I have a GE Profile Harmony high efficiency top load washer that is having significant problems with mold buildup. There is a strong odor and a nasty gray residue on my clothes. I took the washer apart 3 months ago and the area between the stainless steel drum and outer tub was disgusting! I cleaned it all out and have been very careful to leave the lid open between loads, remove wet clothes promptly, etc, but I'm already having problems again. Any ideas? Should I give up and buy a new washer? The only advice GE customer support offers is to use Tide washing machine cleaner but that requires you to run an empty load and my machine won't even fill unless it has clothes in it.
  • 29 Answers
I think It will be possess some problems at first and there are a lot of people that will have the troublesome models however I have seen a huge decline of failure rate on these washers. I have sold a lot of them and I do not have to go out to repair them no more than normal. I even put one in a commercial setting and it has had to have a repair only to attain a good and needy things out of the same.
https://www.structuredsettlement-quotes.com/
Posted on Nov 20, 2013
ttech
  • 139 Answers
SOURCE: empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
Posted on Jul 20, 2007
ginko
  • 19396 Answers
SOURCE: washer spins dry but will not fill also outer tub does not drain
If washer does not fill.
If water is not getting into the machine, check the following:
To start cut power to the applianc3e for five minutes, this can fix a jammed timer control.
Check if the hot and cold water faucets are connected, and have good pressure.
If that does not work you may need to call a repairman to test the following:
The inlet valve must be tested by energizing it , testing valve solenoid, and reading voltages to identify a fault in wiring (contact).
If the inlet valve is fine when tested, worth having a look at the water level switch, if it is stuck on overfill position , it will prevent water from getting into the machine.
Lastly,the timer control board should be tested, to ensure that the problem is not a faulty timer keeping the inlet valve on close position.
Posted on Mar 30, 2009
  • 4 Answers
SOURCE: mold buildup around interior of drum - odor and spots on clothes
Posted in 2008
I've had my Duet for 5+ years with no odor until the past 6 months or so. Even changing to a more fragrant fabric softener didn't make my cleaned clothes and towels smell clean. I noticed it especially when I would grab my towel after a shower. For a while I thought someone else was using my towel and stinking it up. Then I realized it was the whole laundry. ( I was having my laundry done for me... otherwise I probably would have realized it sooner. After reading all the suggestions for resolving this sour odor I thought I would try some of the ideas suggested that I hadn't already tried. Then it dawned on me that about 6 months ago I switched from a powdered detergent (SA8, an Amwy/Quixtar product) and dryer sheets to a well-known well-ranked Liquid Detergent and a fabric softener. I only switched because my son like the way his friend's laundry smelled when he borrowed a shirt. I was using fragrance-free products. So I had fragrant laundry for a short time. Then it started to smell sour. Maybe this change was the cause. So I've ordered another box of the powdered detergent and I'm going back to dryer sheets.
In the meantime I'm still doing stinky laundry. Same day I order new detergent, I decide to wash a load with some very stained baseball pants. I sometimes use a small amount (1/4 cup) of Oxy Clean, with my detergent but I decided to go full-strength which on the box said 1 cup. Hot water wash. Put it in with the clothes. Same liquid detergent, no fabric softener. When I took out the laundry, for the first time in months, it smelled clean. No stale, sour odor. Next load, nice smell again. Decided to do one more load with 1 cup Oxy Clean again. I'm still going to switch back to the SA8 (which is by the way highly ranked by Consumer's reports) and dryer sheets.
By the way, a few weeks ago I had to disconect the water discharge line behind the washer. The sludgy goo that was in the line and machine where the two connected was disgusting, but didn't smell bad. I cleaned it out with my finger. Ugh!
So it's now several months later. My clothes smell clean, as does my washer. I switched to powder and only occasionally use liquid softener. Still occasionally use the full dose of Oxyclean with a hot load. I occasionally wipe down the door and seal... especially the bottom of the window, and always leave the door ajar when not in use.
Posted on May 31, 2009
  • 3600 Answers
SOURCE: Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Posted on Sep 10, 2009
Testimonial: "thankyou for the help, I thought I had just made a bad buy. They sent someone out right away and it turns out this particular machine had a bad part."
  • 401 Answers
SOURCE: Kenmore top loading washing machine does not clean clothes well.
I would seriously consider getting a newer machine. A brown stain could be rust, or an oil leak. Either way it probably is not worth putting any money into. If this helps, please rate my answer. Thank you.
Posted on Jan 07, 2010
There is like a black soot substance coming through into my wash, I'm having to wash the clothes again
When it comes to doing laundry, many people use front loaders because they are more efficient than top loaders. On average, they use 40 percent less water and almost 60 percent less energy. They also clean clothes better. They are not without their problems; and so, if you want to avoid problems, you need to know how to clean a front loading washing machine.
