Question about Defiant 500 Lumen Twin Solar Outdoor Motion White LED Security Light
Light just flashes once and goes off - Defiant 500 Lumen Twin Solar Outdoor Motion White LED Security Light
Trying to synch my remote to the new tvee model 25 sound bar and can't get the orange lights.
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Sep 05, 2011 | Boston Acoustics Audio Players & Recorders
Have a BA TVee 25 Soundbar. Only able to program Volume Up on my remote. Cannot program Volume Down or Mute. Nothing happens except to turn the Soundbar off and on. Don't tell me to follow...
Jul 26, 2011 | Boston Acoustics TVee Model Two TV...
Got the Boston Tvee 25 and was able to program the volume up ok, but not able to program the volume down or mute functions. The process is the same but ive tried 100 times with no luck! Any help?
Jun 05, 2011 | Boston Acoustics TVee Model Two TV...
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
Apr 05, 2009 | Canon PowerShot A550 Digital Camera
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
RCA Model D52W20B Serial # F074C312B Chasis ITC222 Set does not turn on the power light comes on then flashes and goes off. I need the part number in order to fix the problem
if the light flashes three times then goes out you need flyback 259296 if the light only comes on once then goes out you need the deflecion board. You can get any part you need at the following link and if your not sure leave them a email with the model number and symptom they respond quickly.
http://servicemanuals.vstore.ca/
Sep 25, 2008 | Televison & Video
Msg button flashing
go to the phone where the light is flashing press intercom #409. you may have to do that more than once. Keep doing it until the light goes out.
If the phone system is a DK 8 orDk16 press intercom 409 this will cancel the message waiting light that could have been cativated by a different extension.
Sep 22, 2008 | Toshiba DKT-2010 Corded Phone
L63 Salt light is flashing
goes for short time and 2 ljghts flash the red salt light wont go on
May 16, 2008 | Ariston Technologies L63 Free-Standing...
Defiant 500 Lumen Twin Solar Outdoor Motion White LED Security Light Logo
63 people viewed this question
Top Defiant Home Security Experts
tony wahlman
tony wahlman
Tom Chichester
Daryl Gleaton
Are you a Defiant Home Security Expert? Answer questions, earn points and help others
