Question about Ovens
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Luce (hotpoint) gas on glass hob 5 ring burners brand new keeps going out on low flame when pull pan drawer beneath out. 3 engineers have seen it and not resolved the problem. 2 have said ventilation a problem. So kitchen company have drilled around 12 holes 4 cms diameter in back and floor of cabinet plus 2 in the drawer itself and taken plinth off and still the flame goes out when the drawer is pulled out. HELP
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Posted on Mar 06, 2014
barkencoa
  • 3463 Answers
SOURCE: element / burner / hob is overheating on an electric oven
If three of the rings are not responding to adjustment, then I would say yes, you have faulty regulators;It is a fairly straightfoirward job to replace if you know how to access the controls
Posted on Dec 05, 2008
gas784
SOURCE: Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
Posted on Sep 07, 2008
  • 3 Answers
SOURCE: replacing glass top stove HELP!!!
You can buy replacement tops for your range. Check with your manufacturer for local parts distributors or service locations and they should be able to find you one. There is also online part stores that sell them like http://www.partadvantage.com/store anywhere from 150-400$
Posted on Sep 29, 2009
barkencoa
  • 3463 Answers
SOURCE: Electrolux EOG9330 Oven Door Glass shattered!!
It is quite common for this problem to occur.
There is no one satisfactory explanation for this to happen, but happen it does.
DO NOT use the oven until you have it repaired.
Contact the makers or one of their repair agents to get a new door glass fitted.
Hope this helps, and in the meantime have a nice xmas, go out and let someone else do the cooking for you..
Merry Xmas.
Posted on Dec 25, 2009
SOURCE: Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Posted on Mar 18, 2010
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Flame very low in bottom oven
    If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
    Jul 29, 2012 | Ovens
    Gas oven flame yellow not blue like grill and hob rings.Flame is floppy and laboured and doesn't shoot up when turned up,could this be the thermostat Regards F Daley
    Normally not the thermostat. Blue flames signify that the gas is burning clean, a yellow flame signify that some contaminate is burning with the gas. I would guess that something has leaked onto the burner or you have some corrosion build up. Try taking it out and giving it a good cleaning with a soft bristled brush and see if that is any better.
    Jul 01, 2011 | Ovens
    Hello. I have a new hotpoint CIO644 induction hob but when I turn a hob on, and put a pan of any size on the hob, it start ticking. The ticking stops when I take the pan off. The display shows the setting...
    Hi
    I'm not sure that you really have a problem as with induction hobs you need to put your pan (metal only) with the ingredients in it on the hob before switching the heater on.
    it is the pan which will get hot, the ticking may or may not be the pan heating up.
    Try it with water only in the pan and see if it works.
    Dec 20, 2010 | Hotpoint Ovens
    PRODUCT DETAILS For MSP60SS
    Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
    Product Features
    •Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
    •Ovens: Fan oven
    •Timer: Minute Minder
    •Hob: 4 Burner Gas Hob
    •Colour: Stainless steel
    •Energy rated top oven: B
    Hope this helps. Your generous rating will be much appreciated.
    If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
    Oct 20, 2010 | Ovens
    I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
    Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
    There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
    Making Observations
    The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
    Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    A friend has a oven that has been coming on with a bang. I've cycled it on and off cold and hot no problems when I was there. Pulled the botten pan out (it is quite worped from heat and dosn't fit that...
    a lot of iffy things could be happening here..
    verify proper amperage draw through the ignitor.. i believe thats a 3.2-3.5 amp system but check the label thats on the gas valve, it will have the ratings listed on there for sure. make sure amperage draw is in the middle of the range as some gas valves are less tolerant of low amperage draw than others.
    it almost sounds like your amperage load may be on the low side, just enough to open the valve regularly but not open fully..
    its on its way out if so..
    the popping could be the gas coming into the oven slowly enough to NOT blow directly across the ignitor properly, (igniting it instantly if it were) and allowing it to pool in the enclosure some because of the low amperage draw through the ignitor, eventually firing with a bang..
    yes the regulator vent could be plugged, but another thing is if you are on bottled gas/lp/propane for your source of fuel the regulator at the tank could be faulty also, causing the pulsing flame..
    hope this helps,
    best of luck,
    ttfn
    Nov 02, 2009 | Jenn-Air Ovens
    Two Gas hob burners will not remain alight
    Does The thermocouple NOT hold at all or does it go out on low ? make sure the Flame heats the thermocouple , have you tried of disconnecting the Thermocouple from the Magnet and just clean the terminal on the T/C Have you measured the T/C Millivolt reading ? Have you got a clean connection on the Electromagnet ,Chech for bad solder joint in the Magnet
    Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
    I need to get the oven floor out to clean under it.
    pull your bottom drawer out and lift up on the front of the drawer then remove the drawer. then remove screws to remove the floor pan
    Apr 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Tappan gas stove,oven not lighting
    yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
    Jun 03, 2008 | Ovens
    Ovens Logo
    131 people viewed this question
    Top Ovens Experts
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
