Question about HP LaserJet 4345mfp Printer
Output device failure code 66.12.33
Output device failure code problem
My 2005 Lincoln navigator has a new compressor and it lifts up but I must restart it to get it to lift. could you please tell me why
Have to restart what ? Vehicle ? Did you have the system check for code's ?
The four wheel air suspension system is comprised of the following components:
  • Service switch
  • Control module
  • Two front height sensors
  • One rear height sensor
  • Compressor and drier assembly (includes vent solenoid)
  • Air lines
  • Front and rear air spring and shock absorber assemblies
  • Four air spring solenoids
  • Compressor relay
  • Vehicle Dynamic Module (VDM) Diagnostic Trouble Code (DTC) Index NOTE: Repair all other DTCs before C1725 and C1726. Repair DTCs C1990 and C1991 last. DTCs Description Source Action B1317 Battery voltage high VDM Go To Pinpoint Test C . B1318 Battery voltage low VDM Go To Pinpoint Test C . B1342 ECU is defective VDM INSTALL a new VDM. REFER to Air Suspension Control Module in this section. SET the ride height. REFER to Ride Height Adjustments in this section. CARRY OUT the pneumatic test. TEST the system for normal operation. B2477 VAPS II steering assist curve not complete VDM REFER to Section 211-00 . C1445 Vehicle speed signal circuit failure VDM GO to Symptom Chart . C1724 Air suspension height sensor power circuit failure VDM Go To Pinpoint Test D . C1725 Air suspension front pneumatic failure VDM Go To Pinpoint Test E . C1726 Air suspension rear pneumatic failure VDM Go To Pinpoint Test E . C1760 Air suspension rear height sensor signal circuit failure VDM Go To Pinpoint Test F . C1770 Air suspension vent solenoid output circuit failure VDM Go To Pinpoint Test G . C1790 Air suspension LR air spring/shock solenoid output circuit failure VDM Go To Pinpoint Test H . C1795 Air suspension RR air spring/shock solenoid output circuit failure VDM Go To Pinpoint Test H . C1830 Air suspension compressor relay circuit failure VDM Go To Pinpoint Test I . C1840 Air suspension disable switch circuit failure VDM Go To Pinpoint Test J . C1873 Air suspension RF air spring solenoid output circuit failure VDM Go To Pinpoint Test H . C1877 Air suspension LF air spring solenoid output circuit failure VDM Go To Pinpoint Test H . C1881 Air suspension RF height sensor circuit failure VDM Go To Pinpoint Test F . C1889 Air suspension LF height sensor circuit failure VDM Go To Pinpoint Test F . C1897 Steering VAPS circuit loop failure VDM REFER to Section 211-00 . C1964 Air suspension compressor actual run time exceeded allowed run time VDM Allow the air compressor to cool down. CLEAR the DTC. REPEAT the self-test. C1990 New control module initialization (requires ride height calibration and pneumatic test pass) VDM REFER to "Clearing DTC C1990 or C1991". C1991 Plant ride height setting and/or tests incomplete VDM REFER to "Clearing DTC C1990 or C1991".
May 23, 2018 | Lincoln Cars & Trucks
Tip
Mack Fault Codes List
FAULT CODE IDENTIFICATION TABLE - VMACIII - 1998 & NEWER
1-1 Engine Oil Pressure Sensor
1-2 Barometric Pressure Sensor
1-3 Fuel Temperature Sensor
1-4 Ambient Air Temp Sensor
1-6 Starter Input
1-7 Engine Coolant Level
1-8 (ASET CEGR) Estimated % Fan Speed
1-10 Aux. Cooling Relay Output
2-1 Engine Coolant Temp Sensor
2-2 (ASET IEGR) Boost Air Pressure Sensor
2-2 (ASET CEGR) Boost Air Pressure
2-3 Intake Air Temp Sensor
2-4 Trans Oil Temp Sensor
2-5 Front Drive Axle Oil Temp Sensor
2-6 Rear Drive Axle Oil Temp Sensor
2-7 Engine Oil Temp Sensor
2-8 (ASET CEGR) Combustion Air Temperature
2-9 (ASET CEGR) Combustion Air Temp Sensor
