Question about Coleman Heater - Golf Cat / Catalytic - 5036A850
COLEMAN GOLF CAT HEATER IGNITER DOES NOT WORK HAD ONE WINTER
DOES NOT SPARK
Hello, I have a Lochinvar ern 252, it was working great last season and was winterized properly... I just open the pool and now it is reading lockout ignition failure.... I can smell gas when it goes into...
two things, is it a spark igniter or hot surface?
if spark igniter is working then the pilot tube or fuel path to the igniter is plugged, a lot of times small spiders or insects will winter over in these tubes, build a small web or cocoon that restricts gas flow to the igniter. OR hot surface igniter not hot enough and will not lite the gas. can be tested with an amp probe or just replaced .
May 25, 2014 | Lochinvar ENERGY RITE 399000 BTU PROPANE...
Hi I have a Coleman furnace that has the electronic ignition model # G9to601oupb13c that will come on for about 3 seconds then shuts down if i turn off the power and restart it willl come back on and then...
If you mean hot surface ignition and not spark then look in front of the far burner from the glow plug and clean the rod in front of the burner with a piece of steel wool, the rod is probably dirty and can not sense the flame, so the gas shuts off.
Oct 11, 2009 | Coleman Propane Forced Air Heater...
Coleman 5040 Patio Heater w/ Light - Light works, Heater does not
BE VERY CAREFUL sticking matches in any propane appliance! With the gas OFF see if you can physically see the spark when you push the ignitor, if yes, the problem may be the regulator or bottle pressure the only test i am aware of for the regulator is replacement.
Jul 13, 2009 | Coleman (5040B750) Patio Heater
Coleman propane space heater
Google "Coleman" and go to "Propane Heaters" you should see a "contact us" or some such type in your problem along with when you bought the product they will be more than happy to help you.
Jan 29, 2009 | Coleman Propane Forced Air Heater...
Coleman presidential II furnace blower on and off
Sounds like the flame sensor. But it could be the thermostat. Is the furnace standing pilot or electronic spark or hot surface ignition. I would start by checking thermostat. Turn power off to furnace take thermostat off wall and take wires marked r & w and connect them together. Turn power back on if furnace works then change out thermostat.Most eclectronic ignition Furnaces have a flam sensor, You could take flame sensor out and clean it up with steel wool or wire brush. If you need anymore help just reply back .
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
How to install an igniter?
if the heater uses a hot surface igniter its a simple matter of unscrewing the igniter and replacing it with another unit. if it is a spark ignition, the spark wire is a heavy insulated wire that goes to the gap. check out white-rodgers for a replacement. if your furnace uses a purge mode get a purge cycle programmable igniter.
Nov 12, 2007 | Coleman Propane Forced Air Heater...
Coleman Heater - Golf Cat / Catalytic - 5036A850 Logo
150 people viewed this question
Top Coleman Electronics - Others Experts
Coss
Lawrence Oravetz
cwradio73
Are you a Coleman Electronics - Other Expert? Answer questions, earn points and help others
