Question about Dishwashers
Maytag MDB5130AWB dishwasher
Door leaks at startup
4 Suggested Answers
SOURCE: maytag dishwasher mdb5000awa leaking
replace lower arm.
Posted on Jan 08, 2008
futureloginn
  • 734 Answers
SOURCE: Brand new dishwasher installed and water leaks out bottom of door
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Posted on Dec 12, 2008
heatman101
  • 43501 Answers
SOURCE: maytag jetqueen door leak
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dfg
Posted on Sep 29, 2010
Maytag jetqueen door leak
Leaking Dishwasher
heatman101
dfg
Jul 06, 2010 | Maytag MDB9600A Jetclean II Built-in...
Door leaking on maytag dishwasher model DWU82600AAX
Most likely the door got bent out of shape which appears to be common with Maytags. if you can determine which side is leaking bend the door in the opposite direction and it should correct the problem. Worked for us. If not then the liner on the door is most likely damaged.
Nov 26, 2009 | Maytag MDB7100AWB Dishwasher
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
My Maytag washer leaks at the door. It doesn't
f you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Rate the solution..
Jul 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher leaks, is there a recall on this model,mdb7100awb
if the dishwasher is leaking water there is no recall on that. the recall i believe you are talking about would be for the rinse aide leaking in the door. you should contact maytag to see about getting the new kit installed on your dishwasher and you may get your leak fixed for free since the kit comes with the door seal.
You can contact maytag at (800) 675-0535 do not wait and do not use the dishwasher. you will need the model number and serial number off your machine when you call. it is located near the door seal on the tub.
Jan 03, 2009 | Maytag MDB7100AWB Dishwasher
Maytag dishwasher mdb5000awa leaking
Well did you check to see if the door seal is ripped or not on tight??? The door seal is the rubber strip that is used to seal the door shut tight, if this is wrecked in any way that might the the answer to your solution?
Dec 20, 2007 | Dishwashers
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
