Question about Uniden DCT646-2 Cordless Phone
Registration panasonic kx-tg2360jxs - Uniden DCT646-2 Cordless Phone
How to register Panasonic KX-TGA-405 Range Extender with existing Panasonic Base Model KX-TGF570
According to the manual for the KX-TGA405, you need to do the following steps to register the range extender to any compatible base (including the KX-TGF570). First, unplug the range extender's AC adapter. Press and hold the Locator button on the base (KX-TGF570) for 5 seconds or until the registration tone sounds. Within 90 seconds, plug in the KX-TGA405 AC adapter. After the status indicator light on the range extender becomes green, press the Locator button on the base to stop the registration tone. Depending on where you place your range extender, you may need two people with two-way radios to complete these steps in the 90 second time limit.
See page 4 of the KX-TGA405 manual for the Deregistration/Registration steps. Panasonic has the manual here: ftp://ftp.panasonic.com/accessory/phone_fax/om/kx-tga405_en_om.pdf .
I hope this helps.
Aug 22, 2017 | Panasonic Lands Phones
Can't set date & time for Panasonic cordless phone GX-2711SAM
Still error ,handset registration fails although keep on trying step 1&2 in my kx-tg2360jxs panasonic cordless phone , what shall i do ? Shall i change handset batteries ? Really i got bored , is their any one facing my problem ? Help me please
Jan 05, 2014 | British Telecom Synergy 2110 Cordless...
I cant open dial lock in panasonic CODLESS PHONE
hcant open dial lock panasonic model no: kx-tg2360jxs
Apr 29, 2012 | Lands Phones
Panasonic kx-tg2730 my extra cordless phone (2) tells me i'm too far away from base (1) when i'm right nexr to it. how can i connect it to the base?
One of the functions of your handset is REGISTRATION or RE-REGISTRATION. It involves stepping to that command, pressing enter, then pressing the handset locator button on the base and the two units can link up.
Carl
Apr 09, 2011 | Panasonic KX TG2730 Cordless Phone...
Panasonic kx-tg2360jxs is dial locked . how i do ?
i fourget dial password help me to reset password
Nov 04, 2010 | Cell Phones
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
Panasonic kx-tg1100
STEP1:
On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
STEP2:
Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Feb 28, 2008 | Panasonic KX-TG1100 Cordless Phone
DECT registration
Sorry but could you re-confirm the model number, as the post heading shows KX-TG5632 and the text of your query shows it as KX-TG7223E ? ( Panasonic site does not recognise the latter ) Thanks.
Jan 26, 2008 | Panasonic KX-TG5632 Phone
Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Oct 18, 2007 | Panasonic KX-TG2740 Cordless Phone
Uniden DCT646-2 Cordless Phone Logo
19 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
