Question about Panasonic Televison & Video
Panasonic tcl5860 tv mount screws off center on back of tv
Reviews state screw holes for mounting on wall bracket are off center-true?
eagle338
  • 4889 Answers
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Posted on Mar 01, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
SOURCE: what is the wall mounting screw diameter for a Toshiba 40xv645u
dude, im having the same problem - 5/16" wouldnt thread. I'm guessing they are metric - on my way back to Home Depot...i'll let you know what i find out.
Posted on Oct 22, 2009
  • 3 Answers
SOURCE: Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Posted on Dec 13, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
I have a panasonic viera plasma tv model number TC-P60U50, where on tv do I put brackets to mount to the wall?
You will need to purchase a suitable wall mount separately. (You'll need one for LARGE TVs.) On the back of your TV set you'll see there are 4 holes in the lower-central region of the rear panel. They are about 20" apart (left-right) and about 12" apart (up-down) These should match up with the bracket that comes with your wall mount. You will need M8 metric screws that are about 1.25" long. These will also be included with the wall mount. (Which will include some general directions for wall mounting.)
Here is a manual for your TV:
PANASONIC Viera TC P60U50 Owner Manual Page 7
Feb 09, 2016 | Panasonic Televison & Video
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
Television set is roughly 18 months old and has only recently been wall mounted The picture started to freeze then the following day it wont come off standby Brand EVOTEL
HI, if the problem started straight after the wall mount i would imagine the screws holding your wall mount bracket to your tv are the incorrect ones and will be too long ! this could cause all manner of problems ,on the back of your tv there will be numbers by each mounting hole you can safely use ,these will usually have 8mm or similar written in the plastic ,so use no screws longer than what it states or the tv can break down easily ,check the screws holding your tv mount on ,hopefully it will come right if you put the correct screws in. Thank You for using FixYa
Feb 10, 2011 | Televison & Video
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
How do i mount it on a wall bracket ... like what screws do i take out the back of the tv to attach it to the bracket
first buy the right bracket for weight of tv there is 4 big black screws near center of tv ( IF FITTED )take them out place bracket over 4 screw holes then use the 4 screws you took out make sure they are tight ( DONT FORGET TO TAKE STAND OFF )
Oct 12, 2009 | LG 37LG30 37 in. LCD HDTV
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
How to Install Towel Ring
Place the mounting bracket against the wall and trace around the inside of the two ovals on the bracket. Gently drill a hole into the center of the traced oval. If you hit a stud, you will not need the anchor. Carefully tap the drywall anchors into the holes. Screw the bracket onto the wall, using the screws provided, into the two anchor points. Make sure the set screw is backed out far enough to set the escutcheon over the mounting bracket. Place the escutcheon over the mounting bracket, top first. Tighten the set screw with the Allen Wrench provided.
Aug 27, 2008 | Kohler Bathroom Accessory Set with Classic...
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
