Question about VinoTemp (VT60GNV) Wine Cooler
My wine cooler won't adjust temperatures just keeps returning to the highest temp
When I try to adjust the thermostat it won't stay at the new temperature. It just blinks and returns to the highest temperature setting
3 Suggested Answers
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
  • 11800 Answers
SOURCE: Temperature display has steady blinking
This unit uses a thermoelectric element to generate the cooling, not a compressor. Because of that its temperature setting is extremely sensitive and the fans must be fully operational.
The blinking of the light signals that the temperature setting cannot be maintained because a component failure has occurred. The most likely part to have failed is one of the fans so you will have to inspect them both and replace if necessary. If they are ok then you will have to check the thermistor and the control board, in which everything else plugs in.
A basic knowledge of electronics is required for that, if you don't have it then ask someone you know to help you. Calling Vinotemp is out of the question , the bill would be higher than the price of a new cooler.
Posted on Jun 27, 2011
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
Temperature Light Bling
http://www.danby.com/cms/documents/pdfs/en/DWC114BLSDD_EFOM_%28DM%29_FINAL.pdf
set the temp higher,or check front exhaust vent,"a low temp means it is too cold,adjust the thermostat to a warmer temp"
Mar 14, 2015 | Danby DWC114BLSDD 38 Bottle Dual Zone Wine...
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
I need to lower the temperature
There is a thermostat that is seen on the unit , you will have to set the thermostat to a lower level. Also check if there is any gasket leak to confirm that the cooling does not stay.
Keep the cooler away from hot spots to encourage the cooling to stay.
Sep 17, 2010 | Emerson (025806803716) Wine Cooler
Can the U-Line 15WC Wine Captain be converted to a beer cooler? Can it be adjusted so that it gets colder?
Here is a couple of reason that answer is no. One the thermostat is designed for 45 - 60 degrees. 2 The door is only design for those temperatures as well. I believe you are going to need the bee around 34 degrees. A wine captain would never make it. Its also design for 3 different temps at once. coldest on bottom and warmest on top.
Aug 22, 2009 | U-Line 15WC Wine Cooler
Magic Chef Dual temp. wine Cooler #MCWBC77DZC
I suspect the cooler can only actually regulate one of those temperatures and the other one just drags along behind. Perhaps the weather is now warmer and the cooler has to keep the motor on longer to keep cool. The unregulated bottom temperature ends up cooler as a consequence.
Either that or the opposite effect is doing it.
The answer might be to find a 61 degree place in your house to keep the reds.
Apr 28, 2017 | Magic Chef MCWC30MCG Compact Wine Cooler
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
VinoTemp (VT60GNV) Wine Cooler Logo
55 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
jackj59
Level 1 Expert
jasbo
jasbo
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
