Question about Sharp MXB402 Copiers
Sharp MXB402 error code L4-06
This error comes up and it wont let me access the main menu. What does this mean and how can I fix it? Thank you
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 126 Answers
SOURCE: sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Posted on Mar 03, 2009
  • 118 Answers
SOURCE: Sharp AR-285 Error Code
A U2-00 is an internal error code from the main processing board's EEPROM (the chip that stores your configuration choices, the copier's serial number, etc.) It can be a faulty EEPROM but most likely the copier took a power hit/glitch and the fault needs to be reset.
To clear the fault make sure the copier is in Copy mode, then press the 'P' key, then the 'Interrupt' key, then the Clear (C) key, then the 'Interrupt' key. This will enter the machine into simulation mode.
Now enter the number 16 and press start. The machine may also ask you to confirm your choice or you may have an 'execute' key on the LCD screen.
Once the fault has been cleared the machine should reboot. If it doesn't, press the 'CA' (clear all) button and the machine should reboot.
If the U2 code persists, you need to call a repair technician to facilitate repairs.
Posted on Sep 17, 2009
  • 6 Answers
SOURCE: error F2 on a sharp ar-5132 B?W copier
i am getting 32
Posted on Jan 04, 2010
  • 2072 Answers
SOURCE: Error code E7-02, what does it mean? how to fix
That is a problem with the laser.
There is a glass down in the drum/toner area that you can remove and clean .
You can also try, pressing p*c*, which is #*C* and press 14 first and follow the fault clear procedure, then 15, 16 and 17, press clear a couple of times and the machine will reset. If that does not resolve the problem, there is a motor in the laser unit that has a motor with small mirrors attached. That is the most likely part failure.
Posted on Apr 03, 2010
I have a brother mcf-8840d with an error code 71. Any thought on what to do?
Your Error 71 means that the mirror motor can't synchronize with the brains of the printer. The problem is most like the motor bearings, meaning you need an new Laser Scanning Unit (LSU), or it could be the main board acting up
Jun 29, 2008 | Brother Office Equipment & Supplies
Daewoo cd player comes up with error 2 and wont play cds who do i fix this the model number for stereo is AKD-0235H
We do not have access to the meaning of the error codes, these are just for the repair shops.
Oct 30, 2012 | 2000 Daewoo Nubira
I have sharp copier ar-m205 it makes l4 error when start booting , what the problem ? i tried to change main motor and MCU but does not fix thank you for help
1 ) First u check it the main motor running or not. Go to simulation mode i mean put this code, press # key then Press INTERUPT key then C key then again INTERUPT. It should put it very fast, now the dispay shows blank then press 25 and START key and then press 1 key then again 1 . now check the main motor run it or not. A good condition main motor will work it when we put this simulation.
2 ) Check the Main motor cable, its conncted to mother board so removed very carefully. The both side ends should not bend or any other damages,then the cable is good. other wise u can change the cable also.then also it will work
3 ) Now also not solve the problem u remove the main motor and change new one.
4 ) Dont change the MCU.L4 is mainly problem due to the main motor
Jul 05, 2011 | Sharp AR-M205 Copier
I have a sharp AR-M355N machine and I keep getting error code F2-00, what does this mean, is there a specific fix for it
This code is Toner Control Sensor open/trouble.
Check connection of the toner control sensor.
Check connection of connector and harness to the main PWB.
Check for disconnection of harness.
If all is fine, replace the sensor.
Nov 09, 2010 | Sharp AR-M355N Copier
I have a Sharp MX-6201N copier that is showing error code U2-10. Does anyone know what that means and how to fix it ? Any advice greatly appreciated !
U2-10 is 'SRAM user authentication check sum error'
Press P * C * to enter the service 'simulation' mode then enter 16 on the key pad and press the start button.
You will be in U code clear.
Press 'execute' on the screen.
The machine should reboot.
It may start to work again.
If not you will need to replace either SRAM chip or the main board.
Oct 31, 2010 | Sharp Office Equipment & Supplies
Error f1
How do you do. You should check join from the main of the charge to device сортера.If connections is checked and where are no mistakes in join no pay attention to mechanical possible damages, findings scrap papers and stranger subject in sorter device. Recall, pr what circumstance appeared the fault.Error code F1 for sharp copiers sf 2020.2030 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive.
Sep 23, 2009 | Sharp SF 2020 Copier
H5-01
Hello sir;That code means, fuser jam, fuser not installed or pcu main board/sub board, seem like fuser unit not installed.
Mar 22, 2009 | Sharp Office Equipment & Supplies
Flashing E62:12 on screen?
Check error still comes after RESET camera by going into camera Menu -> Initialize ->OK
E62:12 is error code means "Lens Overheating". Camera has "Angular Velocity Sensor" on its main board and that can be cause of problem. If still error blinks, contact Sony Service Center for proper fix as this will requires special tools.
Feb 25, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Sharp MXB402 Copiers Logo
160 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
