Question about Life Fitness 9500HR Treadmill Next Generation TR9500HR Next Gen
Waxer empty - Life Fitness 9500HR Treadmill Next Generation TR9500HR Next Gen
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Posted on Oct 16, 2012
    Treadmiill keeps saying waxer needs filled after filling it
    please see the cause and remedy and fix it. Please read carefully your section of troubleshooting instr. manual or download
    Inspect spray pattern between 8" (200mm) and
    16" (400mm).
    If not, verify wax nozzle is clean, hoses are not
    kinked, wax bag is not empty, or wax is
    contaminated.
    http://www.sportsmith.net/images/product_support/lifefitness/Treadmills/TR9100/9100 Treadmill Manuals/Service/m05100k
    God bless you
    Nov 29, 2012 | Treadmill Doctor LifeFitness 9100...
  • Oct 15, 2012 | Life Fitness 9100 Next Generation...
    Our machine display show the following masage MOTOR CONTROLLER COMM DRD
    two possible issues
    one, unplug treadmill remove hood and make sure the main power connector to the motor control box is in properly then turn treadmill back on this has worked for me before
    two , you have blown the overload resistor on the motor control board (mcb) to check this unplug treadmill and remove the steel motor control box from under the hood remove the motor control board from inside the box and inspect it for damage and /or electrical burn smell
    if you find damage you will need to get it repaired contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping . it cost $200 plus shipping which is a deal since a new one is $1000,i have many repaired by them
    a common issue for the overload to blow is friction between the belt and deck board . if you have an auto waxer , the waxer nozzle is usually plugged . the nozzle should be cleaned once a month
    contact glide for their non clogging wax to resolve this issue
    good luck
    Dec 26, 2010 | Life Fitness 95Ti Treadmill 95 Ti
    I can't reset a fault named "wax empty" and my equipment doesn't work life fitness 9100
    hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
    Aug 13, 2010 | Life Fitness 9100 Next Generation...
    I need Pad holder assembly for chamberland model no. wm1000 polisher part no. 41p27021 in my owners manual
    go to Chamberlain website and you should be able to order from there and it will be delivered to you.
    Jul 13, 2010 | Chamberlain Standard Duty Polisher/Waxer
    I have a life fitness treadmill and put new wax in the blader how do i start the machine and put wax on the belt?
    you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
    Apr 12, 2010 | Life Fitness 9100 Next Generation...
    Treadmill wont run its saying waxer empty and notify maintainence
    Does this treadmill have a wax system ? If it does it will have side access panels on the side just above the rear leveler. The picture that shows here does not but need to be sure it does not really need wax.
    If it does not have a waxer- enter maintenance settings on display console,I do not have one in front of me but I believe you hold pause button down and press clear twice. This should bring up maintenance settings.
    Scroll using up down arrow untill you see replace wax bag or something to that effect. select [enter ] to save. press clear clear to restart.
    Feb 07, 2010 | Life Fitness 95Ti Remanufactured Treadmill
    Variable speed Control problem
    When you are finishing the surface, it's vital to maintain control. Work too fast or too slow and you risk ruining your hard work with unsightly scratches
    Aug 27, 2008 | Vector Vec 260 10 Inch Waxxpro...
    Life Fitness 9500HR Treadmill Next Generation TR9500HR Next Gen Logo
    15 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Electro Med Services...
    Matt Olenzek
    Matt Olenzek
    sajeel1978 .
    Level 1 Expert
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