Dangers of a Dirty Washing Machine Mold is a common and dangerous problem with front loaders. Mold and mildew, at best, can cause bad odors in the machine and on your clothes. At worst, mold can make you sick. It grows because dirt, lint and water gathers between the seal of the machine's tub and door, thus creating the ideal atmosphere for the breeding of mold, mildew and other bacteria.
The mold creates inhalable spores, and the bacteria create nasty odors. Inhaled toxic mold spores can cause chronic fatigue; dizziness; eye, nose and throat irritation; fever and flu-like symptoms; headaches; learning disabilities; nausea; severe breathing problems and vomiting. Therefore, it is important that you keep your front-loading washing machine clean and that you keep the area between the door and the tub dry when not in use.
How to Clean a Moldy Washing Machine
If you are wondering if your machine is moldy, it probably is. If you smell a musty, sour or stinky odor coming from your washer or your clothing, you probably have an issue. There are a number of possible solutions, and none of them work for every situation.
Some people have had luck getting rid of mold by changing detergent. Some do well by using a mixture of baking soda and vinegar every few loads. Others have had mixed luck with oxygen-free bleach.
One product many people have had success with is the all-natural Smelly Washer Cleaner product. It works with high-efficiency front-loading washers, and because it is made from citrus, it is safe for the environment. It supposedly cleans by getting rid of the odor: not by masking it.
Another product that is supposed to get rid of the odor rather than mask it is Affresh Washer Cleaner for High-Efficiency (HE) Washers. The manufacturer also claims that the product is eco-friendly and safe for septic systems and appliances. It works by releasing oxygenated bubbles that remove residue buildup that causes odors.
To clean your washing machine without commercial products, use the Acidic Cleaner (click here for the recipe) with some sprinkles of baking soda to clean the rubber door gasket. Try using a soft toothbrush, or one of many small brushes you can find to clean in small crevices, and a soft clean cloth to gently but firmly wipe out the gooey mold. Frankly, If washing the gasket does not get rid of the odor and the mold, you may have to replace the gasket.
Also use the Acidic cleaner and baking soda to clean the soap and softener dispenser. If you can remove the soap dispenser tray, do so, then soak it in the vinegar solution with baking soda for ten minutes and wipe it clean. Also use the solution to clean the hole that houses the dispenser tray, if your appliance has one. Rinse all parts well after cleaning to remove the vinegar and baking soda residue. Spraying just the Acidic cleaner over the surfaces will remove the baking soda, and then water will remove the vinegar.
Again, be sure to rinse and dry everything well. In fact, you should dry all the parts of the machine, including the inside of the door, after each and every use to prevent the growth of smelly mold. Just like we advise after taking a shower to dry the tiles and grout right away, or after cleaning kitchen surfaces to let them dry completely, we advise the same treatment for your front loading washing machine. Mold, mildew and germs like moist surfaces. Eliminate the moisture, and there goes the gunk!
Another part of front loader maintenance is filter cleaning. Manufacturers and models vary, so you need to check your manual for your specific instructions. But typically, it involves opening a small door near the bottom at the front of the machine. Inside, you will find two items: a small hose and a debris filter.
The hose drains leftover water out of the washer, so you need something for the water to drain into. Be prepared, because it might be several gallons worth. After you drain the water from the machine, remove the housing for the debris filter by turning it counterclockwise. Once it is out, clear it of lint and other debris. Before reinserting it, reach behind where it was and check the drain pump impeller with your fingers to be sure it is also clear of debris.
After you have cleaned the above items, run a load of hot water with laundry detergent but no laundry. Adding oxygen-free bleach to the detergent will prevent mold. If your system has an integrated cleaning cycle, use that. If you were having odor issues, run another load afterward using hot water with one cup of baking soda and one of white vinegar.
How to Prevent Mold in a Front-loading Washer In addition to the rubber door gasket, you need to clean the soap dispenser and any other part to which you have access frequently. Because front loaders use very little water, not all substances are rinsed away when the tub empties. This can cause a residue buildup.
Let it Dry!
It is good to leave the washer door open after doing a load. This allows the inner parts to dry out. Dry the soap dispenser and the door gasket by hand with a towel. Also, do not leave wet clothes in the machine for very long - especially all night. Any moisture in the machine will eventually cause mold.
Rather than using powdered detergent, use liquid because it dissolves better and leaves less residue. Also, to reduce residue, use as little detergent as you can while still getting a clean wash. Rather than liquid softener, use softener sheets to reduce moisture.
