Question about Video Game Consoles & Games
I get this message your dns setting have been modified. Accept changes or restore original saved settings? I cannot fix this with accept or restore, can someone help please.
mlgposer
  • 146 Answers
SOURCE: Joining XBox Live
Make an account offline that should work.
Posted on Feb 06, 2008
gilgamer01
  • 135 Answers
SOURCE: DNS error (80410411) cannot find server
If you are using a public router (meaning you're using just a connection from somebody else's router) prolly, you're DNS have been blocked...have you tried connecting to other sources other than the one you can't use? If you have a connection and you don't own your own wireless router, try borrowing one from someone you know first then try if it works...then that's the time you should ask for your own wireless router...
Posted on Jul 29, 2008
rockitman187
  • 2559 Answers
SOURCE: wii "setting" screen" error message...
As soon as you turn it on and the warning screen appears press the B button on the wii remote 10 times,(if this didn't add the developer channel you will need to do it again)Then go into wii settings after it loads.
Posted on Feb 22, 2009
  • 52 Answers
SOURCE: I have a wep key with letters and my psp won't accept it.
On some modems/routers you need to push a button that lets you connect portable devices to your connection. push the button and 2 seconds later try to connect to your connection
Posted on Jun 26, 2009
  • 38 Answers
SOURCE: I cant play online on my ps3. DNS problem.
try restarting the router and then try it . then see if u can update ur system by the computer.
Posted on Jun 30, 2009
How do I set up the ecb350 as a repeater. I have an xfinity wifi that doesn't reach the whole house but I can connect with an Ethernet cable to the back of the ECB350 out in the area I need wifi acce
What are you using for your main router (xfinity wifi)? The best way is to set the ecb350 in AP Router Mode not a repeater since you have a rj45 cable long enough to go from one of the ports on the xfinity wifi router and hook it into the ecb350. You will need to know what your ip address range is for example if the xfinity is 192.168.1.1 then you want to assign a static address for the ecb350 to be 192.168.1.100 (assigned IP Address) You will also need the Subnet mask, Default Gateway IP Address, and Primary DNS and Secondary DNS of the xfinity wifi router. Then on the ecb350 you will need to configure the following with the info you go off the xfinity router:
Static IP Internet Connection Type Select Static IP to begin configuration of the Static IP connection. Account Name Leave Blank Domain Name Leave Blank MTU Auto IP Address ie: 192.168.1.100 (assigned IP Address) IP Subnet Mask Specify the subnet mask of your Xfinity Router Gateway IP Address Specify the gateway of your Xfinity Router Primary DNS Specify the primary DNS server's IP address of your Xfinity Router Secondary DNS Specify the secondary DNS server's IP address of your Xfinity Router Discard Ping on WAN Check to Enable to recognize pings on the ECB350 WAN interface or Disable to block pings on the ECB350 WAN interface. Note: Pinging IP addresses is a common method used by hackers to test whether the IP address is valid. Blocking pings provides some extra security from hackers. Accept / Cancel Click Accept to confirm the changes or Cancel to cancel and return previous settings. Note: Clicking Accept does not apply the changes. To apply them, use Status > Save/Load Hope that this help you.
Sep 10, 2014 | EnGenius ECB350 Wireless-N Indoor...
How do I factory reset a Lexmark x658de?
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
May 01, 2014 | Lexmark X658DE All-In-One Laser Printer
Vtech model 6053 answering machine will not record message
Perhaps your answering machine needs to be set set to accept messages. Maybe your message machine memory is full of messages?
Aug 03, 2012 | Vtech DECT 6.0 Cordless Phone with Digital...
How do i enable cookies on my web browser?
Internet Explorer 6 for Windows
  1. Within Internet Explorer, click the "Tools" menu and choose "Internet Options."
  2. Click the tab labeled "Privacy."
  3. Click the button labeled "Advanced."
  4. Check the option labeled "Override automatic cookie handling." To enable cookies:
    Set "First-party Cookies" (and "Third-party Cookies, if you wish) to "Accept."To receive a prompt to accept or decline cookies on a site-by-site basis:Set "First-party Cookies" (and "Third-party Cookies, if you wish) to "Prompt."
  5. Click "OK" to save changes and close the dialog box.
Firefox for Windows and Mac OS X
  1. Open Options dialog box: WindowsWithin Firefox, click the "Tools" menu, then click "Options."Mac OS XClick the "Firefox" menu, then click "Preferences."
  2. In the left-hand column, click the icon labeled "Privacy."
  3. Click "Cookies," then click the option labeled "Allow sites to set cookies.
  4. Click "OK" to save changes and close the dialog box.
Safari for Macintosh OS X
  1. Within Safari, click the "Safari" menu and choose "Preferences."
  2. Click the icon labeled "Security." To enable cookies:Set the option labeled "Accept Cookies" to "Always."
  3. Click "OK" to save changes and close the dialog box.
Internet Explorer 5 for Windows
  2. Click the tab labeled "Security."
  3. Click the button labeled "Custom Level."
  4. Scroll down to the section labeled "Cookies." To enable cookies:Set "Allow cookie that are stored on your computer" to "Enable."Set "Allow per-session cookies" to "Enable."To receive a prompt to accept or decline cookies on a site-by-site basis:Set "Allow cookie that are stored on your computer" to "Prompt."Set "Allow per-session cookies" to "Prompt."
Internet Explorer 5 for Macintosh
  1. Within Internet Explorer, click the "Edit" menu and choose "Preferences." (In OS X, click the "Explorer" menu and choose "Preferences.")
  2. In the left-hand column, click "Cookies." It is is listed in the "Receiving Files" group.
  3. Click the button labeled "Custom Level." To enable cookies:Set option labeled "When receiving cookies:" to "Never Ask."To receive a prompt to accept or decline cookies on a site-by-site basis:Set option labeled "When receiving cookies:" to "Ask for each site."
