Question about Kenwood Dnx-7240, Dnx7240, Dnx-7240bt, Dnx7240bt Audio,video, Sub, Rca Cables
Security code set - Kenwood Dnx-7240, Dnx7240, Dnx-7240bt, Dnx7240bt Audio,video, Sub, Rca Cables
Want to reset security access code on my Nokia
To set how your phone uses the access codes and security settings, select Menu >Settings > Security.
The security code helps to protect your phone against unauthorized use. The preset code is 12345. You can change the code, and set the phone to request the code.
The PIN (UPIN) code, supplied with the SIM (USIM) card, helps to protect the card against unauthorized use.
The PIN2 (UPIN2) code, supplied with some SIM (USIM) cards, is required to access certain services.
PUK (UPUK) and PUK2 (UPUK2) codes may be supplied with the SIM (USIM) card. If you enter the PIN code incorrectly three times in succession, you are asked for the PUK code. If the codes are not supplied, contact your service provider.
The barring password is required when using the Call barring service to restrict incoming calls to and outgoing calls from your phone (network service).
To view or change the security module settings, select Menu > Settings >
Security > Security module setting
OR
can look for::
http://www.unlock-free.com/nokia-master/
good luck!
Dec 28, 2013 | Nokia Cell Phones
I want to reset my nokia security cide
For reseting the security code, you should be aware of your current security code. If you haven't changed it since you bought the mobile, then the current security code will be 12345. Now, having the current security code in hand, go to SETTINGS and the scroll down to SECURITY SETTINGS. There you will find an option CHANGE ACCESS CODES. Select that option and select CHANGE SECURITY CODE. Now, provide your CURRENT security code and then the NEW security code and hit OK. The process is complete. You can use the new SECURITY CODE right away.
Hope this one solved your problem. If you have additional doubts, please come back to us.
Regards
Sunny.
P.S: If the solution is helpful, please accept the solution.
Jul 09, 2011 | Computers & Internet
How to change the security code for mobile when you know the master code for Nokia 1100 mobile
Nokia default code is 12345, just go to setting,security then enter the current code then re enter the code to confirm.
Jun 24, 2011 | Nokia 1100
I want your phone locker?
You can set up a security code to lock your Nokia 6288 keypad in case a thief tries to call from your stolen phone
Published on Mar 14, 2007
You can set up a security code to lock your Nokia 6280's keypad in case your phone opens in your pocket and calls one of your contacts, annoying them and potentially running up a huge bill.
The code will also stop a thief from using your stolen Nokia 6280 to run up a huge phone bill before you can alert your network provider.
To set the security code, click Menu > Settings > Phone > Security keyguard. You'll be prompted for the Security code. By default this is 12345. Enter this and press OK. Select On and click Select to see the message 'Security keyguard activated'.
Now when you slide your phone shut and press Lock, you'll see the message 'Keypad locked with security code'.
When you slide it open, you'll be prompted to enter the security code. Type your code and click OK to activate your keypad.
Of course, if any potential phone thieves are reading this, they'll now know the default security code is 12345.
To change the security code, go to Menu > Settings > Security > Access codes > Change security code. When prompted, enter your current security code and click OK. The enter your new security code (a PIN between 5 and 10 digits in length), click OK and enter the new code again to verify it. Click OK and you'll see the message 'Security code changed'.
Hope this helps.
Jan 12, 2011 | Nokia Lands Phones
I dont remember the security code nokia 2690 & i don't use my key pad
hay i recently buy nokia 2690 but am not able to set its security code please tell its procedure b coz after selecting to setting
Jun 29, 2010 | Nokia 2630 Cell Phone (Unlocked) - Black
I FORGOT MY PHONE SECURITY CODE .. IMEI 356851026119822 .. HELP ..
When the phone requests the security code, try entering 1473073742. If this does not work you will need to take the phone to a reputable mobile phone engineer to get the security code reset to default. If this code allows you to access the phone, you can then go to the security settings in the phone and set a security code you will remember using 1473073742 as the old security code.
May 21, 2010 | Nokia 1600 Cellular Phone
I want to change my security code. Right now its the same default code 12345. But dont know how to change it as i desire?
To change your security code from the default, follow these steps carefully;
  1. Press Menu
  2. From Menu, go to Settings,
  3. From Settings, scroll to Security settings
  4. From Security Settings, go to Access Codes,
  5. Press Access codes and you would see Change Change Security Code.
  6. Press Change Securty code and you would be asked to enter your old security code (which is 12345, the one your are presently using) and thereafter, you would be required to enter the new security code.
I wish you the best and don't forget to rate this.
Dec 29, 2009 | Nokia 6233 Cellular Phone
My security code and i want to unlock it
Enter the lock code instead of the security code. After then to change the security code.
  1. Go to menu and there open settings.
  2. There open security settings.
  3. There will options such as change lock code or change security code etc.
  4. If you have forgot security code then you can't change it, better change lock code as your desired password.
  5. To change first get into change lock code and enter old lock code and after that input new password and its all done.
Aug 14, 2009 | Lands Phones
Nokia 6103
The DEFAULT SECURITY CODE IS 12345 . BUT IF YOU HAVE CHANGED THAT DEFAULT ONE........THEN,
To get the security code visit this site www.lur.nu/nokia_mastercode/security_code.php
Use that security code to restore factory settings......
HOPE MY INFO SOLVES YOUR PROBLEM......
Thanx for using fixya....
Oct 09, 2008 | Nokia 6103 Cellular Phone
LG KG220 Security Code
0000 is the security code
Feb 17, 2008 | Cell Phones
Kenwood Dnx-7240, Dnx7240, Dnx-7240bt, Dnx7240bt Audio,video, Sub, Rca Cables Logo
46 people viewed this question
Top Kenwood Video Cameras Experts
Are you a Kenwood Video Camera Expert? Answer questions, earn points and help others
