Question about La Crosse Radio Controlled Atomic Clock
The clock is one week old and I can't read the time or anything. I put new batteries in it when I bought it
Had to change the batteries in the Atomix clock and now the
Hello
What is the Brand name and Model number of your Atomic clock?
Jan 04, 2012 | Audio Players & Recorders
2004 mdx 90k replaced battery a few weeks ago, this morning wife said it would not start. Making some kind of a sound but would not start. She tried it a few more times over and hour period and then it...
I had a loud noise on my 04 mdx. Sounded like a bad belt. Took it to my mechanic and he found that the belt wasn't properly on the alternator. when i bought it, it had a new battery put into it. the dealer i bought it at had put a new battery in it. It was probably not starting, thinking it was the battery but it wasnt. It was the belt.
Dec 29, 2010 | 2004 Acura MDX
My 2003 FLHTCI sat for six weeks or so and needed a charge to start. Got it home and put it on a 2 volt trickle charger ver night. Started one time then no more. Bought new battery, running and charging...
No, the battery should charge at 14.5 to 15.0 volts. No problem. The 12.5 to 13.5 is not high enough to keep your battery charged especially if you do a lot of night time riding. You're fine.
Good Luck
Steve
Sep 22, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
Seth thomas autoset wall clock not functioning. replaced both sets of batteries (AA and CR2032), still not working.
I wish I had a solution... I'm in the exact same situation. I put in new batteries, and all I get is a faint reading of gibberish from the LCD screen, and that's it. I've tried following the instructions, but I can't set the time in the LCD clock, since it's unreadable, and almost completely gone. Seththomas.com has a web page indicating that "they will be back with info", but no support or FAQ pages. Disappointing... I have three of these clocks, and they are all behaving the same way.
Apr 10, 2010 | Seth Thomas Radio-Controlled Howard Wall...
My HJ720IT pedometer screen is blank. I thought the battery had died but got a new battery and it still won't work.
Mine has same problem. Died a week ago. Put in new battery and it worked for a week. Now it is dead again.
Dec 23, 2009 | Omron Hj 720ITC Advanced Pocket Pedometer
Clock will not keep time comp..is only 4 weeks old plus the touch pad freezes up from time to time
The reason the clock won't keep time and date is because the CMOS battery is dead, this battery inside the laptop keeps the date and time in the BIOS even when the laptop has no power to it.
I recommend you take the laptop back to where you bought it from or call the manufacturer as you are still covered by the warranty.
They will either arrange for the laptop to be sent in or send you to a service center.
It's also a good idea to mention that the touchpad freezes too.
Regards.
Aug 28, 2009 | Acer Aspire One PC Notebook
When I press BAKE to preheat the oven or CLOCK to set the time the display goes blank, then the number 30 appears, and then the clock time resets itself. I can still use the oven to preheat or bake, but...
I have the same problem. I bought it new in the fall of 2007. They replaced the control panel but that didn't help. Next they replaced the whole range with a new one, same model, still the same problem. They told me it was a problem with my electric in my house. Then they said it was a strange electro-magnetic field in my neighborhood and I would have to buy a different brand?
One time with the original stove the oven quit working and I had to re-set the breaker. Everything still works but the clock is always wrong.
We bought all Maytag stuff, including fridge, stove, microwave, dishwasher, washing machine, and dryer. The kitchen stuff is 4 years old. The washer and dryer are 3 years old. We have had this issue with the stove, the washing machine broke and they had to replace the whole drum assembly, and last week my refrigerator broke. Very disappointed with Maytag stuff.
So has anyone found a solution?
May 17, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Emerson Research SmartSet Clock Radio
Hello everyone,
I finally found a manual that I hope that it will help you as much as it helped me. It took long enough. Here goes; try this site:
http://www.emersonradio.com/owners/SmartSet%20Series/
Oct 28, 2007 | Emerson Smartset Clock Radio
La Crosse Radio Controlled Atomic Clock Logo
19 people viewed this question
Top La Crosse Home Experts
John
John
Are you a La Crosse Home Expert? Answer questions, earn points and help others
