Question about KitchenAid KUDE70FXSS Builtin Dishwasher
KUDE70FXSS blue lights blinking & wont't start
My sharp lc-52se94u tv wont turn has blinging blue light and opc light on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
May 01, 2015 | Sharp Aquos Televison & Video
32ta2800 power light blinking blue & orange problem not start
You will have to troubleshoot the power supply to find and correct the problem.
Jul 29, 2014 | Philips 32PF5320 32 in. HD-Ready LCD...
Brookstone pocket projector wont turn off
i'm having the same issue. it 1st started with a No Signal error. then this started...ugh!
Feb 10, 2014 | Brookstone Pocket Projector for iPhone 4...
Led light flashes 4 times, pauses then repeats
Which light blinks 4 times and pauses wash normal heavy etc if the model in the blue box is correct the to enter diagnostic press any 3 keys within 8 seconds I usually use normal and the 2 keys to the right all lights should light up if touch pad is up top where you had to open door to accomplish this then close the door after a pause the clean light will begin to flash example 7 flashes pause 1 flash these are your fault code it will do this 3 times for each code. The tech sheet should be behind the toe panel located below the dishwasher door which just repeats what I explained.
Feb 04, 2014 | KitchenAid KUDE70FXSS Builtin Dishwasher
Afterglow Wireless Headset Blue Flashing mic light
i have the same problem. i am worried. i was playing counter strike and we finished. everybody was congratulating. shortly after a loud beep a bit lower pitch than the turning of and on noise that the headset makes. i turned it on and off. the only thing that stopped the beep was to mute the mic. fiddles with the 2 buttons, the light dimmed greatly and the mic started blinking blue. if you are able to find any way to fix it please contact me on skype : Sassy_Sasquach. Thanks!
Jan 23, 2014 | Radio Communications
The blue & red lights on my JVC HD-56G787 tv are blinking alternately
Or the problem could actually be a power supply failure
Nov 08, 2013 | JVC HD-56G787 Television
CAR WONT START AND BLUE LED LIGHT STAYING ON NOT BLINKING BUT CONSTANCE
IS THE BLUE LIGHT A MOBILISER INDICATOR IF SO IT WILL HAVE TO GO INTO A GARAGE TO BE REPROGRAMMED
Jul 06, 2013 | Remote Start System
My vt999 wont work the blue and red lights just blink
you have either a mechanism jammed or something wrong in the power supply bad--don't keep trying as sooner or later you will have smoke.
Dec 22, 2012 | Behringer VT999 Vintage Tube Pedal
MY WII BALANCE BOARD IS CHARGED BUT THE BLUE LIGHT WONT STAY ON.
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
click here to download repair guide if u want
Dec 15, 2010 | Nintendo Wii Fit - Balance Board + Game...
2006 Dodge Caravan Engine Light Blinks 10 Times & wont start
It sounds like your starter needs cleaned or replaced. The poping noise could be the actuator not engaging right. As for the engine light, it could be just a coincidence.
Jun 23, 2009 | 2006 Dodge Caravan
KitchenAid KUDE70FXSS Builtin Dishwasher Logo
85 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