3-1 Exhaust Temperature Sensor
3-2 Engine Speed Sensor
3-3 Redundant Engine Speed
3-4 Engine Position Sensor
3-5 Engine Brake Output #1
3-6 Engine Brake Output #2
3-8 Trans Splitter Position
3-10 (ASET CEGR) Engine Brake Output #3
4-1 Vehicle Speed Sensor (VSS)
4-2 Fan Clutch Output
4-3 Auxiliary Output #1
4-4 Auxiliary Output #2
4-5 (ASET IEGR) Wastegate Output
4-5 (ASET CEGR) VTG Position Sensor
4-6 Tachometer Output
4-7 Speedometer Output
4-8 Customer Defined Statement
4-9 (ASET CEGR) EGR Valve Mechanism
5-1 Throttle Position Sensor
5-2 Throttle Position Sensor Reference Voltage
5-3 Engine Shutdown Lamp/Alarm
5-5 Electronic Malfunction Lamp
5-6 Spare Relay #3
5-7 Engine Oil Level
5-8 (ASET CEGR) EGR Temperature
5-9 (ASET CEGR) EGR Mass Flow
6-1 Fuel Level
6-2 (ASET CEGR) Turbocharger Speed
6-3 J1708/J1587 Link
6-4 J1939 Link
6-5 All Communication Lost - Engine Shutdown
6-6 Fuel Control Module
6-7 Power Relay
6-8 J1939 Link
6-9 Other ECU Affecting Operation
7-1 Service Brake Switch
7-2 Parking Brake Switch
7-3 Speed Control SET Switch
7-4 Speed Control RESUME Switch
7-5 Battery / Alternator Voltage
7-6 Switched Voltage
7-7 Exhaust Temp Reference
7-9 VTG Actuator
8-1 Electronic Unit Pump #1
8-2 Electronic Unit Pump #2
8-3 Electronic Unit Pump #3
8-4 Electronic Unit Pump #4
8-5 Electronic Unit Pump #5
8-6 Electronic Unit Pump #6
8-9 Solenoid Boost Voltage
9-1 Transport Protocol
9-2 Power Reset Without Key Switch
9-3 (ASET CEGR) Aftercooler Outlet Temperature
9-5 (ASET CEGR) Compressor Discharge Temp
9-8 (ASET CEGR) Auxiliary Output Device #1
9-9 (ASET CEGR) Auxiliary Output Device #2
9-10 (ASET CEGR) Auxiliary Output Device #3
10-1 (ASET CEGR) Internal Sensor Voltage
10-2 (ASET CEGR) 5 Bolt Supply
10-3 (ASET CEGR) Sensor Supply Voltage #1
10-4 (ASET CEGR) Sensor Supply Voltage #2
10-5 (ASET CEGR) Fuel Filter Differential Pressure
10-6 (ASET CEGR) Fuel Delivery Pressure
10-7 (ASET CEGR) Odometer Save Area Failure
10-8 (ASET CEGR) GPS Position Data Not Received
10-9 (ASET CEGR) Watchdog Timer Reset
source
on Dec 20, 2016 | Cars & Trucks
Tip
?JCB FAULT CODES LIST
P0087 (flashing code 227) shared sump low pressure fault (for pump without pressure supply)
The main fault symptoms
• Engine severe vibration.
• idling unstable
• Output Fall
• exhaust smoke
• It may be too large output
P0088 (flashing code 118) shared the tank pressure is abnormally high (first or second stage)
• idle instability
• Output Fall
• channeling gas engine failure
• exhaust smoke
P0089 (flashing code 151) shared the tank pressure failure (for pump pressure supply is too large)
• idle instability
• Output Fall
• exhaust smoke
P0090 (flashing code 247) SCV drive system open, + B short circuit or shorted to ground
• Depending on the open / short situations, there may be an engine stall and / or launch
Machine channeling gas.
• exhaust smoke
• Output is too large
P0107 (flashing code 71) atmospheric pressure sensor circuit input low (open or shorted to ground)
Due to spare the equivalent altitude 2000 m (6562 ft)
• exhaust smoke at high altitude.
• insufficient output at low altitude
P0108 (flashing code 71) atmospheric pressure sensor circuit input high (+ 5V shorted)
• The high altitude exhaust smoke
• lack of low altitude output
P0112 (flashing code 22) intake air temperature sensor fault (low voltage fault, earth fault, short circuit)
• When cold starting, may exhaust white smoke.
More here http://truckmanual.weebly.com/jcb-fault-codes.html
2001 chrysler town and country. A\C heat Blowers will not work when controlled my front main pannel. It is a auto temp controlled system. The rear blower will work but no heat when controlled by the rear...
