Question about Dell Computers & Internet
Printer prints 2-3 pages then stops.
When I print with my Dell inspirion it will only print 2-3 pages then stops. When I change to my desk top computer using the same printer it works ok. Why does the lap top inspirion stop printing?
  • 38 Answers
Open the print queue in the system tray and look at the status of the stalled doc. try restarting the doc. If the printing is a large file it could be a memory problem. check device mgr (Ctrl Alt Del) to see memory usage
Posted on Jul 08, 2014
pkbytes
  • 45 Answers
SOURCE: printer will default to "save as" screen when que to print
In administrator login the default printer is "Microsoft XPS Document Writer", make sure that the default printer is the HP Printer.
OR
You have to change in the Print dialog box, select the HP Printer instead of "Microsoft XPS Document Writer"
Cheers - Parveen
Posted on Feb 08, 2008
SOURCE: Samsung ML-4500 with IEEE 1284 to usb cable not working
Windows XP/VISTA (do not install the CD)
1) Plug the cable into the USB port on your computer.
2) A prompt that says "Found New Hardware" will appear. Windows will then install the USB printing support driver automatically. You do not need to install the driver from the CD.
3) Plug the cable into the printer.
4) If your printer is already installed, click on Start, then Printers & Faxes. Right click on the printer you are connecting to and click on Properties. Click on the Ports tab and check the ‘Virtual printer port for USB’ port. Click OK.
5) You should now be able to print.
With XP, the biggest clue is to FIRST plug the cable into the usb slot, THEN the other end of the cable into the printer.
Posted on Jun 04, 2008
kikoksky
  • 119 Answers
SOURCE: unable to print using samsung print on Windows XP
To resolve this issue, follow these steps: 1. If you do not have a Lexmark printer installed, go to step 4. If you do have a Lexmark printer installed, go to step 2.
2. If the Lexmark print service is installed on your computer, turn off the LexBce Server service. To do this, follow these steps: a. Click Start, right-click My Computer, and then click Manage.
b. Expand Services and Applications, and then click Services.
c. In the details pane, right-click LexBce Server, and then click Properties.
d. On the General tab, in the Startup type list, click Disabled.
e. Under Service status, click Stop, and then click OK.
f. Right-click the Print Spooler service, and then click Start (if it is stopped).
g. Exit Computer Management.
3. Test whether the issue is resolved. If the issue is resolved, you do not have to follow the remaining steps. If the issue is not resolved, go to step 4, and then follow the remaining steps.
4. Start the computer in safe mode. To do this, follow these steps:a. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured to start multiple operating systems, you can press the F8 key when the Boot menu appears.
b. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
c. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Note For more information about how to start your computer in safe mode, click Start, click Help and Support, type safe mode in the Search box, press the ENTER key, and then click the Start Windows in safe mode topic.
5. Start Microsoft Windows Explorer, and then delete all the files and the folders in the following two folders (where C: is the drive where you have Windows XP installed): • C:\Windows\System32\Spool\Printers
• C:\Windows\System32\Spool\Drivers\w32x86
6. Start Registry Editor. To do this, click Start, click Run, type regedit in the Open box, and then click OK.
7. Locate and expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86
View the list of subkeys. There should only be the following subkeys: • Drivers
• Print Processors
8. If there are any subkeys other than the subkeys that are listed in step 7, follow these steps: a. On the File menu, click Export.
b. In the File Name box, type the name that you want to use for this key, such as WindowsNTx86regkey, and then click Save.
You can use this backup of the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86 registry key to restore the key if you experience any issues after you complete this procedure.
c. Delete all the subkeys other than the subkeys that are listed in step 6. To do this, right-click each subkey that is not on the list, and then click Delete. Click Yes when you are prompted to confirm the deletion.
9. Locate and then expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers
The registry entries for the printer drivers that are installed on the computer are stored in the Version-x subkey or subkeys, where x is a number (typically 2 or 3).
10. Export the Version-x subkey or subkeys. To do this, follow these steps:a. On the File menu, click Export.
b. In the File Name box, type the name that you want to use for this key, such as print driver, and then click Save.
11. Expand the Version-x subkey or subkeys, and then delete the printer driver entries. To do this, right-click each printer driver subkey, and then click Delete. Click Yes when you are prompted to confirm the deletion.
12. Locate and then expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
View the list of subkeys. There should only be the following subkeys for the default print monitors: • BJ Language Monitor
• Local Port
• PJL Language Monitor
• Standard TCP/IP Port
• USB Monitor
13. If there are any subkeys other than the subkeys that are listed in step 12, follow these steps: a. On the File menu, click Export.
b. In the File Name box, type the name that you want to use for this key, such as MonitorsRegkey, and then click Save.
You can use this backup of the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors registry key to restore the key if you experience any issues after you complete this procedure.
c. Delete all the subkeys other than the subkeys that are listed in step 10. To do this, right-click each subkey that is not on the list, and then click Delete. Click Yes when you are prompted to confirm the deletion.
