Question about Milwaukee Saws
Milwaukee portable bandsaw blade jumps off - Milwaukee Saws
clyde2j2
  • 137 Answers
SOURCE: I do not know how to change the blade on a dewalt
I'm not familiar with that particular band saw but I have had a few different band saws and they all pretty much work the same.
Unplug the saw and remove the top and bottom wheel guards.
Look behind the top wheel and you should see a large bolt standing vertically it may have a knob on it or it may not, look on the bolt to see if it has stop nuts if so loosen them then turn this knob so as to lower the wheel enough so you can remove the old blade.
Clean the rubber tires on both wheels and install the band with the teeth facing down.
Now the tricky part, adjust the top wheel so that it is firmly against the band and turn the wheel slowly by hand (be sure the saw is unplugged) if the band "walks" one way or another, you will have to find the set screw or set screws that adjust the tilt of the wheel, adjust these until the band runs true on the wheel. When it does, tighten the wheel a litte more and turn again slowly by hand repeat this until the band runs true and it is very tight on the wheel, Put the guards back on before you turn on the power. You should be good to go.
Posted on Apr 06, 2009
rowdy45176
  • 2176 Answers
SOURCE: blade popping off front wheel
Is the axle tight? Has the tool been dropped to warp the frame? But a quick fix if everything else is OK is to loosen up the axle and put a THIN metal shim on the backside of the axle and then tightening it back down.
Posted on Jul 29, 2009
  • 582 Answers
SOURCE: bandsaw blade keeps coming off the wheels. What
ALL BAND SAWS HAVE AN ADJUSTMENT FOR THE BLADE TRAVEL WHEN I WOULD REPLACE MINE I WOULD ROTATE THE TOP WHEEL BY HAND TO CHECK THE ALIGNMENTAND WATCH WEHICH WAY THE BLADE STARTS TO TRAVEL THERE SHOULD BE AN ADJUSTMENT ON THE TOP WHEEL THAT TILTS THE WHEEL IN OR OUT JUST A TINY TURN WILL MAKE A BIG CHANGE
Posted on Aug 22, 2009
  • 302 Answers
SOURCE: clark 6x4 bandsaw
there should be an adjustment knob on the back that changes the angle of the top wheel and this will center the blade so it stays on. I do this by jogging the saw on and off while I adjust it. hope this helps you
Posted on Sep 24, 2009
  • 32 Answers
SOURCE: saw is making noise while
Its been my experience that when a Band Saw makes a clicking noise its a blade issue i.e cracked,bent tooth etc. I would change the blade and see if that helps.
Posted on Oct 25, 2010
The blade won't stay on even though I have it on properly it comes right off when I turn it on
I have no experience of portable bandsaws but do have some experience of workshop bandsaws.
One wheel is generally movable in order to "steer" the blade and careful adjustment is needed with the blade guides retracted until the blade runs full on the wheels. The blade guides are then brought back to prevent the pressure against the work from pushing the blade off the wheels.
Oct 04, 2015 | Milwaukee tools 6242-6 Compact PortaBand...
How to keep blades from walking off portable bandsaw model 6225. I replaced bushings on both wheels. Don
Hi Don. have you tried over tightening the blade tension? that works for me
Mar 03, 2015 | Milwaukee Tool Saws
Blade drift with Milwaukee bandsaw
Worn band saw guides maybe? Or too much tension or change the blade , I use bi metal Haltbar band saw blades of sawblade.com
Mar 26, 2014 | Milwaukee 6238 Deep Cut Portable Band Saw...
Jammed my 6230 bandsaw during a cut and now it won't start. Are their fuses I can replace?
Go to Milwaukee Tool website and try to check if you can download a manual or electrical diagram there. You can call or email them. Check the motor capacitor.
Are you using an old or new band saw blade? If it's old/dull, try different blade. If it's new, the weld might be really bad. Old Blade and Bad weld can cause the blade to jump off. I purchased band saw blades on www.sawblade.com . Great quality blades; they have porta band blades. Call them.
Oct 23, 2013 | Milwaukee Tool Milwaukee 6230 Deep Cut...
I have an 18v Milwaukee bandsaw (model #2629-20) and the blade is constantly slipping off the wheels. I'm thinking it's an easy fix but not sure exactly what is causing the problem. Please hel
Possible causes:
- Tires: If the tire(s) on the front or rear pulleys are worn, torn or have chuncks out of them, the blade can slip off.
- Pulley(s) out of line: If either or both pulleys are out of alignment the blade will work it's way off. This could be caused by a worn pulley hub; a worn or broken pulley axel; or worn, broken or frozen bearings where the axels turn. On the drive pulley this could include the bearings on the drive shaft or the boss where the bearings fit into.
- Blade: If there are any kinks or slight bends in the metal they could cause the blade to work off the pulley.
Mar 07, 2012 | Milwaukee Tool Saws
Just purchased a 6230 porta band saw and the blade keeps jumping off. Put the blade back on and as soon as you touch the material the blade jumps off.
could be a couple problems, first the blade could be bad, the tires that are on the wheels, a loose axle bolt or the frount housing might be bent. First try another blade and watch for which pulley it rolls off of. Next try to wobble the pulleys and if you can the axle bolt has loosened, I use an impact driver to lock them in place along with loctite. Next if the above are OK check the front housing for being bent (that is a common thing) from the housing hitting after cutting a piece of steel. Let me know if you need more assistance.
Oct 06, 2010 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Saw is making noise while cutting ( click..click..click ) Milwaukee portable bandsaw ( 6 months old ) paid over $350
Sep 17, 2010 | Saws
I bought an older used 6225 milwaukee bandsaw, it worked alright for a little while then it started runing slower & slower till it hardly turns now. Would it need an armature?
Hi Joe,
While that is a possibility, I usually start with blowing it out with compressed air, then inspecting the brushes. They're usually the first thing that wears out (down).
Best regards
Mike
Mar 31, 2010 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Want to know where to get owners manual
You can go to Milwakeetool.com and down load the manual for your tool.
May 24, 2009 | Milwaukee 6232-6 Variable Speed Deep Cut...
Saws Logo
113 people viewed this question
Top Milwaukee Saws Experts
Navin Sharma
Navin Sharma
john h
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
