Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
I need a source for KTE 3089B switch for a ceiling fan
What 3-speed fan switches are compatible with KTE 3089B?
Sorry we have no means to look that up here at this website.
Jun 20, 2017 | Dryers
Need a KTE 3A-250VAC ceiling fan pull switch wiring diagram for a 3 speed Harbor Breeze fan UL model HST52-II
They are all wired the same, just go for color for color when changing the switch. It can be a testing job to release the old wires and installing them into the new one. Not much room.
May 28, 2017 | Dryers
My ceiling fan, model, 5745, has a broken switch. yellow wire-1 violet-2 black-3 orange-L Where can I get a new switch?
I tried the Home depot stores and Lowes Stores solutions years ago and found out the switches are too different to work everytime.
If anyone needs switches or capacitors for ceiling fans that are hard to find, I can help. I have a source for them, I also have photos for the wiring color codes for the Shine top 102 nascarnbroncosfans@msn.com
Mar 29, 2010 | Aloha Housewares (93645) Ceiling Fan
I can't find a replacement fan 3 speed switch for my ceiling fan Hampton Bay Model 92427
Hi azwaverid!
I just had a similar problem with my ceiling fan, not sure if I have the same model as you (the fan was in the house when I bought it). I do have the exact same pull chain switch (K.T.E 2035080).
I went to a big home improvement store and the salesman gave me some 3-way switch and guaranteed it would work. The switch had only 3 wires, not 4 like the original. Can you guess what happened next? That's right, their part didn't work.
Being an engineer, I could not admit defeat. I consulted with other engineers I work with, and they pointed me to a "mom & pop" electronics store close to my house. I went to Centennial Electronics in Colorado Springs, CO. The sales staff didn't have experience with this problem, but at least helped me and offered suggestions.
I ended up buying a Philmore Pull Chain Switch for $2.51 after tax. This worked perfect! Just be sure to place the wires in the right slots. On my fan, the following positions and wire colors were: L - Orange, 1 - Yellow, 2 - Purple, and 3 - Blue (I just matched them up the same as the K.T.E. switch colors & positions).
Hope this helps!
Bob
P.s. The exact part I used was:
Philmore No. 30-9152 (UPC code: 0 38975 39152 6). The box says (everywhere you see a semi-colon is a line break): Philmore PULL CHAIN SWITCH; L-1-2-3, L-2-3, L-1-3, L-1-2, PUSH-IN TERMINAL; 6A-125V AC, 3A-250V AC; Made in Taiwan No. 30-9152; LKG Industries - Rockford, IL
Oct 28, 2009 | Oasis Hunter 54' Ceiling Fan
Power supply pull switch is broken
Just about any hardware store will have a replacement switch for your fan.They are a standard piece of equipment.You don't mention if it is the switch that controls the light,or the one that controls the fan.The light switch is a simple on off switch.The fan switch could be a simple on off switch or could have variable speeds.It may have an off position,and may not.You can tell if it is variable speed or not by looking at it.It will have more than two leads.You can decide for your self if you want an off position or not.For instance if you want to turn the fan off,and on from a wall switch you may not want an off position on the fans pull chain.
Jun 05, 2009 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
Ceiling fan wiring Aloha ceiling Fan Model # 29079
I have an Aloha Breeze L-Style 52" Ceiling Fan(Polished Brass), Model # 29079 Bought From Wal-Mart about 1 1/2 years ago and the fan speed switch busted and the capacitor melted. I have a new switch but can't find a new capacitor because I can't read the spec info. Looking for a place to obtain the correct capacitor for this fan so I can make necessary repairs!
May 04, 2009 | Aloha Housewares (93645) Ceiling Fan
Installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Nov 17, 2007 | Dryers
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
64 people viewed this question
Top Westwind Dryers Experts
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
