Question about Tadiran Emerald Ice 28 DLX/BL Business Office Phone Telecom 28DLX 72420945400
Emerald ice phone goes directly to voice mail without ringing
Outside calls go directly to voice mail for one extension only. intercom call still ring at extension.
My Panasonic Phone KX-T7630 rings seventeen (17) times before going to voice-mail. Desired amount of rings before going to voice-mail is four (4) to five (5).
This is just for your phone ringing when it's dialed, not for outside lines ringing on your phone.
From your intercom, dial *7104 (CF No Ans) 500 (if that's your VM extension) # That will flash your FWD/DND light to tell you it's forwarded on No Ans. Now on the intercom, dial *71324 The 713 part tells your phone to forward after xx seconds. 24 is about 4 rings. You can adjust the timing using 6 seconds as a ring cycle.
Carl
Jun 28, 2011 | Panasonic KX-T7630 Corded Phone
How do we set up the phone system so that an outside caller can call our extension directly without having to go through reception/main unit?
There are a couple of ways. The easiest one is to use the Panasonic voice mail system which has an auto attendant built-in. It can be programmed to answer incoming calls, play a menu and let the caller dial extensions or ring the operator. If no one answers, it can take messages and provide the voice mail for the system. The TVA system has a LAN card that can send voice mail to email. It's optional in the TVA-50 and included in the 200.
Carl
Mar 14, 2011 | Panasonic KX-T7630 Corded Phone
I cant change the voice mail
When you say voice mail, do you mean your personal vmail box or the AutoAttendant? If so you'll need to login to the 998 mailbox and modify the "Custom Service" prompts (menu# 5-3). NOw as far as the ringing goes, you might try doing an extension data clear procedure by doing Intercom -> *790 (I think it's Intercom 7900 on the older systems). Otherwise you should call a local Panasonic Dealer for a service call. Contact me offline for a referral.
Sep 02, 2009 | Panasonic KX-T7630 Corded Phone
Ringer/ Voicemail Bounceback
Well, this one is kinda tricky. If the receptionist knows there's no one there, they can use VoiceMail Transfer.
From the phone, the user can set CF Busy or CF Busy/No Answer with the following codes on the intercom:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding2.gif (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
The last piece of the puzzle is the timing. That's *713 (00-99). Start with 24 (4 rings) and go from there. If it hits the receptionist before the forward takes place, you probably have to adjust the recall timer for call transfer, a system program.
Carl
Aug 11, 2009 | Panasonic KX-T7630 Corded Phone
Ring back on 18D
If you have enough voicemail boxes go to ext 10 or 11
Press feature 00
Left intercom twice
#310
enter extension number
press 1 to assign
Feature 00
Jan 16, 2009 | Avaya Corded Phone avaparp18d
Calls go straight to voicemail
Your phone is fowarded to Voice Mail and do not disturb is on. Turn DND button off. If it is not the case on your phone press intercom # key 601 then hang up. Then do intercom #key 604, dial your voice mail extension numbe, r press the speed dial Select button, dial 16, press the redial button then hang up.
Dec 11, 2008 | Toshiba DKT-2020 Corded Phone
Phone ringing.
On extension 10 or 11 press Feature 00
Left intercom, left intercom, right intercom
Enter your extension number
Press line buttons until its a fast blink and display say no ring
Feature 00
only transfered calls will ring
Nov 21, 2008 | AT&T Partner 18 Phone (315805B)
Re: Question
Your phone can have 3 options, Ring all the time, Switch between Voice and Ring, or Voice all the time.
From your phone(s) press PROG 21 and press the ENTER soft key (3rd key). Now press the SEL (3rd key) until it says VOICE CALL then press ENTER and EXIT. If you set it to this mode, the AUTO ANS button won't work.
If you select TONE, the Auto Answe button will work, making the phone VOICE CALL when lit and ring when not.
If you select VOICE CALL DENY, the AUTO ANS button still won't work and ...you get the pattern.
Carl
Oct 22, 2008 | Panasonic KX-T7633 Corded Phone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Voice vs ring on intercom
Speaker - "60" - Speaker.
This is the default setting for Voice / Tone toggle.
Feb 26, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Tadiran Emerald Ice 28 DLX/BL Business Office Phone Telecom 28DLX 72420945400 Logo
41 people viewed this question
Top Tadiran Computers & Internet Experts
David Payne
David Payne
Are you a Tadiran Computer and Internet Expert? Answer questions, earn points and help others
