Question about Water Heaters
Beretta mynute avarie A01
Vokera aav leaking
Robert, i'm sorry to say but the AAV's are machined parts and the seal should not have been broken by removing the cap. The floats are set perfectly and you would have been easier replacing the whole vent. You could have isolated all the pipes under the boiler and just drained the boiler down by releasing any pressure by the pressure release valve. You may need to buy another AAV and start again.
Apr 06, 2014 | Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Vokera mynute 28 se, plumber has replaced fan and swithch as the burner would not cut in, was beeter for a year or so, in trying to find the problem again, he has discovered that if the front plate closing...
It sounds to me like the outside air intake (your boiler requires outside air for combustion) is plugged. Bird's nest, maybe? Leaves? Spider webs? Have the plumber check outside AND where the intake air connects to the boiler.
Nov 05, 2013 | Water Heaters
Pilot light gone out on a mynute 14 se ....vokera....there usually is a flame..
press the pilot button and use a long lighter to light the pilot
Oct 13, 2009 | Water Heaters
The pilot light on my vokera mynute 14-48-SE has gone out how do i relight it?
turn honeywell gas control clockwise and push in then spark egniter hold for 20secs then ease off button slowly pilot sound remain alight
Oct 08, 2009 | Water Heaters
Low hot water pressure .have A VOKERA MYNUTE HEATER
Sounds like you have debris that is caught in the line or calcium buildup that is blocking the line.
Apr 09, 2009 | ACCO Brands Water Heaters
Vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Mar 14, 2009 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
