Question about Dryers
Kenmore 96429100 no heat element tests @ 9.8Ohms(within range according to schematic) no continuity on thermal protector on upper end of element housing. Question is , there is a sticker that says if thermal protector fails , to also replace 'high limit' switch. Is that on bottom of element housing or by the vent hose base?
TheMobilian
  • 8220 Answers
SOURCE: how do you test dryer heating element on GEQ9800LW0
Ok maybe the heating element got old and brittle over time and finally gave up the ghost. But it may not be the element. It could be one of the safety Hi-limits have blown.READ MORE...
Posted on Apr 10, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
garing
  • 998 Answers
SOURCE: Kenmore 80 Series Heavy Duty Electrc Dryer runs but will not heat
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Posted on Aug 06, 2009
  • 103 Answers
SOURCE: i have a kenmore he4 no. 110.85871400. i have no
Check thermistor with ohm meter, make sure you unplug unit first, make sure wires are removed from thermistor or you will read ohms thru the wiring. If thermistor checks ok, the you have a relay board problem. replace power board.
Posted on Oct 01, 2009
dmftrucker
  • 1922 Answers
SOURCE: whirlpool GEW9200L not heating up, i have replaced
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
Posted on Oct 09, 2009
Kenmore electric range/ovens
Most likely the clock / control or a thermal fuse if your model has one.
Oct 09, 2017 | Kenmore Ovens
Upper oven will not heat up, broiler does not work.
Hi Larry
Use a multimeter on AC range to test for voltage on wires going to bad element.
It's probably a bad switch or open element.
Elements often unplug for replacement. Don't always show damage of burned out conductor. So... Use your multimeter on the ohms scale to test for continuity at each end.
Upper oven element is likely open circuit and will need to be replaced.
Cheers
Nov 03, 2015 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Kenmore 96429100
Electric Dryer? Most common issue, especially on one of this age, is the heating element. Check with multimeter at contact terminals where element connects to dryer.
If bad, order new online and replace.
Nov 19, 2013 | Dryers
Kenmore 70 series dryer won't heat
Post the model number for clarity. These tests should only be attempted by competent service personnel. Do you actually have 220 power? Are both legs of circuit hot...at 120v? While dryer is unplugged from power, check the heating coil for continuity. Also check continuity to ground from each end of heater (should not have continuity to ground at both ends). Also there should be power to the heating element when activated.
Mar 14, 2012 | Kenmore Dryers
My Kenmore 400series 6942 electric dryer works, but doesn't get hot. Pulled the heating element had it tested. It shows good. Had three other relay/fuses tested. They show good. It has to be easy enough...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpg if there is no heat then one of the thermal fuses is bad you will need to check the continuity on them and replace the one that does not have any continuity
Jan 20, 2011 | Kenmore 400 6942 Dryer
Placed new heathing element dryer wont heat
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
Nov 19, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Kenmore 110.72822101 dryer does not heat. Need schematic
Parts to be tested:
Thermal fuse - test continuity with multimeter at Rx1 (Ohms) Heating Element - Same Thermostat-High limit - read Ohms, must have low impedance at room, and infinite at limit temp. Fan - Check if it is running Timer assembly - Difficult to test in full, look for faulty parts at a glance - read volts out.
always disconnect power when testing the appliance.
Here below the schematics and illustrated parts breakdown:
Please, do not forget to leave feedback.
Many thanks.
Ginko.
Sep 21, 2009 | Dryers
Dryer not heating
normally, it is the thermal cutoff switch. test this part for continuity and if there is non, then that is your problem.
tnx 4 using fixya,
drcool
Sep 29, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Dryers Experts