14. If you have a printer attached, disconnect the printer cable from the computer, and then restart the computer.
15. Verify that the Print Spooler service is running. To do this, follow these steps: a. Click Start, right-click My Computer, and then click Manage.
c. In the details pane, right-click the Print Spooler service, and then click Start (if it is stopped).
d. Exit Computer Management.
Note If you cannot start the Print Spooler service, follow the steps in the following Microsoft Knowledge Base article to start the Print Spooler service:
919750 (http://support.microsoft.com/kb/919750/) You experience problems printing, viewing printer icons, and adding printers, the Print Spooler service does not function correctly, and you receive print-related error messages on a Windows XP-based computer
16. If you have a printer attached, reconnect the printer cable to the computer, add the printer that you want, and then try to print a test page. To add your printer, follow these steps: a. Click Start, and then click Printers and Faxes.
b. Click Add a printer.
The Add Printer Wizard starts.
c. Follow the instructions in the Add Printer Wizard to install the printer that you want
Posted on Jun 24, 2008
  • 15 Answers
SOURCE: Dell laptop print spooler service is not running
go into control panel under administrative tools and go to spoiler and enable it
Posted on Mar 29, 2009
wildbear6
  • 192 Answers
SOURCE: aspire one model za3 user guide
Hello, your laptop is known as the Acer Aspire One 110, here is a direct link to the laptop from Acer. at the bottom of the screen you see a drop down menu for Technical Documentation, though I think Acer only have them in German? :-s
Posted on Jan 04, 2010
HP psc 1100/1200 all-in-one stopped printing
Press and hold the cancel button and then press the start copy button release them together.
You should print a test page. No Test page an internal printer problem is likely!
If test page is good reset the spooler \. More than one way to reset spool file. Spool file controls transfer from computer to printer. Spool file a mess then printer hangs!!!
Method 1
a. Go to Start / Control Panel / Administrative Tools / Services
b. Select "Print Spooler".
c. While Print spooler is stopped, start it by double-clicking on "Print Spooler" and then click the "Start" button.
d. Verify that the "startup type" is set to "automatic".
Method 2
Create a new txt file
Type in exactly as the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Rename txt file killspool.bat
save on desk top
Double click off of desktop file to run
Next time printer hangs you can use this file again
Hope this helps?
Dec 03, 2016 | HP Office Equipment & Supplies
It prints gibberish before the print job.
I have had this happen before, this could be you need to change the drum kit on the printer itself, check the indicator light.
Jul 28, 2009 | Dell 1720dn Laser Printer
Printer will print only the first page even if you check all pages
Does it do it with other programs?
it sounds like you have a header or footer problem. Go to it in your word processor and delete any special settings that are listed in there.
Apr 20, 2009 | Office Equipment & Supplies
1600n Printing an Extra Page everytime...
I had a computer experiencing the same problem.
I found under the printer properties that there was 2 drivers listed; both say "Dell Laser MFP 1600n PCL 6"
I swtiched the settings from one to the other.
The Printing Preferences also show more options.
  • Open the Printer(Control Panel->Printers>Dell MFP 1600n)
  • On the menu at the top click Printer->Properties
  • Click the tab at the top Labeled Advanced
  • Change the driver and Click Apply
This should fix your problem.
Nov 08, 2008 | Dell 1600n All-In-One Laser Printer
Hp 3745 desk jet problem
check whether its printing the test page properly directly from the printer not from the pc.for that print
1)just ON the printer
2)press the ON button
3)do not leave the ON button and lift the cover of the printer completely up and down 4times.
4)if you want to change the cartridges which front cover you will lift ,that you have to lift 4times up and down by pressing the ON button ,then leave the ON button the printer test page will come out of the printer .
5)keep the paper in the tray.
6)check that printout if its proper the printer is perfect
7)if the print is improper then the printer is having some problem.
8)also try changing the cartridges and see if its same or better prints comes out.
thanks.
Sep 18, 2008 | HP DeskJet 3745 Printer
I need to change to size of the print
When you are ready to print, go to the option above print, called page setup. Change the scale to about 150%, just experiment with that and it should help. There are other options in print preview that will let you change the size, but I would go with page setup. Hope that helps
Feb 21, 2008 | Video Game Consoles & Games
Epson R300 printing only in top left corner of page
Change the paper settings in the driver when you go to print. If you have it set to 10x15 it will only print a 10x15 patch in the corner.
Go to START, PRINTERS AND FAXES then right click on R300 and select PROPERTIES. Click PRINTING PREFERENCES and set the correct paper properties. Click OK all the way to desk top and the settings will be saved.
On the printer panel press ADVANCED, scroll down 3 times to PAPER SIZE and press OK. Select A4 and press OK.
Dec 01, 2007 | Epson Stylus Photo R300 InkJet Printer
DELL A940-Good connection-no printing
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Nov 29, 2007 | Dell A940 All-In-One InkJet Printer
Computers & Internet Logo
35 people viewed this question
Alun Cox