If you always wash in cold water, do an occasional load in hot water. This will clean out some of the residue buildup. Use a low-sudsing detergent designed for a high-efficiency washer. These washers usually have self-cleaning cycles, and you should use the one on your machine periodically.
As with anything, prevention is better than cure. Becoming a little slack in caring for your front loading washing machine can cause many problems later. And if you are no more fortunate than many other people, you may not be able to get rid of your problems once you have them. So if you haven't done so in a while, go take a look at that washer and get ready for action.
Aug 02, 2015 | Washing Machines
After cleaning the refrigerator still has a strong odor. It also grows mold.
put an open box of arm & hammer baking soda on the top shelf that absorbs the odor. The mold is a byproduct of the odor.
Jan 24, 2011 | GE Monogram ZIR36NMRH Refrigerator
The washer emits a foul odor when washer first
You have the beginning of a detergent and/or softener residue buildup on the inside of the plastic outer drum of your clothes washing machine. Mold and bacteria need a moist, dark environment and a food source to grow. This residue is the food source. This can be a major health concern. See: http://www.cbsnews.com/video/watch/?id=5408971n
We can't change the environment of the washer but we can lessen the "food source" by reducing detergent and fabric softener use.
Do an internet search on "Smelly Washer Reviews" to see what you can do about the problem of mold odor in your washer, towels and clothing.
After your washer odor is gone you'll need to change washing habits so mold and bacteria don't return. Go to the blog page at smellywasher.com to read the featured posts on the left side of the page on the cause of the problem and what to do for extreme cases of washer mold odor.
Dec 19, 2009 | Maytag Atlantis MAV6451 Top Load Washer
The rubber seal at the front of the machine has gone mouldy. I have cleaned it before with bleach but the mould comes back all the time
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Oct 21, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Mold on Rubber Seal. Bleach won't kill it. Need to replace
This can happen with any front loading washer, regardless of the manufacturer.
One of the first things to do is make sure you're using the He (High efficiency) laundry detergent and only use a small amount, about 3 tablespoons or less. The trick is to not use so much detergent that you start getting a buildup in your machine. Also, if you have heavily soiled clothes, pre-treat them instead of adding more detergent to your wash cycle. This alone will result in better results.
Also, be certain the washer is properly leveled in all directions and to make some slight changes in your wash day schedule.
By making sure the washer is properly leveled, it will operate better and help minimize odors, as the spin cycle will get more water out, etc.
The other tip, that has really helped in our house, is to do all the hot water (whites) as the last load. Since we do use bleach when we wash our whites, along with hot water, the washer's last load will have had the best sanitizing cycle run through it before being left for the next load another day.
With the bleach and hot water, the washer gets a nice clean disinfecting wash which helps eliminate odors, germs, excessive soap, etc. and leaves the washer fresher. By doing this, we don't have to purchase other (more costs and expense) additives to run through the washer to attack the odor causing germs and gunk.
What good is a more energy efficient washer if I have to always run a special tablet/liquid cleaner in it each week without any laundry in that wash load? Seems wasteful to me to be doing an "extra" wash just to wash the washer. So I'm not a proponent of having to always use another product every week or month to have a washer work like it should.
However, if you've got an existing (smelly/moldy) washer presently, I would recommend that you use a produce called Whirl-Out, which will help dissolve the buildup that your machine currently has and get it clean again. Then you can follow the steps above to keep it from causing you issues in the future.
I hope you find this Very Helpful and best regards!
Sep 21, 2009 | LG WM-2277HW Front Load Washer
Samsung Washer makes the clothes smell like mold
Sep 21, 2009 | Samsung WF337AA Front Load Washer
Last few weeks there is a foul odor coming from the washer
How old of a unit? The new high energy effeciency washers are known for their "odors" due to the fact they dont drain out all water and it can mildew inside. Some solutions...leave door ajar after wash cycles , water will evaporate, there is products you can add every so many loads, one product being "affresh" ,,,some other people will run strong bleach load every so many loads it will kill mildew. These washeres have been out for years in Europe and they have same problems, its just inherent with product
May 21, 2009 | GE WSXH208A Front Load Washer
Removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
Jan 03, 2009 | GE WPGT9360EPL Top Load Washer
Foul water odor after wash
There is always a littlee water left in the sump of a washer after it is emptied. If the washer sits unused for as little as 2 or 3 days it can have that odor. One thing that I do is add about 1/4 cup of ammonia after the washer is full of water. DO NOT USE AMMONIA IF YOU USE BLEACH IN THE SAME WASH!!! IT WILL CAUSE CLORINE GAS TO BE RELEASED!! If bleach was used in the previous cycle it will be ok.
Feb 28, 2008 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Aug 16, 2007 | GE WPGT9360EPL Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
