Question about Crosley Collegiate (CR85) Turntable
Crosley collegiate needle skipping - Crosley Collegiate (CR85) Turntable
2 Suggested Answers
  • 189 Answers
SOURCE: My Crosley Rochester CR66 5-in-1 entertainment center skips parts when playing vinyls. I just got it and I don't know why it's doing that. Is it the needle?
Absolutely or the album is scratched
Posted on Mar 03, 2015
Crosley CR6019A turntable skips
Hi
Being a portable model, it is very easy not to have the turntable level. It is very important that it is level as a tilt can lead to the head "skipping", amongst other things.
You can get a full User Guide here
http://0bee184f253cf7f48610-d2b1caba160808a264f409f8f32a9b54.r0.cf3.rackcdn.com/Crosley%20CR6019A%20%20Executive%20Turntable.pdf
Another possible problem is that the balance has become upset by being moved around. The correct balance is achieved b the positioning of a weight on the tone arm on the opposite end to the needle. This can usually be moved short distances to balance the tone arm so that the needle is held in the record groove, by the minimum necessary weight on the needle.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 26, 2014 | Audio Players & Recorders
Why is my brand new crosley turntable keepsake hunter skipping tracks?
The turntable may not be level. Also, the stylus could be damaged or defective. The stylus pressure may not have been set correctly in production or may have been affected by shipping.
May 05, 2014 | Crosley Keepsake USB Turntable
Turntable skipping
It sounds like you need to adjust the need tension (counter-weight thingy on the other end). If the needle is too "light" on the disk, it will float around and over the groove walls. Make sense?
Another thing is th tracking resistance of the stylus arm (if your player has this adjustment).. This one puts resistance on the horizontal movement to keep it from "skipping" when a deep scratch is encountered playing an album.
The higher end players have these and many more adjustments which were made to counter scratches and deformities in vinyl records. My father had one which used a laser instead of an actual needle to read the track groove so that no wear occurs in playback.. (star wars stuff, right?)
Goiod luck to you, but I think those two are your issue.
Jan 29, 2014 | Crosley Audio Players & Recorders
Record skipping despite new needle
It could be something to do with the turnatable's platter. Is the matt that the record sits on faulty. Does the platter wobble up and down with no record on it? If you can see this happening you might need to check the platter out. If it's a belt driven the belt can come out of position causing such problems. Also objects can get stuck inside the platter. Especially if you have small children in the house!!!
Feb 28, 2013 | Crosley Cr704 Audio Shelf System
What is the replacement needle for crosley cr74
Here i have added two links which will take you to the needle for Croslye CR 74. There you can also fined the code for the item
LP Gear stylus for Crosley
LP Gear 78 RPM stylus for Crosley
Dec 09, 2012 | Crosley CR74 Turntable
The records keep skipping
there is an adjustment for the angle of the needle. it is hard to deal with though, because you cant get your head down there to see exactly what is going on. be gentle. you can adjust and fix it.
Sep 16, 2012 | Crosley CR6007A Turntable
Every record we play skips, even the brand new ones
the needle/stylus needs to be replaced.
http://www.needledoctor.com
Apr 23, 2011 | Crosley Conductor CR73 Turntable
Crosley Collegiate (CR85) Turntable Logo
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
