The carriage on my royal deluxe slides all the way left when i hit the key
  • 3594 Answers
SOURCE: return sticks
Try putting a few drops of light oil on the shaft that the carrier rides on and the pulleys that the cables are on (WD40 works well) also look for debris under the carrier.
Merry Christmas
DickyO
Posted on Dec 28, 2007
  • 117 Answers
SOURCE: How do I get the left hand margine to release on my Royal typewri
Generally yoy can set the left margin all the way to the left by holding down the left margin key and pushing the carriage return button
Posted on Mar 24, 2009
  • 3 Answers
SOURCE: Carriage won't advance with space or letters.
You will have to take this in for service. Bad escapement
Posted on Jun 26, 2009
squipps
  • 204 Answers
SOURCE: I have an old school
If there is tension on the carriage when you push it to the right, the spring is not broke or the cord..then the problem would be in the escapement area..you would need a repairman to do this. if the carriage is loose, no tension then the spring is either broke or the cord is off or broke.
Either way not something easy....
Posted on Dec 19, 2009
  • 23 Answers
SOURCE: I can't unlock the carriage on my old Olympia typewriter
YEP, MOVE THE PAPER FEED SELECTOR TO NUMBER 1
Posted on Sep 17, 2010
Deluxe. Why doesn't carriage move all the way to the right?
seems like there is a stop that needs moved , but it's been 55 years since I had a typewriter so you just need to look for it
Aug 29, 2015 | Royal Office Equipment & Supplies
The peice of my typewriter that is supposed to move the paper tothe left as you type doesnt move?
It's either in the carriage lock position, just check if it's locked in place.
The other reason may be that the return spring has broken. Easy to replace & is repairable sometimes.
Jul 18, 2014 | TYPE B 1957 Royal Quiet DeLuxe Typewriter
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Shift Key Problem , Royal Quiet Deluxe
There is a carriage shifting screw on both sides of the typewriter. You will recognize this because it is a screw that has a big bump head with felt on it. It is being hit when you hit that shift lever. You will have to loosen the securing nut first before adjusting.
Nov 17, 2013 | Royal Office Equipment & Supplies
I have an old school "Royal Quiet Deluxe" typewriter; the carriage will not move when the letter keys are pressed or when the space bar is pressed but will move to back space or to slide the carriage back...
Sep 29, 2009 | Royal Office Equipment & Supplies
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
Sep 05, 2009 | Office Equipment & Supplies
Jun 26, 2009 | Royal Office Equipment & Supplies
Mar 23, 2009 | Office Equipment & Supplies
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
k24674
jasbo
jasbo
