Question about Dynex 32 in. LCD Flat-Panel HDTV
Vizio lost hdcp connection with display
Accidentally hit buttons on side of tv, then this lost hdcp connection with display came on
My vizio tv turns on but had no display
UNPOWERED INPUT DEVICE
Check to make sure the device you're trying to use with your TV is plugged in and turned on. While it may seem like a silly oversight, it is possible that you switched on your TV and didn't actually turn on your DVD player, gaming console or whatever device you're trying to enjoy. If you tried to use a remote to turn on the device, check that the batteries still have a charge and turn on the device using its built-in power button.
TIP The problem may be your input device itself. Check your TV with other devices and see if it displays them properly. If it does, contact customer support for your device for more detailed troubleshooting instructions
WRONG INPUT CHANNEL
Make sure that your TV is on the right input channel for the device you're trying to use. When your TV isn't switched to the right channel, no visual or audio input from the device will display on your screen or through your speakers. Turn on the input device and press the Input button on your remote to cycle through your input channels until you see the device's display on your screen.
AV CONNECTION PROBLEMS
If you're on the right input channel and your device is turned on, there may be a problem with the physical connection between the device and your TV. Make sure that all cable connections are secure, and also that all cables are connected to the In ports on your TV and the Out ports on your input device. If you're using a connection that has color-coded plugs, make sure the connectors are inserted into their appropriate color-coded ports.
If you're using an HDMI connection, make sure that the cable you're using is compliant with High-bandwidth Digital Content Protection, especially if your TV and input device are both HDCP-enabled. HDCP is a copy protection system that prevents the copying of digital video and audio content as it travels over the connection. Systems connected with non-compliant cables won't display any video or audio conten
FROZEN TV
Periodically a TV may freeze up, showing that it's still turned on but not actually displaying any information from your input device or the TV's menu system. To fix a freeze, power cycling is the best solution. TEP 1 Turn off the TV by pressing and holding the Power button on the cabinet until the TV powers down.
STEP 2 Unplug the TV from the wall power outlet.
STEP 3 Press and hold the Power button on the cabinet for 30 seconds, and then release it.
STEP 4 Plug the TV back in and turn it back on using the Power button on the cabinet or your remote control.
HARDWARE OR SOFTWARE FAULT
If everything is correctly set up, powered on and on the right channel and you still aren't getting any picture or sound, there may be a hardware or software fault in your TV. The best way to check is to press the menu button on your TV or remote and see if the on-screen menu appears. If the menu doesn't appear, contact repair
Sep 28, 2016 | Vizio SV Televison & Video
Home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Aug 22, 2008 | JVC THD-50 System
Is there a reset button on a vizio lcd 32 in flat screen tv and where would the fuse be located what happen was my husband accidentally touched the usb where it says sevice with a wire and the tv just...
Hi Kaycee.
I suggest you try to reset the power to the TV:
Start off by turning the TV off and unplugging it. Press the power button on the side of the TV for 30 seconds. Let go of the power button and plug the TV back in.
Hopefully this will get it working for you.
If this does not solve the problem, you can go to the online video, "How to Power Cycle a VIZIO TV" - see attached video.
Reference is
https://answers.vizio.com/hc/en-us/articles/200132879-How-to-Power-Cycle-a-VIZIO-TV
Hope this all helps you
Mar 04, 2015 | Vizio Televison & Video
New iPad retina won't connect with HDMI TO VIZIO 55 m550nv tv
Sounds like your using an old HDMI cable. You need to get on that can handle HDCP. Walmart has a few decent ones that cost around $14 for a 3' cable.
Feb 03, 2013 | Televison & Video
My Vizio, when I turn it on the Vizio turns white, but the screen is black and there is no sound coming through
Have you tried hitting the 'input' button on the remote control?
Check the connections of external devices like an antenna, satellite, or cable that may be connected to the TV.
Press the TV button on the top of the remote to return to the TV mode if you have changed modes.
May 04, 2011 | Vizio 42 in. LCD TV
I have a VL470M and am trying to connect a LGBD570 Blu-Ray through HDMI. It works fine through the composite input, but the HDMI says "no signal". Am I doing something wrong?
There are two possible issues. 1) The resolutions are mismatched. (output of the player and input of the TV) 2) the player can not confirm that the TV supports HDCP over the HDMI connection. Only 3 of the 4 HDMI ports are HDCP (high def copy protection) compatible.
Try a different HDMI port and make sure that you have the input set to the correct HDMI port. (There is an input button on the side of the TV as well as on the remote.)
The easiest things to check are turn off the Blu-Ray player and then turn it on again. Then press the Home button and navigate to the Setup Menu. Select Display and press the right arrow button, then select Resolution and press Enter. Then set the desired resolution and press Enter to confirm the selection. (Your TV should support 1080p from the Blu-ray player.) Then turn off the player since changing the resolution can lead to video issues.
I hope this helps.
(the manuals for the TV and the blu-ray player are available on line: http://www.vizio.com/vl470m.html and http://www.lg.com/us/tv-audio-video/video/LG-blu-ray-dvd-player-BD570.jsp Click on Support on either site.
Nov 13, 2010 | Televison & Video
TV says lost signal and turns itself off
Unplug the TV from Wall, wait a bit and plug back in. Should be reset.
Feb 09, 2010 | Vizio L42HDTV 42 in. LCD Television
"Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
113 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
