Question about HP LaserJet 4345mfp Printer
Error code 66.12.33
External output device failure code 66.12.33
Sound is too low even tough the levels are to the max I wounder if a software could influence the sound ??
What are you using for speakers? Most sound cards/chips have limited power output. Most speakers that attach to desktops are externally powered to provide a greater sound level. Laptop speakers are small and designed for the power that the integrated sound chip can produce. If you attach unamplified external speakers to these devices, over time you will damage the output drivers on these chips, causing loss of sound level and eventual failure.
Feb 15, 2016 | Microsoft Windows 7 Home Premium 64BIT...
Tip
Beep Codes (Different BIOS) " What they mean "
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
IBM POST Diagnostic Code Descriptions
Code Description
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Colour/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Colour/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
on Dec 30, 2009 | Computers & Internet
How to fix error code 150-3039 on wiiu
Error Code: 150-3039 means there is a problem with with your external storage device. It is most common when you are using an external hard drive that does not have a separate dedicated power supply. It either isn't getting enough power or the hard drive has other problems. Try powering off your Wii U, disconnecting your external HDD, and running the system without the drive. It should work. Then power off and reconnect your external drive. If you receive the error message again then you should look into getting new external storage. This link lists Nintendo approved devices: http://en-americas-support.nintendo.com/app/answers/detail/a_id/1359/~/what-external-storage-devices-can-be-used-with-wii-u%3F
May 05, 2014 | Video Game Consoles & Games
Suddenly, my 500GB Seagate external hard drive couldn't mount on my iMac. It was working fine till yesterday. I connected them to the Mac USD port, and the light in the seagate is blinking... Any
I can only comment generically:
I would try to uninstall the drive on the OS. Then re-start the computer. After the re-start, connect the drive and see if the drive re-installs itself.
If the error persists, then the drive is indicating failure. To absolutely verify if it has failed, take the drive to a store where there are MAC computers and try the drive on one of their computers to see if it works.
A continuous flashing LED on most devices where the LED does not normally continuously flash is an indication of a failure of the device. Some devices will flash an error code when designed to do so, and if possible.
Jerry G.
Aug 14, 2012 | Apple iMac 17" Desktop
Cant get hdmi to work
What device are you connecting to the TV? Are you using an HDMI to HDMI cable or a DVI to HDMI cable (or another adapter in the cable or between the cables)?
Try using a different cable. Try connecting the source device to another TV. Basically, you want to see whether the TV's HDMI input is bad, the device output is not active, or if the cable is bad (or an adapter attached to the cable is bad). Adapters are likely failure points. If you are using a DVI to HDMI cable, check your cable and device specs. Single-link and dual-link DVI are different and not interchangeable when attached to an HDMI cable end.
I hope this helps.
(some computers (esp. laptops) will have external video ports turned off by default and you need to turn them on before you try to send the output to an external monitor (TV).)
Apr 17, 2010 | Televison & Video
Error message
this mean that the player didn't recognized any external device connected to it.Check the external device setting.
Jun 18, 2009 | Televison & Video
4 beeps 2373 laptop
Code Description
Code Description
200 - 299 Memory
300 - 399 Keyboard
AMI BIOS Beep Codes
Code Description
Code Description
2-_-_ Faulty Memory
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
I recently changed my fat 32 external drive to NTFS and while converting the external drive got disconnected because of a power failure in the house so now when i try to connect to the external drive it...
Ideally youll need to take the external device apart and installed the actuall hard drive into your machine, that will eliminate if its the actual drive or the external housing...
Let me know...
Matt
Jan 21, 2009 | Computers & Internet
Printer is displaying 65.12 error
There is no 65.xx error code
the following code should help you.
66.00.15 EXTERNAL DEVICE FAILURE
Description
The stacker or stapler/stacker was removed and then replaced with the printer power was on.
Action
1. Turn the printer power off.
2. Make sure that the accessory is properly seated on and connected to the printer, without any gaps between the printer and the accessory. If the accessory uses cables, disconnect and reconnect them.
3. Turn the printer power on.
4. If the error reappears, record the message, and contact HP Customer Support.
Oct 29, 2008 | HP LaserJet 4350 Printer
Toshiba DVD-RW Error
Are you trying to burn from a specific program? From the looks of the error I would suspect Adobe Premier. Do you know which Operating System you use (Vista, XP)?
Sep 10, 2008 | Computers & Internet
HP LaserJet 4345mfp Printer Logo
111 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
