BDP-S1100 vs hl 6163w
Sony BDP-S1100 not displaying at any resolution in HDMI port. Cycled Power, Checked Cables, etc. Sony title screen comes up, the goes black before settings menu pops up. Help?
  • 275 Answers
SOURCE: RCA 36" making loud pop then screen goes black
It seems that there is EHT Leakage from the EHT Transformer Anode Cap! Generally happens during rainy seasons, or if your TV is placed near a window or near an AC, due to excess of moisture in the air. Unplug the TV and wait for an hour to discharge all residual charge in Capacitors. Open the back, and look for a thick red cable leading from the FBT. (It is a Black Block with a thick red cable running from it to the rear of the Picture Tube). Take a sturdy Electrical cable with the conductor visible at both ends. (Multimeter Leads will do.) Now, ground one end of this lead to any Metal part of the Chassis, and gently ease the other end under the Cap of the EHT Cable. BE VERY CAREFUL, as there are very High Voltages involved! Do it Gently, and you will hear a POP! This indicates that the Electrical Charge inside tha Picture has been discharged. Now Take dry cloth and wipe clean the area around the Anode Cap. Close the back of the TV, and switch it ON. In all likelihood your problem should be resolved. BUT, I REPEAT, DO NOT DO THIS UNLESS YOU KNOW WHAT YOU ARE DOING, AND ARE VERY VERY CAREFUL. Otherwise, seek professional help!
Posted on Aug 22, 2006
SOURCE: persistent menu on screen pop ups
I just had a similar problem, and it turned out that one of the little rubber buttons was pushed down and had gotten stuck under the plastic housing just enough to create contact, but hardly enough to notice at first glance.
Posted on Jun 08, 2007
  • 8 Answers
SOURCE: 32" Sony Wega -- initial set-up menu constantly on
While washing the screen of the tv some cleaner may have got to the buttons and casused some corrosion try pushing the buttons a few times at the front of the tv this usually works if not you need to have one of the buttons replaced..
Posted on Dec 02, 2007
HDTV GURU
  • 261 Answers
SOURCE: Sony Bravia KDL52XBR5 picture blanks out using HDMI port
I think this has to do with the cable box not liking the encryption thing going on with the sony tv. The cable boxes probably don't understand it fully and therefore you have intermittant problems. I would just use component inputs. Which are analog and no encryption problems. I hope this was helpful. I bet it doesn't happen using a sony DVD Player or a blue ray DVD Player either. Sony, Sony, Sony.....Good stuff...but they have their moments. Let me know if u come up with a fix for this and then i will post it on my fix it list.. Thank you again..GURU JAY
Posted on Feb 08, 2008
De Engineer
  • 247 Answers
SOURCE: Sony 46 inch XBR3
Since you have a lit power light, you are getting AC power.
Your set either has a blown internal fuse (or circuit breaker) or a power supply problem. If you can reset its breaker or replace its fuse, you may be able to fix it yourself. If not you need professional service.
Good luck! :)
Posted on Mar 09, 2008
Emerson LCD TV Model LD190EM1 Sony Blu-Ray Disc Player, Model BDP-S3100, The TV screen gives an error reading "Format not supported" when I connected it using either HDMI connection.
This HDTV is rated display signals up to and including 720P resolution according to the spec linked below. If you are outputting a 1080i or 1080P signal from your BD Player, this could be the cause for the error message. Many HDTVs will accept signals higher than they can display - and simply down-rez to the highest resolution that they can display.
Connect the BD Player to a device that can display the signal. Enter the player's setting and change the output to 720P. Shut it off / disconnect cables as needed and reconnect it to the Emerson HDTV and see if it will display properly.
If it does, you're all done! if it doesn't - there's something else going on that isn't readily apparent to me. Good luck!
Emerson LD190EM1 Specs CNET
Mar 03, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
Sony BDB S1100 not connecting to Toshiba TV
Use a good HDMI lead and make sure you select the correct input on the TV.
Feb 19, 2014 | Sony BDP-S1100 Blu-ray Disc Player - 1080p...
I recently bought a Sony Blu-Ray BDP-S370. The issue I have is that it will not play any DVD's on my Samsung HD TV The message "Mode not supported keeps coming up" Thanks
When you see "Mode Not Supported," hold down the "stop" button on the Bluray player for about 15 seconds and release it. This should reset the player to the lowest resolution over HDMI.
Check other Bluray player settings such as deep color, resolution etc. for conflicts.
Mar 14, 2011 | Sony BDP-S350 Blu-Ray Player
Just bought the sony bdp s350, bought the cable
What type of TV? Plasma / LED / LCD.. ?
Typically you should run through your HDMI ... most of the 5 RGB etc.. in the back can only be used on one of the inputs only for high def... HDMI is easier but more expensive cables..
May 12, 2010 | Sony BDP-S300 Blu-Ray Disc Player
I am trying to hook up a Sony BDP-S360 via HDMI
I don't know what kind of TV you have, but on some TVs the HDMI inputs have to be enabled via the TV setup menu. Try looking at the setup status.
Dec 27, 2009 | Sony BDP-S360 DVD Player
I have sony bdp s300 tonight it began intermittent loss of HDMI signal. It comes and goes. Not the cable, just upgraded to the most recent software. No damage to the HDMI port. This one has me beat.
What brand of tv do you have?? Also what resolution does it display? 1080i, 720p,480i or 420p?some DVD's only use certain ones. U gotta make sure your TV can display the resolution from the DVD.
Jun 28, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
May 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
BLue ray DVD player
I am not sure about the Sony BDP-S300 Blu-Ray Disc Player: But the Samsung BD-P1000 Blu-Ray Disc Player requires HDMI cable
to give the best resolution (1080p) possible that the TV set is able
to support. Hope this helps.
redthroat@hotmail.com
Nov 27, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
