Question about Hotpoint TVF770 Tumble Dryer
Change heater element on hotpoint TVF770K Aquarius dryer now have F13 fault
Now runs and heats up then stops with F13 fault flashing on control panal
    Sergeant:
  • 282 Answers
There is a small thermostat button ontop of the Heater mechanism which has tripped . It has either a red dot or blue dot ontop. Use a pin or opened up paper clip and push through the red wax. It will go click and it is reset. .
It sometimes trips out with a F code which normally trips the machine off because it thinks the Heater unit is on fire.
There is a small disk which costs about £15 to buy which you can change.
You will need HEX screwdriver set to change and open up the Heater matrix to clean the fluff off the element.
change heater element on hotpoint TVF770K Aquarius - b11d81f4-4b2d-4e7b-b96f-64181e755ab0.jpg
Posted on Nov 15, 2014
  • Dai Boyce
    Dai Boyce Nov 15, 2014
    Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10- 20 pounds sterling from Hotpoint or other spares stores.
Hi just had this problem myself
When plugging the red & black connector cable in, there are two ports on the bottom next to each other you've plugged into the incorrect one
Do hope this helps people in the future :-)
Posted on Sep 19, 2014
  • 139 Answers
SOURCE: no heat
hi there
your problem is either the t-stats have blown which is very common or your heater is blown..
im guessin your t-stats beacuse they are the most common on hotpoint dryers to blow. There always blowing
They located at the back of the dryer behind the protuding panel so there for you dont need to open it all up just that panel.
To check if their blown check for continuity,, no continuity no good merry christmas cheers
Posted on Dec 24, 2007
Jimster
  • 240 Answers
SOURCE: PROBLEM WITH HOTPOINT DRYER
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1811&modelDesc=DRYER&modelNumber=NVLR333ET0WB&documentID=E2136683&documentTypeID=PLDM&documentClassCode=PV&titleType=DRUM%2C%20BLOWER%20%26%20DRIVE%20ASSEMBLY&titleID=00004&
This is a diagram of your particuliar unit. These Hotpoints are manufactured by GE. The heating element is right behind the drum itself. First is to unplug the unit. Open the door, and look at the top edge of the top of the door. You will see two screws that hold the top down. Remove these screws, then lift the top off. You will have to reach your hand under the drum (and really reach around) and unhook the belt from the idler pully and motor pully. The drum is now free to pull out, directly forward. Your heating elements are now right in front of you. Be sure you check both for drooping, touching each other or the sides, broken wires, etc. Also, these elements are very, VERY expensive. They make a rewire kit that will save you a TON of money. Instructions are included with the kit, Be sure when you put the drum back in, you grease the rear bearing slide and plug.
Heater Assembly (whole unit) Part Number WE11X103 $90.00
Restring Kit: WE11X203 Part Number $35.00
Also, both of these parts are usually found on E-Bay in groves. Do yourself a favor, do not buy them from Sears, they have too high a mark-up, shipping is also way to high, and takes forever to get there. Let me know if you need further help. Thanks and good luck!!!!
Posted on Feb 02, 2008
MNTECH
  • 1543 Answers
SOURCE: where do I find the heating element in my hotpoint dryer
Heating element is behind the drum. Disconnect power. Use putty knife to release 2 spring clips holding top at front edge of dryer. Swing top back. Remove two screws holding dryer front to sides near open top. Swing dryer front to the side. (you don't have to disconnect the door switch wires) Remove plastic tub block at top center of opening. Release belt. Pull up on back of drum, then pull drum out through the open front of dryer.
Posted on Sep 12, 2008
barkencoa
  • 3463 Answers
SOURCE: I don't have any heat from my hotpoint aquarius ctd40G tumble dry
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
Posted on Jan 07, 2009
skyblue67
  • 71 Answers
SOURCE: dryer wont heat up on a aquarius VTD00, do you
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. . Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. Also overloading and blocked filters can lead to thermo cut out, it is best to check your manual and call someone out on this occasion. You may even have a red reset button on the rear of your machine some models do, if yours doesnt then call out engineer :)
Posted on Jul 19, 2009
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Mar 05, 2010 | Washing Machines
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hi i have a Hotpoint WD640 1400 spin Aquarius + and on the control panel it keeps flashing F-13 can anyone help
The dryer fan or dryer thermistor (thermostat) is faulty.
If the fan is working, then replace the thermistor, or check for broken wire.
Please rate my solution.
Thanks.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 23, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Error code f13
There is a small disk which costs about £15 to buy which you can change. You will need HEX screwdriver set to change and open up the Heater matrisx to clean the fluff off the element.
Sep 10, 2008 | Hotpoint Aquarius WD640 Front Load...
CODE F13 ON HOTPOINT AQUARIUS WASHER/DRYER
Do u want to resolve the f-13 fault code on HOTPOINT Washer Dryer units
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 - 20 pounds sterling from Hotpoint or other spares stores. code-f13-hotpoint-aquarius-washer-dryer-brswrwcy453xu5qdcnkktuei-3-0.jpg code-f13-hotpoint-aquarius-washer-dryer-brswrwcy453xu5qdcnkktuei-3-2.jpg code-f13-hotpoint-aquarius-washer-dryer-brswrwcy453xu5qdcnkktuei-3-5.jpg
Jan 17, 2008 | RCA F27450 27" TV
F 13 ???????
f13 means the dryer heater is not working the thermal fuse on top of the dryer that connects inline with the heater is open circuit this is most likely due to the fan dropping and stalling causing the overheat or poor airflow due to a buildup of fluff in the dryer
Jan 28, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint TVF770 Tumble Dryer Logo
235 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
