Question about Minolta Office Equipment & Supplies
Minolta di550 error code c-13fc - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,680 Answers
Image processing board or the Print head ( What houses the LASER inside the machine they are not talking to each other so that code is displayed. Check the connections , I would go with print head 1st. Di550 is a legacy Minolta machine, might be tuff finding a print head as for Image control board WOW! Home and close front door resets if it comes back need above
Posted on Jan 22, 2015
SOURCE: C13F5 error
There is a small IC board under a cover in the optical secsion near the scanner, open the cover and change that small board, its called IC something, If ya need further info let me know, Ill look up the part #
Posted on Feb 20, 2008
  • 11 Answers
SOURCE: Minolta Copier
  • STARTAER get low
Posted on May 07, 2008
sir fixalot
  • 146 Answers
SOURCE: error c12co in minolta di550
C12CX (X is any value)
1. Run “Hard Disk Format” selected in the following sequence: Tech. Rep. Mode - Function - Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
To enter Tech Rep Mode:
1. Press the Utility key.
2. Touch Meter Count.
3. Press the following keys in this order: Stop - 0 - 0 - Stop - 0 - 1.
4. Select Tech. Rep. Mode.
Posted on Nov 11, 2008
  • 990 Answers
SOURCE: Minolta Di550 error code C-0500
Dear sir; the error code you post out,I check the manual it said "low fuser temp" my suggestion go to check the fuser lamp inside the fuser roller of the heating unit, you may try to reset before you go for it; the easy way just open and close the lower front door,just try it and let me know the resolve. HAVE A HAPPY HOLIDAY !!!
Posted on Dec 17, 2008
  • 990 Answers
SOURCE: i have a Minolta Di550
already solved
Error Code c0045
Bop. Error Code c0045. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.officeimagingsystems.com/id169.html
Konica Minolta Di450 Error Codes
http://www.biz.konicaminolta.com/download/users-guide/c554e_c454e_c364e_c284e_c224e/en/contents/id16-_101076518.html
Aug 25, 2016 | Konica Minolta Minolta Di450 Di470 Di550...
Erace the c-of24 on di450
The code refers to a sensor that looks at the drum - it might be dirty or something else is going on check this Fixya-link: Minolta DI450 error code C0F24
Jan 17, 2015 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta DI450 error code C-0920
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw.
Dec 26, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Error c-11a4
Subject C-11A4 code occurs after updating the flash ROMCause: The Flash card to update the firmware was applied to the wrong board
found on kmbs site ssd
Jul 31, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
How can i fix the error code C0990 on minolta di550
Main Tray lifting motor Your large capacity draw. Require knowledge of the draw lift system recommend. have a tech look at it
Jul 10, 2013 | Minolta Di3010 Copier
Of 24 error
Cof 024 - AIDC sensor contamination correction failure.The photosensore LED located under OPC drum of the AIDC sensor dirty.Clean the sensor,reset the malfunction code if the necessary perform F5 AIDC auto adjustment.
Mar 06, 2013 | Minolta Di550 B&W Laser Printer
Minolta Di550 Copier with a malfunction code of C-OF24
Hello sir; here have few steps need to follow;
1, press "function", press "printer", "F8" press "start" machine will run about 4 minutes the start key will turn from orange to green.
2, same procedure go to F5 will run about 30 seconds.
Jan 08, 2009 | Minolta EP1030/1030F CS/PRO Copier
"to test stapler, press staple button" ... Minolta di550 with FN-105 ... HELP !!!
First make sure that you do not have the collate and staple option checked on the printer menuing system or in the print setup on one of the local machines printing to it. Ensure that when auto-staple is not used that the error stops manifesting.
Then, I would check to make sure that you are installing the correct staples, length and width for the model.
Jan 23, 2007 | Minolta Di550 B&W Laser Printer
78 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
