Question about Motorola Mobility RAZR V3
Car charger lights up but phone does not take charge
Lately the charger has been making frequent beeping noises while charging. Today when I plugged it in the red light on the charger base came on but the red light on the phone does not, the beep noise indicating charging was not heard, and the phone did not take any charge. Is this a problem with the car charger or the phone?
  • 425 Answers
Try charging your fon in your house outlet. if it works then your car charger is defective. if still your fon wont charge in your house then your fon has a prob in its charging section.
Posted on Oct 16, 2007
Why want my tablet charge Where do I return my tablet it will not charge anymore
Most common cause of this is faulty charger, the metal connector at end of wire won't connect properly to device charging port.
Test it by putting plug back in Tablet charger port and very very gently wiggle it around very slowly, see if the charging light comes on or flickers. They usually make a beeping noise when successfully charging or the screen lights up. If you get intermittent charging then it's the charger and time to get a new one. Very common, most are USB connectors or small pin types.
If it's still under warranty then send it back to the place you bought it before you try testing it.
Oct 07, 2016 | Tablets & eReaders
I have a Gateway NV53A laptop. I love my laptop however there have some problems lately and now it would even charge. The first issue was there would be some sort of a straching noise as if something was...
The charging problem could be a faulty charging circuit in the laptop or the laptop battery is worn out. Rechargeable have a finite number of charge cycles.
The beeping noise is a power on self Test error message and the number of beeps indicates the error code.
You need to take your laptop to a computer repair shop the assess the laptop's fault and when you get the quote then decide to get it repaired or put your money towards a new laptop.
If you decide to get a new laptop you can salvage the hard disk from your old laptop and insert the hard drive into an USB hard drive case and use it as an external USB hard drive for data backups and file transfers.
May 16, 2013 | Computers & Internet
The AC Adapter makes a beeping noise and doesn't charge the batt.
I would verify that the battery will take a charge. If the battery is bad, the charger will tell you that it is not charged. It will not tell you why, just that it is not charged. If not plugged into the computor,again, battery is not charged. Hence, the beep.
Good Luck and hope this helps.
Mar 15, 2009 | Toshiba Portege R100 Notebook
My Phone dont want to charge
Try to turn off and on the phone. If that still does not work try to use a different charger. Sometimes even if the light is on the charger does not charge.
Feb 06, 2009 | Palm Treo 500 Centro
Charging problems
try whit usb cable comming whit phonne . if you have this cable plug into usb port on you computer and chec if you phonne charge now. if not call back
Feb 03, 2009 | LG VENUS Cellular Phone
Motorola v3 car charger
check your cigarette lighter, it may have a blown fuse , check to make sure its not the problem.
Oct 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Charging
It's beeping because the battery is completely dead and needs to charge. If beeping doesn't stop after a while of charging, you may need a new battery or a new charger.
Jul 21, 2008 | Motorola Mobility RAZR V3
Battery charging problem
Seems like it may be your wall charger.
I would inspect your connectors (both charger & phone) as well though (for dirt or debris).
I would also suggest using Motorola's wall chargers, the products seem to charge best with them rather than the after-market knock-offs which also seem to damage the phones connectors on some models.
May 13, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Wont charge and makes noises
First get rubbing alcohol (higher % the better) and brush both ports on the phone and the charger. Blow dry it for a minute or so and plug in.
If still no-go, then try it with another charger....if the same result, the phone has a bad charging port and need to be replaced.
The newer phones are coming out with very sensitive ports, so you have to be finesse with them.
Apr 15, 2008 | Samsung SCH-u740 Cellular Phone
Can't Charge!!
Try another charger. I broke the plastic that locked into the phone on my car charger and had problems charging. The phone is very finicky about the contacts. Had to replace charger.
May 28, 2007 | Sony Ericsson T610
Motorola Mobility RAZR V3 Logo
296 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
