Question about Casio Tv480 Tv-480 Handheld Portable Pocket Size 2.2" Lcd Color Television Tv
CANNOT GET A TV STATION
NO STATION CAB BE FOUND
How do I manually tune an autotune Ford radio?
On my Ford radio, you press and hold one of the radio station buttons until it beeps, then it does a manual scroll through all the channels looking for a station. Once found, another press locks it in. Maybe your would work the same way.
May 26, 2015 | Ford F-150 F150 Extended Cab
I have a 1998 GMC Jimmy and i just put a new engine and transmission in and everything runs fine but the Console shifter will not shift out of Park....I can take the linkage off at the transmission and it...
there may be another nut along the line into the cab/ at the shifter that is diconnected or frozen, i had an old oldsmobile that i got stuck at the gas station cause the bolt came out. simple fix, but sucked doing it at the gas station lol
Feb 23, 2012 | 1998 GMC Jimmy
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
Toshiba tv 2151tb how do i tune in stations
Toshiba TV 2151TB Tuning
Press remote button adjacent to the picture brightness button.
The symbol of a clock appears.
Press the button again and the >>> symbol appears, this is for course tuning.
Touch the Increase Volume button and auto tuning starts.
When a station is found two green underlines appear.
Type the station number i.e.for 2 type 02, this stores the station.
Touch the Increase volume button again to find the nexr station.
Upto 39 stations can be stored.
Fine tuning of any station is achieved by pressing the tuning button until three blocks sysbol is displayed.
Use the Increase/Decrease Volume buttos to fine tune the station.
Feb 24, 2009 | Toshiba 19A26 19" TV
Sony vaio vgn-a417s tv tuner
Here's the drivers for the Vaio: http://www.howtodrivers.com/model516419.html
Oct 28, 2008 | Sony Computers & Internet
I have an Archos 605 WiFi. I haven't yet connected my Archos docking station to the TV and HDD. Meanwhile, I thought I would copy a programme from the HDD to a DVD, then put the DVD in the computer and...
What kind of HDD do you have, do you have any type of output on it. You stated that you haven't connected the docking station to it and the TV...? The best thing to do is to connect your Archos to the Docking station. Set the docking station up correctly, with cables coming out of the HDD (if it has some sort of output) to the station and out of the station to your TV. Once you set that up, you can use the Archos as a mini DVR or VCR. Go to the REC option on the main screen of Archos, you'll have an option for Video Recorder (tab on top). If you play any source on the HDD, then all you have to do is press the Rec option on the Archos. If you already have a file on the HDD, then try just moving it over into the Archos once you connect the Docking station to your computer via USB or just use the USB cable connected to the computer with the HDD. I use the USB preference as Windows Media Device. (found under menu/settings/system). Is is basically a HDD itself. Remember the Archos will only play certain videos without the purchase of any extra plugins.
Good Luck
Apr 14, 2008 | Archos 605 WiFi Digital Media Player
This unit is a B mobel PS42P2SB
Samsung PS42P2S plasma tv when you switch on from cold sound crackles and pops from the speakers for about 30 seconds then its ok, when you switch off and on when tv has been on its ok, just if you leave it off for a while. anybody know whats wrong.
Apr 05, 2008 | Samsung PS42P2S 42 in. Plasma Television
No remote
I found out that a company named 'Kids Station' makes the tv. Unfortunately, they are not on my universal remote list. If anybody could figure out which codes work, please post them!
Here are two links which have the compant name.
http://www.coinoptoday.com/newsflash/news/warner-bros_2006-01-18_kid-station.html
http://www.planetkrypton.net/category/Electronic_Products
Nov 04, 2007 | Jwin JD-TV1300 13 in. TV/DVD Combo
Casio Tv480 Tv-480 Handheld Portable Pocket Size 2.2" Lcd Color Television Tv Logo
42 people viewed this question
Top Casio Televison & Video Experts
Henry  Thomas
Henry Thomas
mikeuk
Lawrence Oravetz
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
