Question about Brookstone MiniMax Tower Fan
Cleaning the dust from the inside
I need to take fan apart in order to get dust from inside
2 Suggested Answers
SOURCE: I need to take the
You will need a phillips screwdriver (preferably 2 different sizes - some of the screws are tiny), q-tips and a can of wd-40.
On the back of the brookstone (the darker gray side) you will find 4 screws inside of 4 channels. Take these out.
Put the fan on its head. pry off the 5 rubber bases and set aside carefully so as they won't lose their stickiness. You will see 5 screws beneath these. Remove them and then remove the bottom plate. Now remove the 2 screws and washers, noting that the rounded side of the washer was facing you. Now pivot the base so that the 4 holes on the outer part of the base line up with the 4 screwsheads that are screwed into the tower. Take these out.
The 2 gray tower pieces should now separate easily. set the fan on a newspaper and blow away as much of the surface dust as your can. Now use your wd-40 (with a straw nozzle attached) and spray into the motor area where the actual fan turns. Also spray, from the top down, along the metal rod that connects the fan to the motor.
Now use the q tips, dipped into warm water, to clean the dust from the fan "blades" and to clean any other nooks and crannies you can see.
Lube the motor up one more time, put the machine back together and leave to dry out overnight.
Will work like a charm afterwards.
Posted on Nov 23, 2011
Cleaning the lens from the inside
Cleaning the lens from the inside is not possible from a practical point of view. However, if you don't care that your camera won't work after you've taken it apart but you just want to see what's inside, then go ahead. If you see dust inside the lens and this is what is concerning you, please know that all lenses have dust inside...it can't be totally eliminated. In 99.999% of cases, the dust doesn't show up on the actual pictures.
Oct 17, 2011 | Casio EXILIM Card EX-S770 Digital Camera
Tv repair
I would reccomend replacing the fan or cleaning+lubricating it. You can find a "precision oiler" at a local hardware store. Its like a small plastic tubs with a skinny needle at the end. Its very handy in cases like this. Use that oiler to squirt a little bit of oil into the shaft that turns the fan at the moto ritself. You may have to take the tv apart depending on what model it is. If lubing it and cleaning off all the dust doesen't help you will need to replace the fan.
Dec 09, 2007 | Televison & Video
I have one server IBM X series 346, which is giving Fan alarm , its fan LED showing amber, though server is working fine.
The problem could be a faulty CPU fan or the fan and heat sinl assembly is clogged with dust.
Check the fan, if it does not spin freely then replace the fan. If the fan and heat sink is clogged with dust, remove the dust and use a can of compressed air to clear the dust from the heat sink fins.
Apr 07, 2011 | IBM xSeries 346 Server
Have several small DT-70 table fans. Wondering is it possible to take them apart for cleaning? I have NO idea where my manuals are, bought them several years ago. If they cannot come apart for cleaning,...
There are 6 screws, deeply recessed, in the rear of the fan case. (At least that is how they are on mine, phillips or cross head)
Once they are loosened, the front and back will come apart. I Do that annually so it can be thoroughly cleaned..
Otherwise, I use a toothbrush to fit between the slots to get most of the dust, also a paintbursh with stiff bristles for the outside grills.. Similar small brushes should work for loose dust. Also can blow out loose dust with a shop vac with blower capability.
Jul 21, 2010 | Dryers
My sony wega kdf-60xbr950 tv does not turn on, it just make clicking sounds. I order a new lamp assembly and it did not fix the problem.
The projector inside the unit can become clogged with dust in its cooling fans which causes load and shut down of the unit. If you feel comfortable take the back off get a really long phillips screwdrivers and remove it, take it apart and clean the dust out.
Apr 29, 2010 | Televison & Video
Heater fan dont work all the time on my 94 volvo 960
After some years, the the filters (made of foam) in the HVAC system can become dry-rotted. Debris from the rotted foam, as well as dust, can accumulate in various places within the system. Unfortunately, the motor housing of the blower is one place in which the dust and debris accumulate very well. To fix the problem, you have to remove the cover from the blower, and vacuum clean it. The blower is behind the glove box, on the lower right side.
A word of caution: The fan cage (which looks like a gerbil wheel) can become brittle, over the years. After cleaning out the blower motor, the blower will be able to freely spin at full speed, again. This may be too much for an old brittle fan. If your old blower can't take the force of spinning at full speed, you will hear it break apart inside its chamber. I discovered this, the hard way. After cleaning the dust and debris from my Volvo's blower motor, the blower spun at full speed and the fan broke apart. So, I had to buy and install a whole new blower.
Dec 13, 2009 | 1994 Volvo 960
Auto shut down due over heat
Very Very Carefully disassemble the laptop, and clean out the processor fan, and any other "vent" looking things. Lots of times hair (especially pet), dust and other pollutants will clog these, or they may stop working all together, and need replaced.
Nov 19, 2009 | Sony VAIO GRZ660 Notebook
My laptop fan constantly runs help!
First, I recommend cleaning all the dust out of the cooling vents. Use an old toothbrush to brush the dust away from the vent holes and blow air through the vents using one of those compressed air cans made for cleaning keyboards. One time I worked on a Sony laptop that I had to take apart to get all the dust cleaned out of the air vent.
The second thing I recommend is to download a piece of free software called FanSpeed. Here's a link http://www.softpedia.com/get/System/System-Info/SpeedFan.shtml
I'll let you read the description for yourself, but in short it allows you to monitor the temperature inside your computer and to adjust how the fans react to this temperature.
May 28, 2009 | Compaq Presario Fan
Video card fan gettin gnoisy
If the noise is troubling you can see about ordering a replacement for it. Thats the easiest fix. Your other choice is to take it all apart and see whats up in the inside of the fan.
Mar 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Want to dust bulbs and screen on inside. how do i take apart?
don't remove anything use a clean lense cleaning cloth that's all dust the mirror.
we us compressed air to blow out the dust
Oct 06, 2008 | RCA R52WM24 52" HDTV Projection Television
Brookstone MiniMax Tower Fan Logo
89 people viewed this question
Top Brookstone Dryers Experts
Dan Webster
Dan Webster
Are you a Brookstone Dryer Expert? Answer questions, earn points and help others
