Question about Lexmark X654de MFP All-In-One Laser Printer
920.06 fuser error
How do you reset a fuser error? I have already replaced the fuser
3 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: 920.06 SERVICE FUSER ERROR
    A 920 fuser error indicates that the fuser unit in the printer is below the proper temperature for printing. Turn off the printer for 30 seconds. Bypass any surge device or power strips, plug the printer straight to the power outlet in the wall. Make sure the printer is an operating environment where the temperature is above 16°C (60°F). If none of the steps above correct the issue, the fuser unit or possibly the power supply unit on the printer will need to be replaced. This will require a service action on the printer. I hope I can assist you more on this.
    Posted on May 26, 2010
    mariolands
    • 2296 Answers
    SOURCE: MON IMPRIMANTE LEXMARK T640N AFFICHE UN CODE D
    Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T640n, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
    If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
    Posted on Feb 18, 2011
    How do I fix a fuser error in a Xerox Work Center 4250 printer?
    Hello, my name is Steve.
    Keep in-mind that you still need to "Reset" the fuser's Image count.
    Resetting this will start the process from "0".
    Hope this helps,Steve
    Aug 18, 2015 | Xerox Office Equipment & Supplies
    We are getting a 50.7 fuser error on our HP CM6040mfp printer and we replaced with new one but still it showing the fuser error. Do we need to reset the printer or any other issues .kindly help
    Pressure release mechanism error in fuser, you already replaced the fuser.. then check below connectors.. Remove rear door...>Check connectors:J1720,J1965,J1964 &dc controller PCA connector J105 & J121..shown in fig>check fuser driving gear,>Fuser driving motor as shown in fig>Fuser sensor flag & pressure release sensor> perform sensor test... administration..scroll to trouble shoot..sensor test..perform all sensors as shown in display.. check sensot test passed or not...
    Jan 31, 2012 | HP Office Equipment & Supplies
    Panasonic UF-9000 Laser Printer/ Fax, E04-01 Error Already Replaced Fuser Assy. for Grinding noise & broken fuser gear.
    Hmm, that is still a fuser error for sure, was that the same error you had before you replaced the fuser assembly? You did replace the fuser itself with the assembly, correct?
    Let me know
    Tim
    Sep 24, 2010 | Panasonic Panafax UF-9000 All-In-One Laser...
    Getting a 80 Maint. Error. Replaced the fuser. How do I reset the paper count?
    Go to Config by turning off the printer. Then press and hold Select and Return buttons while turning on the printer. Once in Config Menu, choose Reset Maintenance Count.
    NOTE: The error indicates that the printer has already printed 300k pages, worn out transfer and charge rollers. You should've replaced the maintenance kit = fuser, charge roll, transfer roll and pick tires. Otherwise, you'll ge having print quality issues.
    Jun 15, 2010 | Lexmark W840 Printer
    May 26, 2010 | Lexmark T640n Laser Printer
    May 26, 2010 | Lexmark T640N Networkable Mono Laser...
    Replace fuser E error
    Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
    Apr 05, 2010 | OKI B6200 Laser Printer
    Has an E04-01 on the display printer error
    This error is to do with the fuser warm up temperature. I would recommend replacing the fuser. I don't know how technical you are, but it is quite a job to replace (the copy module has to be removed as well as all the covers). Hope this helps.
    Nov 26, 2008 | Panasonic Panafax UF-9000 All-In-One Laser...
    Cru fuser error
    I already solved the cru fuser error by replacing the fuse of the toner cartridge.Thanks anyway for this information.
    Jun 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
    Lexmark X654de MFP All-In-One Laser Printer Logo
    62 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
