Question about GE Profile JP930 Electric Cooktop
F156 beeping on my GE glass top range - GE Profile JP930 Electric Cooktop
How do I fix beeping F11 error code on my frigidaire stove?
The F11 error code stands is a shorted keypad. I suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least 5 minutes. If that does not work you may need to have a professional technician
Sep 28, 2016 | Frigidaire Stove/Oven/Range Black Glass...
After we had a tech to fix the glass top and one burner, the f1:e1 code came out and kept beeping. I was told it could be the control board problem. Could it be loosen wiring problem too?
Need model number of your range to answer this question. Is this gas or electric? Is this a freestanding range or cooktop because I only can find information on ranges with this fault code given. All should EEPROM communication error which is a communication error on start up. when the top was damaged was the unit being used? Was water or liquid a factor when this damage happened? A loose wire would be a different error code or fault code like a F2 - E1 or E2, not your code given. I hope this helps, need more information. Thanks
Apr 17, 2016 | KitchenAid Cooktops
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
What is the solution if my oven beeps?
Hello friend, thank you for your inquiry!
I understand that your door is locked and you have error "F5E1" showing on your range. I would perform a reset on your appliance which can be done by flipping the household circuit breaker off for roughly ten minutes. If that does not correct the issue and you continue to receive the error "F5E1" I would contact a professional to come out and repair your appliance because it could be an issue within your UIB (user interface board) or main control panel. Hopefully this helps. -Matt
Sep 15, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
Need to clean contacts on control knobs under glass cooktop on ge jgp640 downdraft top. Ignitors wont stop clicking. Is the top glued to the chassis
Sorry to read about your problem, I hope this helps you out.
their is no cleaning of contacts, they are sealed units..have to replace the switch,
you have to remove the entire range from the counter top..will take 2 people
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 16, 2010 | GE Monogram ZEU36 Electric Cooktop
My glass top has a broken in the corner on my jgp932 cooktop range can i just get the glass top replaced and can i do it myself
I'm sorry to hear this. you can get just the top, but your lookingat somewhere between 300-700 dollars just for the glass. also this is not a common part and will probably be back ordered, so you'll be looking at a wait of 2-5weeks for the part. you can change it yourself but due to the cost of the glass I would have a service company change it so that if it breaks while changing they will have to pay for a second one and you wouldn't be stuck having 2 broken glasses
Apr 23, 2010 | GE 30 in. Profile JGP932 Gas Cooktop
No heat cookop gives me code rf f156 , lf f116, rr f 146, lr f126
You will need a serviceman for this one as it is a serious problem.
note: rr is right rear, lf is left front and so on.
Usually this indicates a problem with the elements or worse - electronics (if it's the electronic version).
Jun 19, 2009 | GE 30 in.JP950 Electric Cooktop
Cooktop glass broken - need a replacement - where can I find it?
It all depends on our capabilities... The top isn't all that difficult to replace. If it were me, I would call GE Factory Service 1-800-432-2737 or schedule an appointment online at www.geappliances.com as there may still be a warranty on the top which is expensive...
Dec 23, 2008 | GE Profile JP930 Electric Cooktop
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
GE Profile JP930 Electric Cooktop Logo
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
