Recorders
LC-52D43U Volume Problem
if connected to a cable box is that vol up .
and is the vol up on the tv at the same time, 2 remotes 2 volumes
the other is that you may have changed the settings in the menu for surround / 3d or such and each effects max sound .
Mar 02, 2008 | Sharp LC-52D43U 52 in. LCD HDTV
Rca 32v524t chassis-atc010a
replaced,off/on vol,up and down,and channel up and down.
Nov 21, 2007 | RCA 32V524T TV
Onkyo TX-DS797 Receiver Logo
334 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
