Question about Tablets & eReaders
Have a novatech tablet with jellybean 4.1 can I upgrade to 4.3 version
As the firmware states jellybean 4.1 on Novatech tablet, and want to install certain apps but states I need jellybean 4.3 can I upgrade my tablet.
3 Suggested Answers
sepideh_rose
SOURCE: my tablet won't download facebook app. States the web page is not available. Also states it may have moved permanently!
Backgammon on facebook onlin an ipad new
Posted on Nov 25, 2012
  • 21 Answers
SOURCE: Hi I just got a tablet online and it doesn't have
Just make sure with the play store settings, whether you have sign in with your G mail account or not. If no just sign in and try else register as a new user and try. If found still there were an error. Just try to restore the tablet. If you again found the same error then, shutdown the tablet and press power + volume up button up to 15 seconds, so that you will get restore option there and restore through that. Definitely it will work for you.
Posted on Aug 01, 2013
Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
Sep 30, 2016 | Tablets & eReaders
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
I need new firmware for my videos s7 tablet I have ver.2.2.2
Most firms, don't make newer versions for Android tablets or phones. They only develop newer software for this new systems. For your tablet the version 2.2.2 is the latest.
The only way to get around this, could be you root your system. BUT this can be dangerous, because you can end up with a non functioning tablet. You can't root, with just any rom. You need a rom that was developed for your tablet. I could not find a rom, so perhaps the Android community did not think it was worth developing one.
If you don't have any experience with updating computers or tablets, don't even start looking for it, because one error and our tablet is bricked. (can't be used anymore)
Nov 03, 2014 | Huawei Ideos S7 Slim Tablet With 8gb...
Forgot my password how do I factory reset my
Accoruding to the Polaroid website, you can do this, but it does state:
IMPORTANT! Please make sure that you backup your files to a computer before you update your tablet's firmware. All content will be deleted. You can re-download your purchased and/or free apps from the Amazon Appstore (or other appstores) once the firmware update is completed.
Here's the link to the READ ME.
Polaroid Tablet Support Site
Remember, it is very important to find your EXACT model number AND build number located on the back of the tablet before performing a firmware upgrade. Performing an upgrade to the wrong tablet will result in the tablet being "BRICKED", rendering it useless as well as voiding your warranty.
I hope this helps and thanks for using fixya!
Oct 07, 2014 | Tablets & eReaders
I need operating system mine is lost its harddrive is dead, so i have new one
On the bottom of your tablet/PC you will see a COA sticker stating what version of windows was installed. You can download an image file from various sources on the web/torrents and install using your current license number. The drivers for XP are still available on the gateway website, however if you decide to upgrade to Windows 7 there are some advanced tricks you need to be aware of to install all the drivers, most of which are outlined in previous posts for your m275 tablet here on fixya. :) (I recieved 13 of these from a university science department that upgraded and have successfully re-installed both XP and win7 on all of them.)
Mar 13, 2014 | Gateway M275 Tablet PC
Polaroid tablet jelly bean 40490 cant install any apps from google play store just says error 403
Read this, there seems to be a known bug:
http://forum.xda-developers.com/showthread.php?t=1774808
If your tablet is not running the latest version of Jellybean, I would suggest you update it.
Feb 11, 2014 | Polaroid Tablets & eReaders
Manual for zeepad jelly bean 4.2 version
I need a readable Manual for the zeepad jellybean 7" screen
Jan 14, 2014 | ZEEPAD 7.0 Capacitive Touch ceen 512/4G...
Need the stock rom for a mid 729b?
Can you tell me where you got the upgraded rom from, and have you tried downloading the firmware from the manufacturer's website? http://www.archos.com/us/support/support_tech/updates_fwm.html
Dec 21, 2013 | mid Archos M729B Android Tablet
I just rooted my mid kacaso tablet. I want to upgrade my current version (Ice cream sandwich) to 4.1 Jelly Bean. Can you please tell me how do I get the Jelly bean firmware
after some days/ or when its the time for your tablet it will(a message will automatically come and then you can upgrade your current version (Ice cream sandwich) to 4.1 Jelly Bean. wait and see. then be happy
May 23, 2013 | Tablets & eReaders
Hi Just got my new archos 101 8gb Spec said 2.2 but it came with2.0.54. on plugging in to PC the upgrade didnt happen so upgraded to 2.1.04 Everything that I have thrown at it works but I dont have...
Betty,
Archos has been saying Flash would be officially available for some time now, but it's still not out. There is a beta version that I'm using, works great for me:
First step to getting Flash working is to go to your settings menu, then Applications, then check the box to allow for Unknown Sources to be installed.
To get a Beta version of Flash working use this link (from your Archos tablet):
http://ge.tt/36fA44X
You should be prompted to install this APK file on your Archos 101 after it's downloaded, this will give you a decent version of Flash (it's taken from a Droid X which has similar hardware to the Archos 101).
The Version number of your Archos 101 firmware is different from the Android Operating System. Version 2.1.8 is the latest Archos firmware as of Feb 28, 2011, this is Android 2.2.1.
To force an update, you actually need to connect the Archos 101 to the internet, not to a PC. Once you're connected to a Wifi network and have access to the internet, go to your Settings, then scroll to the bottom to About Device. On this screen is a Firmware Update option, this will check for and download the latest. Once it's downloaded you'll be prompted to plug your tablet into the charger and restart it to apply the firmware.
Feb 05, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Tablets & eReaders Logo
51 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
