Question about Cell Phones
How do i shut off the gps function once i am done using it?
How can I shut off the gps function once it is turned on?
Press the home button or back button
Posted on Nov 21, 2013
H20 gps says waiting for nmea gps serial data
Your GPS is looking for an alternative source of NMEA data and is no longer doing it itself. If it doesn't get that data it will continue to look or wait for it. We can disable this function so the GPS relies solely on the data it is receiving through its own antanae. This function can only be changed while in Advanced mode. If you're not running in advanced mode make sure you switch to advanced mode. Once there, go to your Main Menu (from map screen, hit menu twice). In that menu, go and select SYSTEM SETUP. In your System Setup menu you will see an opition, COM PORT. Select COM PORT and hit Enter. You will see three Check boxes (NMEA INPUT, NMEA GPS INPUT, NMEA OUTPUT). Make sure that none of those are checked. Once you are done, you can EXIT out of the menus. Go out and see if you can acquire a Satellite Fix.
From:http://www.bruntonoutdoor.com/support.php?category=Atlas+MNS
Feb 14, 2012 | Lowrance iFINDER H2O C GPS Receiver
What is the reset for and do i have to reset language
The RESET button on the unit will wipe out any personal information, like routes and destinations, that you have added to your GPS unit. All of your Favorites will be erased. You would normally only use the RESET button if your unit is locked up or "frozen", and nothing you do will get the unit to function. Once the unit resets, it will behave and be setup the way it was when you first took it out of the box and turned it on.
If you need to change the language that the GPS uses you just have to go to the SETUP menu. Then chose the icon for Language. The screen will change to a box that will show the current language, with an arrow on either side. Use the arrow to scroll to the language of your choice. Once you see that language you would choose the box underneath that has the word DONE in it.
If you need further information about the language function please let me know.
Feb 15, 2011 | Nextar 43NT GPS Receiver
Our nextar gps said we did an illegal function and shut down
Look for a small hole in the unit, hole will be big enough to fit a paperclip into, in the ho;e is a reset button, turn the power on, then hit the reset button, this should fix the problem. Hope this helps
May 10, 2010 | GPS
When i logged onto the garmin website initially it stated i was eligible for the latest maps update however once i am done registering its no longer available. what should i do?
garmin give you 60 days from the first time you use your gps to update the map for free. so if you turned on your gps august 10th, and it's now the 22th, you're out of luck.
it's from the time of gps use, not the time when you create your profile online.
Oct 22, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
After using my TomTom for about 10 mins. the screen fades then is black. It will come back on if I tap the screen. the voice still can be heard. Can this be fixed ? If so how!
It can usually be fixed and tends to be just an option in the preferences menu
Touch a regular map display once
Now touch the Safety Preferences once
Press Done until you see the Turn Off Map Display
Select NEVER
Select DONE
Select DONE one last time to return to the map.
Hope that was of use
Sep 16, 2009 | Tomtom ONE GPS Receiver
How to set the clock
Hi There
you will need to hold down the source button till the unit shuts off
once the unit is off look for a Button with a F (Function) hold this button down till the LCD display turns on it should only take a few seconds.
once the F (Function is active on LCD) press the F Button (i think its X2) till you see the clock
once your are at the flashing clock use the skip buttons on unit to switch numbers after the hr time is set press F Button again to adjust the minutes.............
when this is done press the source button to turn the unit back on and the clock should be set.....
hope this helped
Mar 05, 2009 | Pioneer DEH-P4700MP CD Player
My GPS's battery dies even when its full.
can you take it in and have them check the battery
Jan 29, 2009 | Tomtom One XL GPS Receiver
Turne on
can you please help me figure out my gps
Jun 15, 2008 | Audiovox NVX226 GPS Receiver
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
