Question about Brother SE-400 Sewing & Embroidery Machine
The backstitch button on my SE-400 stopped working
It just stays in one place and won't reverse the fabric. HELP!
2 Suggested Answers
SOURCE: My machine won't do a button hole - it doesn't go in reverse unless I pull the fabric. When I do, It completes the button hole
it sounds like the machine needs to be serviced
Posted on May 13, 2012
Does my Brother SQ9185 sew backwards other than the push button backstitch?
Use the reverse button. That's what it is for. Sew forward and then push the button and sew in reverse.
Machine Darning Jeans Shirt
If you have a darning foot, you can use it (drop the feed dogs) and then you manually move the fabric around while stitching.
Learn How To Mend Clothes with Machine Darning
Oct 01, 2016 | Brother Sewing Machines
How do I reverse stitch or backstitch?
Consult your owner's manual. Unless you have a very old machine, there is usually a reverse button. On really old machines, the sewist would have to lift the presser foot while the needle is still down in the fabric, and then the fabric is swiveled 180 degrees. On some machines, it is the stitch length selector lever. On others, it is an arrow.
Nov 09, 2015 | Sewing Machines
Why is the fabric feeder pushing the fabric toward me instead of awayfrom me?
It is sewing in reverse. Shut down, restart the machine. If this doesn't help, press the backstitch button, and see if it stuck. Try changing the stitch length dial.
If this is an electronic machine, it may need to be serviced. This happened to a embroidery machine I had, when I tried to sew straight stitching. It needed to be service as it was an electronic issue.
Oct 27, 2014 | Sewing Machines
How did you do backstitch on a diagonal when you don't have a defiant hole to go into on Aida cloth for cross stitch
If i understand your question correctly, i go into the exact middle of the square (between the 4 holes) when the line i need to backstitch doesn't line up with holes. The way the fabric is woven it usually works pretty well, with there being an exact center.
Sep 12, 2014 | Sewing Machines
How do I back stitch
You push on the backstitch button. It's the button that looks like an upside down U. If all it does is take a few tiny stitches back then stops...you need to look at the screen...to the upper right you will see the upside down U and a scissors. make sure both of these are not selected. If one or both have a dark background...touch them and the background turns white/clear. Once they are unselected...you can backstitch at the same speed as going forward.
Jun 19, 2014 | Brother SE-270D Computerized Sewing...
I have an Elna Elnita air electronic and cannot figure out how to backstitch. I have always owned Elna Su air electronics but this little machine I can't figure out the backstitch
Unless there is a specific button to do reverse stitching, you could try pressing the foot peddle 'backwards' .. in other words, press with your heel rather than your toe. Some foot peddles are configured this way.
Apr 09, 2014 | Elna Sewing Machines
I have a Husqvarna Opal 650 machine that was just purchase in July. I am hired to sew headbands, and we use Coats Transparent polyester thread. It's worked perfectly, until last Saturday it suddenly...
change the needle again, the needle could have a burr
check for burrs in the needle plate area and in the bobbin area
is the needle the right one for the fabric being sewed? was the needle inserted correctly into the needle holder?
is the tension correct for the fabric being sewed?
Oct 14, 2013 | Sewing Machines
Singer 4423 stuck on backstitch!
Is sewing machine set for buttonhole making? Sounds like it got "confused" in the process of a buttonhole revolution making a reverse stitch, and so you need to change adjustment settings top left, bottom right, remove extension table and turn feed dogs switch back left of machine to UP position.
Did this help?
Jimmy
Dec 13, 2011 | Singer 4423 Sewing Machine
Hello. I hope u can help me. I cannot get my stitching tight? If I pull the thread it comes right out. Thanks Jodie
You need to backstitch over the beginning and end of your stitching, Jodie. When you start out, manually turn the wheel to put the needle into the fabric. Push the foot pedal to stitch forward a little. Now, reverse over those stitches to nearly where you started stitching. Use the foot pedal to go forward again, stitch to where you want to end. Reverse again, just a 1/4 inch or so. Then take the fabric out and cut your stitching.
This backstitching keeps your thread from pulling straight out. You should always use it with straight stitches and general zigzag stitches. Don't use it with decorative or embroidery stitches, though, as it mars the appearance of them. But if you're doing any type of topstitching that uses straight stitches, backstitch in the area that will be in the seam allowance, ever so slightly, or your top stitching will pull out, too.
Hope that helps!
May 19, 2011 | Kenmore 16622 Mechanical Sewing Machine
Brother SE-400 Sewing & Embroidery Machine Logo
56 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
