Question about LG WM1814CW Front Load Washer
Burning smell wm0642h mold
I would think it is a problem with the belts as if i use heavy clothes it will not be clean and it will have a burning smell
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 224 Answers
Often this problem can be the motor bushes. check the motor for black powder. this is a sign of brush wear.
Posted on Nov 20, 2013
3 Suggested Answers
SOURCE: clothes smell......
The following are the methods you can avoid odor in clothes after washing.
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
Good luck.Please do post comments if the problem is still not solved or if there are any doubts in this post.
Posted on Jan 20, 2009
Daniel S
  • 4323 Answers
SOURCE: I am having mold and
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 31, 2011
Screeching sound; smell of burned rubber
What is the model number of the unit?
Oct 31, 2012 | Washing Machines
Clothes smell after drying
I don't think the problem lies with the dryer, I would suspect the washer has mold, this is especially true on front load washer, they make products designed just for this problem, check with a large retailer, not sure who makes the mold and mildew remover, I think Home Depot or Lowes may have the product or know about it..
Jan 29, 2012 | GE Profile DPXH46EA Electric Dryer
How do I clean the mold smell from a front load neptune HE washer
some people use vinegar and water and run a hot wash with the unit empty i have found that when cleaning out any smell in a washer whether it be stagnant water smells or mold the one thing that works the best is a product they sell at home depot called AFFRESH it comes in two types one for the front load washer and another for dishwashers simply just add one tablet to your hottest wash without any clothes for heavy mold sometimes il run it twice with two tablets separately it sells for about 8.99 per package and is a life saver of all front loaders if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation this way I can keep helping people who have similar situations with there appliances Thanks again Rick
Jan 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have some sort of wet guck in the gasket. It took me forever to find where the smell was coming from. I have to clean it out every time I use the washer. Please help.
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps... Please post back for more information
Daniel
Nov 26, 2010 | LG WM0642H Front Load
Washer smells bad - musty
smell are normally due to 3 culprits
low temp wash , liquid soap , moisture
affresh washer cleaner may be worth a try
video
May 07, 2010 | LG WM0642H Front Load
Drum rotates and then motor locks up. Burning smell comes from machine with continued operation. Drum rotates free by hand. Drive problem or motor?
replace your belt ... the motor does not smell like burning rubber, the belt will exzude that odor.
Pop the top ... remove the front ... use care with the door switch wires.
the drum will come free of the unit.
Put the new belt over the drum, through the tensioner on the bottom, around the motor pulley.
You will need help ... put the drum back on the wheels inthe back and replace the front ... snap the top down
while it is apart, clean the exhaust system completely
Nov 02, 2009 | LG WM0642H Front Load
I think the belt burned up . it smelled like
Yup, the belt..
There may be something caught on one of the pulleys...
Clean them when you replace the belt...
Sep 15, 2009 | Washing Machines
Did not go into the spin cycle and smells like something burning
when m/c goto spin the motor load is maximum i hope no thing with your motor
also if you smell like rubber burning maybe the belt , you will surprise every thing you see come after heavy overload clothes
Jul 06, 2009 | Washing Machines
My dryer in my stackable washer/dryer quit
I Think the belt got binded on the motor spindle and the burning smell was the belt burned through by the spinning spindle
Mar 23, 2008 | Dryers
Mold Smell in front loading LG Tromm
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 15, 2007 | LG WM0642H
LG WM1814CW Front Load Washer Logo
89 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
