Question about Konica Minolta Office Equipment & Supplies
Error code c-c132
Papaer deck pf 601 comes with this error code please let me know what is it...? thanks
Having the same code on my 5501. Have recently purchased a PF602- apparently this is not compatable with the 5501. Has anyone had success on a 'bodge' or workaround for this?
Posted on Jun 12, 2015
What is wrong if my Frigidaire front load dryer
Thank you for your inquiry, friend!
I understand that your Frigidaire dryer has been providing you with an error code "PF". Typically "PF" stands for power failure this can happen if power is shut off during a cycle or the dryer receives insufficient power, which could be an issue with your power cord or control panel. Let's perform a reset on your dryer and you can do this by unplugging the power cord for ten minutes. If you need any additional assistance please feel free to reconnect. -Matt
Oct 14, 2014 | Dryers
Tip
PF Error Code for Appliances
<p><br /> <p>There is one<b> <i>Error Code that is almost universal to most any appliance</i></b>. The<b> PF or Power Failure code</b> is usually the same no matter what <b>type of appliance</b> or <b>brand</b> you are working with. Even with the fact that this <b>error code is so common</b>, I still see many questions on <b><i>www.Fixya.com</i></b> that are asking <b>what the PF Error Code means</b>.<br /> <p><br /> <p>So now the next question is this.<br /> <p><br /> <p>What causes the <b>appliance to give you the PF error code</b> in the first place?<br /> <p><br /> <p>The most common cause of your <b>appliance giving you the PF error code</b> is a problem with the <b>power coming in from your utility company</b>. Of course if there is an <b>interruption of power</b>, and then the power comes back on you will get the<b> PF code</b>.<br /> <p><br /> <p>Some <b>appliances will give you the PF code also if the power voltage goes low</b>, or goes into a <b>brownout</b> condition. Depending on the sensitivity of the <b>appliance control</b> you may also get the PF code for other reasons such as <b>frequency problems</b> or <b>voltage fluctuations</b> or <b>power spikes</b>.<br /> <p><br /> <p>The other <b>problems that can cause the PF error code</b> can be internal to the appliance.<br /> <p><br /> <p><b>Loose wires going to the circuit board</b> or the control can also be a <b>cause of the error code</b>. If a <b>wire terminal end</b> happens to get <b>corroded</b> or loose, the <b>vibration from the machine</b> can cause slight power problems and this can <b>cause the PF code to be displayed</b>. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by <b>banging on the side of the appliance</b> or <b>slightly moving the wiring harness</b>, to see if you can get the error code to display.<br /> <p><br /> <p>The bottom line about this <b>power failure error code,</b> is that it is <b>power related</b>. Finding the exact cause can be difficult. If you are continually having to <b>reset the appliance</b> then check to see if all of your appliances are giving the same code. This will indicate <b>utility power problems</b>. If only <b>one appliance is giving the PF code</b> then it is probably internal to the appliance.<br /> <p><br /> <p>
on Mar 06, 2011 | Refrigerators
My LG comes up with the error code PF
PF - Power Failure - PF error code indicates a power failure during the washer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks
Oct 23, 2011 | LG WM-2277HW Front Load Washer
Pf code comes on after normal cycle and dishes finish washing
Here is a tips that I wrote that will help to explain why you get the PF Error Code
heatman101
Feb 09, 2011 | Frigidaire 24 in. PLD3465REC Stainless...
We are getting an error code of "PF" and can't
heatman101
0-=0
Oct 31, 2010 | LG WM3431 Front Load Washer / Dryer
Pf code came on and then went to er code reset power and pf code comes up then starts showing 37-36
heatman101
,./;''l
Jun 18, 2010 | Frigidaire 24 in. PLD2560LCC Energy...
The PF(power failure code) comes on several times
heatman101
Jun 03, 2010 | Frigidaire 24 in. PLD2850 Built-in...
PF CODE COMES UP WHAT IS LIKELY PROBLE
Found the below at http://lgknowledgebase.com
The PF error code indicates a power failure. This might occur while machine is working due to an external disturbance like a storm or power outage in the area. If the PF error code is displayed, turn off the power to the washer, unplug it for 10 seconds, and restart the wash cycle. If the error code continues to present after these steps have been taken, then the washer may require service.
hope this helps,
best of luck, have fun,
thanks,
chuck
Feb 25, 2010 | LG WM1814CW Front Load Washer
Xerox tektronics phaser 850- media jam
The preheat entry sensor assembly probably has broken sensor arms, and will need replaced.
Jun 13, 2008 | Xerox Phaser 850 Printer
161 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
