Question about RCA Televison & Video
I need to remove back of rca led52b45rq to clean inner screen
I want to clean inner screen
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: INNER SCREEN NEEDS CLEANING
Its very easy, see its rear side, you will see screws there, unscrew it and remove back cover of TV to clean it. Please you must Unplug TV from AC outlet before open it back cover.
Posted on Aug 15, 2008
SOURCE: nEED TO REMOVE INNER SCREEN.
take the lower panel speaker covers off first, then tanke the 4 screws out below the screen, then take the bottom skeleton cover off around the speakers then you can take the 4 screws out of the bottom of the screen then the whole screen slides up with 4 tabs in all 4 corners becarefull not to pull out the plastic holders will break you need to make sure to slide it upwardes then you have full access to the inside to clean. hope this works for you
Posted on Jan 16, 2010
MY RCA LED52B45RQ NOT COMING ON
Open internal fuse or power supply failure
Nov 16, 2016 | RCA Televison & Video
Here is a picture that shows you how to remove the front screen to get access to the mirror as well.
Aug 15, 2008 | Toshiba 51H84 51" Rear Projection...
LED52B45RQ RCA TV will not turn on
Could be an open internal fuse or power supply failure. The "standby light" merely indicates that power is getting to the TV.
Jul 14, 2016 | RCA Televison & Video
I have a RCA led52b45rq tv that wont power on & standby light is off also! I do have 5v to the 5vsp terminal on the power board! Any ideas why wont turn on?
How about the rest of the voltages? Are they present and within limits? Are there any capacitors that look puffy, changed color or have domed tops? You can get repair parts kits, replacement boards or a repair service from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 27, 2016 | RCA Televison & Video
RCA D56W20 Screen Removal
you will need a set of star bits or star tip drivers there available at your local hardware store
there are screws that go around the top half of the back of the tv this will take the etcheonson loose so that you can get to the lenses to remove them for cleaning
Nov 08, 2009 | Televison & Video
I need to clean my 1997,52 inch rca tv screen
OK
Take the screws out of the BACK top panal of tv! be gentle the mirror is connected to this back!.... now after removeing back you will see the inside of screen and the three lenses and on back panel the mirror! clean all three of these and you will see a big change for the better..Then just replace back! (The screen itself does not come out!)
Please take a second to place a rating for my answer!
thank you!
Jan 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Need to clean the backside of the plexiglass
You dont!!!! You remove the back upper panel screws and remove the back of the TV to access this area to clean! Wile your in there you might as well clean the lenses and the mirror too ( will see a big differnce in the picture!) be carfull with the back when removed! the mirrir is connected to it!
I think this will fix ya up!
Please rate this free response!
THANK YOU!
Jan 17, 2009 | RCA HD52W58 52" TV
How to clean inside of screen?
Your tv has two screens on it. The outter screen and the inner screen. The outter screen has a frame around it held on by clips. You can remove this outter screen by gently prying it from the tv. There is a small gape between the outter screen and the tv casing. When prying the outter screen be carefull not to dsanage the tv case or the outter screen frame. Take note of the location of each clips because you will need thses to put the outter screen back on. Clean with a good gentle screen cleaner, (Do Not Use Windex). Philips screen cleaning gel for plasma & LCD works very good. Install the outter screen back on the tv by making sure the clips line up and use light pressure to snap it back in place. Do Not Hit Outter Screen To Force Clips Into Place.. I do this on my tv about once every 6 months or so.
Jan 04, 2009 | RCA P61960 61" Rear Projection Television
I ve got a cracked inner screen on a rca d61130 any help
it is compulsary to replace the screen.calling a technician is much advisable if you dont have any technical knowledge.
you can do it your self by removing the old screen by opening the locks on the inner side and removing the screws from internal side.
thanks.
Oct 13, 2008 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
