Question about Black & Decker Tools & Hardware - Others
Unable to get Pop brand 2000 staple gun to work
Unable to get it to staple have tried all settings not sure if staples are loaded correctly. do not have directions
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
SOURCE: LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Posted on Dec 07, 2008
  • 384 Answers
SOURCE: How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Posted on Jul 07, 2009
tbirdfan1
  • 3051 Answers
SOURCE: reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
Posted on Oct 03, 2009
SOURCE: stanley sharp shooter tr110 staple
Are you loading it correctly? It took me awhile to figure it out myself. When you pull the clip out I was convinced you have to load them in there above where that black spring is on the slide lock that you pull out (as they seem to fit there) but no, you do have to turn it upside down to where the place where the staples shoot out is facing you and then load the staples into that space that you now see in front of you by placing the staples in upside down (pointy ends facing you). Then just slide the slide lock back over the staples you just placed in. I had to push down and then up on the clip to lock mine in all the way but some might lock in on their own (not sure). It should work fine from there.
Posted on Nov 14, 2011
Stapler will staple ok then it will jamb and break staple in half,and driver will stick but you can put driver back and will run for a short time then has same problem. It also is breaking up staples as it...
It sounds like the gun is working properly but is having feeding problems. First, make sure you are using the proper staples for your gun. Senco makes three versions of the SKS(XP) stapler: The SKS L11-17 drives 18 gauge, 1/4" staples. The SKS M12-17 drives 18 gauge, 3/8" staples. The SKS N12-17 drives 16 guage, 7/16" staples. None of them use staples over 1 1/2" long and each gun will only shoot the staples it is set up for. If you are using the correct staples make sure the rail and nose peices are clean and the feeder shoe and staples are riding freely on the rail and the feeder spring holds them firmly forward in the gun. Lastly check the tip of the driver to make sure it is square, it should not be rounded or have any chips out of it.
Dec 07, 2010 | Senco SKS 18 Gauge Stapler
I'm stumped -- I just bought a Stanley Heavy Duty TRA700. I took the "safety" off (the wire loop that holds the handle down), pinched the lever on the back and slid out the tray the staples go into. I...
The question here is what are standard staples in YOUR opinion? Are they designed to be used with this staple gun. What length are the legs of the staple 1/4" or less.
You cannot just use any staple in these guns They have to be the correct type either stanley or Bosh
Please rate my help++++Thanks for using FIXYA
Jun 20, 2010 | Stanley Chrome Hd Staple Gun Tr110
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
My jt21m stappler gun is not dispencing staples, i have loaded it the only way i can see how to, helppppp
Make sure you are using the correct staples for your staple gun. Same brand, proper size.
Next look carefully where the staple should come out as often there will be part of a staple caught up in that area which will have to be pulled out with a pair of pliers.
Oct 03, 2009 | Arrow Fastener Co. Lt Duty Staple Gun -...
Swingline Stapler 900XD -
Help! I have a swingline 900XD and the device that holds the staples in place is missing. Does anyone have an idea how to fix it???
Jun 10, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Powerfast strap gun for romex misfiring
just a try spray with a generous coat of pb blaster while firing a few then follow with a good coat of household oil then oil before using just something to give it a try
Nov 17, 2008 | Tools & Hardware - Others
Tools & Hardware - Others Logo
220 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
