Question about Refrigerators
Whirlpool Water Cooler whkm-D40 hot button broken, does not release water. How do I fix it?
I have a obsolete but modern-ish Whirlpool water cooler. The white plastic ring the 5 gallon water bottle sits on is cracked, and chunks are coming off. Whirlpool doesn't stock parts for old model
The collar is only there to keep the bottle at the correct height in relation to the water in the cooler. The principle is that when the vacuum inside the bottle is not being release by the water clearing the opening no more water will run out. To understand what I mean fill up a bottle ( any old bottle) right to the top. Fill up the sink and with you finger over the top of the bottle place the bottle upside down in the water. Take you finger from the hole and it will glug once maybe twice then no more water will run out until you lift the bottle out of the sink water. To stop more running out simply put the neck of the bottle bac in the sink. It is the same with you water cooler bottle. So all you need to do now is to to cover the foam with a piece of vinyle and it will be fixed.
Mar 08, 2013 | Cars & Trucks
I'm looking for users guide for my WHKM-D45 water cooler
Have you checked out the mfg web site? Google for it? Look for someone selling it and have a manual you can copy?
Sep 21, 2017 | Washing Machines
Whirlpool water cooler #whkm-D40 cold push-button broken, does not release water
First, check its button properly. Second, check the circuit board properly.
Chevy Silverado Parts
Aug 27, 2012 | Refrigerators
Temperature on a whirlpool D10 watercooler
Lisa coolers similar to yours=> Whirlpool Dual-Temp Top-Loading Water Cooler
It appears that customers gave a not so good review yet being inexpensive this is common when most products are imported from China. The WHKM-D10 that you have now is now called the WHKM-10DP Whirlpool Dual-Temp Top-Loading Water Cooler with Heated Water. Wish I had better news, but please keep me in mind for any other Whirlpool, Maytag, Kitchenaid, Jenn-Air, Amana,or GE Home Appliances, Thanks, John Tripp/AKA Sea Breeze
http://appliance911seabreeze.com/
Whirlpool Factory Technician
You also can find a user manual by clicking here=> Whirlpool Product Literature; Manuals, Guides and Instructions
Nov 15, 2011 | Refrigerators
I have a 2 year old whirlpool water cooler that no longer dispenses hot water. Any possible easy fixes for this?
I hope this doesn't sound insulting, but there is a switch in the back that controls uniquely the hot water, is it set to on?
Dec 25, 2010 | Whirlpool Refrigerators
Water cooler problem
what is your model number is then we can get started then okay
May 29, 2010 | Whirlpool GI15NDXTSS
I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Feb 18, 2010 | Hamilton Beach Water Cooler with Storage...
I purchased a whirlpool 40 gallon hot water heater model #BFG1J4040T3NOV in November of '08. since its been installed i been having a problem with the water staying hot for more than 1 shower. After about...
Will the water stay hot in the kitchen sink? Try to isolate the problem. If it is happening at all hot water locations, then it will be related to your water heater. If just in the shower then it is related to the mix of water ratio coming out of the shower hear. If its only the shower, then you are getting too much cold and not enough hot through the pipes. This can be very simple to fix by replacing the handle going to the shower. If this does not work then you may have a problem in the hot water pipes. After you isolate the problem, please post another question here.
Apr 16, 2009 | General Electric GE SmartWater Household...
Water is hot on both cold and hot side of my water cooler. water bottle on cooler is extreamly hot.
are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
Oct 06, 2008 | Whirlpool Refrigerators
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