Internet Explorer 4 for Windows
  1. Within Internet Explorer, click the "View" menu and choose "Internet Options."
  3. Select "Custom" and click "Settings."
  4. Scroll down to section labeled "Security." To enable cookies:Select "Always accept cookies."To receive a prompt to accept or decline cookies on a site-by-site basis:Select "Prompt before accepting cookies."
Opera 7 for Windows or Macintosh
  1. Within Opera, click the "File" menu and choose "Preferences."
  2. In the left-hand column, select "Privacy."
  3. Select the option labeled "Enable cookies."
Netscape Navigator 6 and Higher for Windows and Macintosh
  1. Within Netscape Navigator, click the "Edit" menu and choose "Preferences." (In OS X, click the "Netscape" menu and choose "Preferences.")
  2. In the left-hand Category column, click "Cookies." It's listed in the "Privacy and Security" group. To enable cookies:Select "Accept all cookies" or "Accept only cookies that get sent back to the originating server." To receive a prompt to accept or decline cookies on a site-by-site basis:Check the option labeled "Warn me before storing a cookie" and select "Accept all cookies" or "Accept only cookies that get sent back to the originating server."
Aug 28, 2011 | HP Computers & Internet
Trying to connect to internet and its reading error code 220602.
Sorry to hear your having issues with your wii internet. One solution you can try is to:
Disable encryption on your router. Set up a new wireless network profile on your wii and then connect to it and do not use encryption. Accept the user agreement when it pops up. Then set up the encryption again on your router and try to connect using the encryption key.
Apr 27, 2011 | Nintendo Wii Console
I have nokia 6500s. It shows black screen after some time and again come in stable state. Some times it cannot accept memory card. Please help me to hard reset my phone.
All you have to do is:
From MENU goto SETTINGS, When there scroll down and select 'Restore Factory Setting'.
There are two options in there:
"Restore Settings only"
and
"Restore all"
Select "Restore All"
When done the phone will delete every thing on the Phone memory(C:\)(contacts,picture,messages etc)
and also restore phone to its original settings and will restart.(use 12345 or 0000 default code)
This proceedure is mostly common on S40 phone.
or try the code *#7370# (for hard format)
or *#7780#(to restore setting only)
Hope this explain and solve the problem
Feb 15, 2011 | Nokia 6500 Slide Cellular Phone
I want to restore my pc to its factory settings
Take the original "System Restore" set of CD/DVD disks that were shipped with your computer, and reinstall Windows.
Some brand-name manufacturers (Dell, IBM, HP, COMPAQ) will accept telephone-orders for that set of disks, to match the disks that originally were shipped with the computer.
Sep 27, 2010 | Computers & Internet
I have to restore factory setting in nokia 1110i using code 1234,0000 but not accept this code plz help me
Turn of your phone for 30 Minutes and Then Try 12345 not 1234. Please Vote if solved.
May 12, 2010 | Nokia 1110i Cellular Phone
The resource cannot be displayed The page you are looking for cannot be opened by your browser because it has a file name extension that your browser does not accept....
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this problem, make sure that the Accept header of the client request matches the MIME type that is specified for the requested content file name extension on the server. To do this, follow these steps: 1. Start IIS Manager. To do this, click Start, click Run, type inetmgr.exe, and then click OK. 2. In IIS Manager, expand the server name, expand Web sites, and then click the Web site that you want to modify. 3. In Features View, double-click MIME Types. 4. Double-click the MIME type that you want to modify. 5. In the Edit MIME type dialog box, type the appropriate MIME type for the content file name extension in the MIME Type box.
Note You can also set the MIME type of the content file name extension to */* to accept any MIME type
Sep 29, 2008 | Computers & Internet
Pictures appear to be darker than original in print outs.
You can make several adjustments to improve your images such as lightening dark areas, changing the exposure, sharpening blurred edges, and changing the brightness and contrast.
  • Exposure adjusts the overall intensity of light in an image.
  • Adaptive Lighting improves only the dark areas in an image without affecting the bright areas.
  • Brightness adjusts the amount of light in colors ranging from light to dark.
  • Contrast adjusts the difference in brightness between light and dark areas of an image.
  • Sharpness helps define edges and the smoothness of texture in an image. Use this tool to make a blurred image appear more focused.
Adjusting the image Follow the steps below to make adjustments:
  1. Click the View tab and select the image you want to edit by either clicking the image, or by clicking the small box at the bottom left corner of the image. Figure 1: Select the image c00603524.gif
  2. Click the Edit tab and then click the Advanced tab.
  3. On the Advanced tools tab, click Adjust Image .
  4. Select an adjustment from the list on the left. Figure 2: Adjusting the brightness c00603525.gif
    • The Exposure adjustment is automatically applied when the Adjust Image tool opens. Eight variations of the image are displayed on the left. The current image is displayed in the center. Each image represents a different level of adjustment. When you move the pointer over any of the images on the left, a large version of the image is displayed. Use Preferences to turn this large image preview on or off and to set the timing for the display.
    • If you want to use a different adjustment tool, select Adaptive Lighting , Brightness , Contrast , or Sharpness from the list.
  5. Select one of the images on the left.
  6. Do one of the following:
    • Click Accept to accept all changes and exit from the Color Toolkit.
    • Click Cancel to discard all changes and exit from the Color Toolkit.
  7. If you have finished modifying the image, do one of the following to save your changes:
    • Click Save to overwrite the original image.
    • Click Save As to save the modified image with a different name.
Aug 25, 2008 | HP Photosmart D7160 InkJet Printer
Video Game Consoles & Games Logo
66 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