This may be similar to what I just fixed on an '00 dodge:
http://www.dodgeintrepid.net/showthread.php?t=89711
Accessing the Integrated Diagnostic System:
Procedure for Automatic Temp Control (ATC) equipped vehicles:
With the engine ON and the vehicle stopped set the temp to 75*F. Next hold down the Floor, Mix and Defrost buttons until the ATC display begins to flash. While the display is flashing, the system will run it's tests and calibrations.
When the display stops flashing, the tests and calibrations are complete.
The ATC display can only display one error code at a time. Any stored codes can be scrolled through by pressing the Panel mode button once for each code. DO NOT press any other button or you will have to start the test over. Note the codes and refer to the list below to determine what system is malfunctioning.
List of Climate Control DTCs:
23: Blend door actuator feedback failure (bad servo)
24: Mode door actuator feedback failure (bad servo)
25: Ambient temp sensor failure
26: ATC In Car thermister failure (ATC only, bad ATC head or ATC head disconnected while battery is connected)
27: ATC in car sensor failure (ATC only)
31: Recirculation door actuator stalled (stuck door or bad servo)
32: Blend door actuator stall failure (stuck door or bad servo)
33: Mode door actuator stall failure (stuck door or bad servo)
34: Engine temperature message not received (ATC only, bad ATC head or bus failure)
35: Evaporator sensor failure
36: ATC control communication failure (bad ATC head or bus failure)
37: Blend door actuator output shorted to battery (bad servo or wiring fault)
38: Blend door actuator output shorted to ground (bad servo or wiring fault)
39: Mode door actuator output shorted to battery (bad servo or wiring fault)
40: Mode door actuator output shorted to ground (bad servo or wiring fault)
41: Recirculation door actuator output shorted to battery (bad servo or wiring fault)
42: Recirculation door actuator output shorted to ground (bad servo or wiring fault)
43: Common door shorted to battery (probable wiring fault, could be a servo that failed in an odd manner)
44: Common door shorted to ground (probable wiring fault, could be a servo that failed in an odd manner)
45: A/C control blend door input open or shorted with respect to ground (MTC only, wiring fault or bad servo)
46: A/C control blend door shorted to battery (MTC only, wiring fault or bad servo)
47: A/C switch failure (MTC only)
48: A/C control mode door input shorted to ground (MTC only, wiring fault or bad servo)
49: A/C control mode door input shorted to battery (MTC only, wiring fault or bad servo)
50: A/C control electric backlite (EBL) switch fails (MTC only)
51: System voltage too low for calibration!!! (check battery cables, battery and alternator!)
Dec 10, 2014 | 2001 Chrysler Town & Country
What does fault code 13 mean on a 91 acclaim
Code 13 indicates a failure of the vacuum or pneumatic failure which prevents the MAP output from changing. This referring to the MAP sensor
Oct 18, 2014 | Cars & Trucks
Been reading posts regarding xbox 360 with yellow led on psu, i been given a one but got no controller, hard drive or memory card. It powers up but after about 5 seconds goes to displaying 3 red circle of...
The 3 red rings are an error code.
This means there is a general hardware failure within the device.
Typically this means the device has overheated and parts on the inside are literally 'melted'.
You can service the Xbox, but it's cheaper to actually purchase a new one.
Apr 16, 2011 | Microsoft Xbox 360 Console
My Dell Inspirion Mini 10 is beeping 8 times when I turn it on. Nothing on the screen.
Try holding Fn + End with battery and power cord out and while still pressing Fn + End plug only power cable back in and try to power on.
Oct 12, 2010 | Computers & Internet
Need to know what these codes mean for hyundai accent P1529, P1404, P0722
P1529- TCM MIL request signal failure
P1404- DTML Heater circuit failure
P0722- ATM Output speed sensor no signal
All these together indicate a possibly cut wiring harness failure, or other major circuit issue.
Apr 23, 2010 | 2002 Hyundai Accent
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
Tv trouble shooting
whenever any fusible resistance fails means there is a short ckt in tv. failure is mainly due to main filter cap or rectifire diode os switching ckt failure(here as you cleared str.) remember while servicing power supply isolate hor. section for safety purpose.& connect it only after power supply output is ok &after checking parts in hor. ouyput section. if this seems to be ok then go for hor.output ckt failure like hor output,flyback transformer & cap& diodes connected with it.
Oct 02, 2007 | Televison & Video
HP LaserJet 4345mfp Printer Logo
78 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
