Question about Garden
I have a Task Force electric line trimmer with the adjustable shaft ... how do I extend the shaft?
  • 8 Answers
SOURCE: how far does the return gas line on a ryobi string trimmer extend
There is supposed to be a barb fitting with a flange on top of it that is on the end of the hose, inside the tank. If you do not have that barb in place the gas will start to leak out of the tank in a short time. Barb fitting is designed to have hose stick up about 3/16" into the tank when the hose is properly installed. You put the new hose on the fitting, thread the other end of the hose through the fill opening of the tank and out the hole in the bottom. Pull hose through until barb comes through the hole in the tank and the flange is flush with the inside bottom of the tank. There is supposed to be a plastic ring that fits over the bulge in the hose/barb at the bottom of the tank on the outside. Serves as a retainer for the fitting.
Posted on May 20, 2009
SOURCE: Homelite curved shaft timmer line problem
It sounds like its a bump feed which they usually are, try turning on the machine and bump the head off the ground. If this fails to work try rewinding the line on tightly and neatly with no parts of the line crossing over as this could knot it. Quick tip most heads have a arrow pointing the direction to wind the line.
Let me know if that works.
Posted on Jan 09, 2010
rycgl
  • 1545 Answers
SOURCE: Homelite curved shaft trimmer cs26 sting will not
Check the spring inside and the spool too. If broken, a universal type head can be purchased at Home Depot.
Posted on Sep 06, 2010
  • 407 Answers
SOURCE: I cannot get more line
Sometimes the line can become fused together.remove the spindle and manually pull the line. Replace and the tap and feed should work fine.
Posted on May 12, 2011
SOURCE: I was given an electric start Homelite line trimmer, Touchstart UT-20683. Its like new condition but mising the wall charger. I need to know the voltage requred to charge the battery. Does anyone have
Funny I picked up one today...for $20. It too is missing the wall charger...it I find one I'll let you the source, meanwhile the voltage is 6. Hope this helps. I'll keep you posted Re: the charger..
Posted on Jun 23, 2012
Echo string trimmer will not rev up idles fine and starts up easy
The fuel mixture and or idle speed may need adjustment. If yours is a newer trimmer and it has a two cycle engine, these adjustments are sealed by the manufacturer. Some adjustment tools are sold on line but finding the right one can be a challenge. It seems the manufacturers almost force you to take it to a small engine repair shop to make this simple adjustment. It was the EPA that forced manufacturers to seal these adjustments.
Nov 10, 2016 | Echo Garden
Why does the string keep breaking on a task force electric weed eater
Hello, When the string gets old it dries out and becomes brittle. I soak my trimmer string in water until I am ready to use it. The string actually absorbs some water and stays flexible. Try it.
Aug 28, 2014 | Garden
Flymo electric power trim..dual auto feed line keeps getting wound around the drive shaft...bloody annoying any suggestions.. Ian (M)
Most trimmers have a cutter on the shield by the spool. This cuts excess line off to prevent it from wrapping around the shaft. If the shield has been removed or the cutter is dull it will allow extra line to wrap around the shaft.
Aug 03, 2011 | Garden
I cannot get more line out of my toro 15" electric trimmer. It cannot be empty, it has only been used once. The cutting line will not extend out any more. Should it not?
May 12, 2011 | Toro& Electric String Trimmer
I have an electric 13"
you can try a smaller string size, this should help. Tim
Apr 24, 2011 | Toro& Electric String Trimmer
I have a Talon electric line trimmer AT2307A. When I press the start button, the bottom attachment with the nylon line does not spin even though the motor is running.
Halfway down the shaft of the line trimmer, you can detach the line trimmer attachment ( this in so you can fit a lawn edger attachment if need be). Unclip the line trimmer at that halfway point and the start the motor and see if that rod inside the shaft is spining, if so, reattach the line trimmer attachment and see if the nylon line spins, if so, it wasnt attached correctly, if not, then there a break in the flexible rod going to the trimmer head, most likely at the bend.
Dec 29, 2010 | Garden
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Jun 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
