Question about Pioneer DEH-P780MP CD Player
Loud engine noise through speakers
Hi, I'm having a strange problem with my head unit, almost a month after installation I began to hear a very loud engine noise through the speakers. To begin I have it connected to a 4-channel Kicker kx-350.4 and four sets of Phoenix Gold 6.5" component system speakers. Before buying the new head unit I had a Pioneer deh-p8200r and never had that kind of noise with identically the same setup. I checked all the grounds, from the head unit to the amplifier, battery, also installed inline 12V noise filters and nothing happened, I took the head unit out of the dash and turn it on to check if it was some kind of radiation inside the dash but nothing happened. I followed a noise-supression guide from Crutchfield.com but solved nothing, I connected mi iPod through the RCA cables to my amp and the noise was gone so it isn't my amp nor the rca cables. I decided to install the old head unit back into my car and with it there is not a little bit of noise so I concluded it's a problem with the head unit. One last important thing, the noise is even present I have the key on ACC. I contated Pioneer and the gave me a list of local repair shops but when I call to one of them they told me they woudnt repair it because I dont have the receipt. So I will have to repair it on my own but I just wanted to know if this is a common problem, I've been making installations for almost 4 years and never had this kind of problem. I will appreciate any help you can give me. Thanks
Here we go again. i just had the same problem with my pioneer 1900mp. a little research found something out. with the pioneer units, they have a problem with the rca pre out jacks. they can burn out as soon as a little bit of electricity gets into them. of course i tried everything to diagnose the "engine" noise. but nothing worked, so i tried running speaker wires to the high inputs of my 4 channel amp, and the noise was gone. it's your pre outs, unfortunately. but fortunately for you, if it's still within the warranty period, they will probably work something out with you. pioneer customer service is wonderful. give it a shot.
Posted on May 07, 2008
Jadrian - I purchased a DEH-P780MP and have the exact same sound. My suond however increases in pitch throughout the RPM range and is audible when operating the headunit on ACC. I have found this problem to being typical in Checy Sports cars since I can swap this head unit out from my camaro SS into my Mustang Saleen and the sound disappears. The same is true for a swap into my SUV. Never quite figured it out! I think the 12V line from the fusebox or from the battery itself doesn't have "clean" power.
Posted on Oct 08, 2007
SOURCE:
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
I AM INSTALLING A SYSTEM ON MY 1995 NISSAN ALTIMA WITH AN OLD ROCKFORD 360X6 AMP AND NEW ROCKFORD SPEAKERS HAVE TRIED A ROCKFORD PRIME R300-4 AMP WITH EVEN MORE IGNITION NOISE QUITE A LOUD WHINE INCREASES...
Hello my name is Israel and I will try to help you out. I have read your problem and what stood out was where you hooked up an ipod and no noise was heard. Do you hear noise when a cd plays? Do you hear noise when the radio plays? When else do you not hear noise?
Feb 23, 2011 | Kenwood DDX516 Car Video Player
One of the speakers when turned on loud, there is humming sound. sound hear like a helicopter engine
we need to do a little bit of fault finding here to narrow down where it's coming from or what is at fault.
First try physically swopping the speakers over and reconnecting (do not just switch the cables at the back of the amp). Is the sound still coming from the same side or has it swopped over? If it's swopped over, it's a speaker issue and needs replacing.
Ok, if the strange sound is still happening from the same side, have a look along the speakers cable path. Is the cable running along side any power cables or extension leads or is it near any wall warts or mains transformers (the type you get with mobile phones, keyboards, answer machines,etc). If so, move the speaker cable a considerable distance away from these. Now, has it stopped or the noise reduced?
If we are still not getting anywhere, see if you can try your speakers on a friend's system and/or try someone else's speakers you know to work on yours.
If his/her speakers are noisy on yours, firstly you have to consider that most sytems at very high volume will produce some noise, but if it's actually quite a loud audible noise that's relatively new to the system, you need to get the amplifer serviced.
Hope this helps
Good luck
Jan 07, 2011 | Audio Players & Recorders
I have a 4 month old Dell Studio 1535 laptop, with audio problems
Firstly check that the microphone level is down or turned off as this sounds like some sort of feedback that's being produced.
Check the microphone and try to play music again.
Please post back
Good luck.
Oct 02, 2009 | Dell Studio 1535 Notebook
Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Apr 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Whining noise @ acceleration?
You have a bad ground somewhere. You also may nneed to replace your spark plug wires. The deck is getting interference from the engine due to a grounding problem.
Best of luck
Jan 30, 2009 | Panasonic CQ-C3301U CD Player
One more
Does it make any strange noise with no RCA cables plugged into it?
If not, you need to check the shield grounds on your head unit.
Click HERE for the test procedure.
Aug 20, 2008 | MA Audio HK4000D Car Audio Amplifier
Loud and strange noises
The built-in speaker amp or the volume switch may be going bad on you. A quick test is to disconnect the speaker set and replace it with a headphone or another working speaker set. If it behaves normally then the problem is in your original speakers, if not then you may have software driver issues or less likely an issue with the sound card. Let us know what you find out.
Jul 28, 2007 | Dell 5650 Computer Speakers
Pioneer DEH-P780MP CD Player Logo
1,355 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
